Question about Sony FD Trinitron WEGA KV-32FS100 32" TV
SONY initial setup screen flashing on
I have a SONY WEGA Trinitron model KV-32FS100 and the "Initial Setup" auto program screen keeps flashing on and off intermittantly, more and more frequently (no matter what you try to do to stop it), until the remote is disabled. Pushing buttons on TV itself only temporarily helps problem.
  • Anonymous Dec 13, 2008
    I have the exact same problem with mine
  • lizray1967 Mar 08, 2009
    i have the same problem
stonephoenix
  • 563 Answers
SOURCE: Sony FD Trinitron WEGA KV-32HS500...red standby light blinks 6 ti
I have over 10 years experience in electronic tech support.
I know this isn't what you want to hear, but the problem you've described can't be fixed with
troubleshooting. Your TV will have to be repaired. There is a part that has developed a defect and needs to be replaced. If you're still in warranty, the TV will be repaired at no charge to you. The warranty would likely be at least one year from the date of purchase from the manufacturer. If you purchased an extended service plan they will repair the TV at no charge as well.
If the TV is no longer in warranty, it will likely cost a minimum of $150 parts and labor. This is assuming that you only need one
circuit board or small part. If the problem is more than one of the circuit boards, the price of repair could go much higher.
I hope I've provided you useful assistance and that this information allows you to make an informed decision as to how to proceed from here. Please be sure to vote on my response. I hope I've earned a good rating from you today.
Please let me know if I can be of further assistance.
Posted on Jul 11, 2009
SOURCE: Initial Setup flashing on and off
i have the same problem with my sony it takes about a 1/2 hr for the picture to come on and from then on it just constantly blinks off and on. At first i thought it was the cable and the cable came and sed right away its the tv. this happened b4 but it fixed itself, now they tell me its doing this b4 the tuner goes bad.
Posted on May 30, 2006
SOURCE: Sony WEGA KV 32FS100
No picture. Standby light blinks 5 times. Tried unplugging and restarting. Same problem
Posted on May 09, 2008
Heh. I just gave my set the "Fonzie treatment" after I was convinced the initial setup notice was messing with me. The problem cleared right up. No joke.
Posted on Aug 05, 2008
  • 115 Answers
SOURCE: Sony FD Trinitron WEGA KV-32FS120 timer flashing 9 times
WARNING- VOLTAGES STORED INSIDE YOUR TV CAN KILL YOU EVEN AFTER ITS BEEN UNPLUGGED FOR DAYS..your problem is in the zero cross detect circuit . youu should take it to a repair facility. -Or replace diode D647 . Or on remote in this order press "display -5- vol down - pwr ." and then you could watch it right now ..kinda
Posted on Oct 01, 2009
Testimonial: "Thanks for the amazingly quick response. This is very helpful information."
The "Initial Setup" screen pops up and starts
replace your tac switches maybe one of the switch are defective.
Dec 22, 2010 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Describe your Sony FD Trinitron WEGA This started
I have the exact same problem. If you get anywhere (I can't) please contact me at tbiasi@hotmail.com. If I figure it out, I'll get back to you.
Good Luck.
T
Sep 09, 2009 | Sony FD Trinitron WEGA KV-27HS420 27" TV
Initial Setup Screen
Have you ever cleaned the set front glass with windex or glass cleaner.Sometimes the fluid runs down before you can wipe and lands inside right on top of the push buttons that control ( CH,VOL, MENU, etc.) If this happens you can get this trouble. If you up to it take the cover off and look at the board just under the front edge of the crt. If you see green or grey residue you probably have to remove that corresponding TAC switch. You can just cut out and use the remote for that function.
Apr 07, 2009 | Sony FD Trinitron WEGA KV-32FS100 32" TV
Can't figure out how to turn on cable on Sony Trinitron TV
Setting Up the TV
After you have finished connecting your TV, you can use Auto Program to set up your
channels. During Auto Program, the TV will automatically search for available channels and
program receivable channels.
(Make sure CABLE is connected on coaxial and you are not using any other connections such as cable box, hdtv or satellite antenna)
1 Press to turn on the TV. The Initial Setup screen appears.
2 Press on the remote control or on the TV front panel to start Auto Program, or press
to exit.
To perform Auto Program again
Press .
2 Press g to highlight Channel Menu.
3 Press f to highlight Cable. Press to select.
4 Press F or f to highlight On or Off according to how you connected your TV. Press to
select.
5 Press f to highlight Auto Program. Press to search for channels.
6 After Auto Program finishes, press to exit.
To reset the TV to factory settings
Turn the TV on.
2 Hold down on the remote control.
3 Press and release the POWER button on the TV front panel. The TV will turn itself off,
then back on.
4 Release .
✍ When you start Auto Program wait until it is finished; otherwise it will skip over channels that are
available. Perform Auto Program again to program receivable channels.
✍ The Initial Setup screen appears each time you turn on the TV until you perform Auto Program.
Initial Setup
Auto Program [CH+]
[CH–]
First please connect
cable/antenna
Exit
Jan 17, 2009 | Sony FD Trinitron WEGA KV-24FS120 24" TV
Sony FD Trinitron Wega model KV-34BR800
Sony Wega Triniton KV-32FS100 TV
For the last week my TV has been going to a black screen for 10 seconds or so then the picture returns. It has been continual. Last night it stopped going to black screen, but now the standby light flashes 5 consecutive times and the color went haywire. A lot of red and everything that is suppose to be black is green.
I did a soft and hard reset with no success. What's wrong and is it worth fixing? Bought new in November 2002.
Aug 01, 2008 | Sony FD Trinitron WEGA KV-32FS100 32" TV
Initial setup
This is commonly caused by the CRT going too weak, and the AKG circuits are switching off the bias to the CRT. This is part of the high voltage regulation protection.
Other causes, but are rare to cause this, are failures in the bias circuits, high voltage regulation (flyback assembly), and in the scan amplifiers.
With proper experience, reference to the service manual, and the proper set-up, it is possible to determine the causes of the failure, and service it. The cost of the parts will be rather expensive if you can still have access to them.
Jerry G.
Apr 04, 2008 | Sony FD Trinitron WEGA KV-36HS510 36" TV
Initial setup
First give it a hard reset. To do this you must unplug the power cord for at least 4 hours; then try again.  This will reset the internal programming and restore it to factory defaults settings. Unplugging for a shorter period of time may not do the trick.
If the hard reset does not solve the problem it has a defective eeprom OR a bad voltage regulator that feeds the controller IC/eeprom set.  In which case you will need a tv tech to dignose the exact fault and determine the defective parts. (There are over 100 parts associated with these functions).
Hope this helps.
Oct 20, 2007 | Sony FD Trinitron WEGA KV-32FS100 32" TV
May 30, 2006 | Sony FD Trinitron WEGA KV-32FS100 32" TV
Sony FD Trinitron WEGA KV-32FS100 32" TV Logo
312 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
