Question about Dryers
Maytag Gas Dryer has power but not heat to dry
Our dryer is not giving off heat.
We called liberty appliance and they told us to look at the hose and disconnect it and run the dryer.
It still does not give off heat. We cleaned all dust.
LDG5005AAE
  • gudmaps Nov 22, 2008
    Rick,
    We removed the Vent  from wall outlet and back of dryer and lint trap cleaned. Air still is flowing at what seems a strong flow.
    So I assume that the blower is okay.
    When I listen as I start the dryer I do not think I hear any igniting sound although I do not remember well what it should sound like.
    So maybe the problem is in the gas ignitor and there may be an issue with the gas valve, temp sensors, or fuse as you say.
    I guess we will need to wait until Liberty Appliance sends someone out on Monday. Too bad we cannot do it ourselves.
    Funny I could not find our model on the Maytag site. They also refered me to Whirlpool. Guess they must have merged?
    Model Number - LDG5005AAE
    Serial Number - 168300190H
    Thanks for your help,
    Paul
  • 706 Answers
Hello gudmaps,
I'll attempt to assist you with a few things you can try.. to begin with ... if your dryer uses gas to generate heat and is not electric, the byproduct of the gas flame is not one that you would want to vent into a room. If your appliance shop suggested you unhook the exhaust pipe as a means to test the vent system for a minute or two ( to measure the exhaust out of the dryer for temp and flow) then that';s ok for a short period of time.. Think of it as running your car in a garage.. the fumes are unhealthy for you so limit that activity if you can... I can suggest you do the following:
Check to make sure that the entire vent system exiting the dryer is not restricting air flow.. ( that means that when you run it.. you can feel the exhaust is fairly robust at the exit point outside.. if it feels weak , then in all probability your vent system is restrictive and will need a thorough cleaning ( despite lint trap filters,.. some lint does work its way by that filter and end up in the vent duct.. eventually limiting flow to a point that the dryer no longer drys in a reasonable timeframe.
If the vent duct system is not the problem, then you may have a problem with the blower inside your dryer.. Sometimes items get byu the filter and impede the blower from moving air.. If you are handy and can gain access to that ( with the dryer unplugged) .. than that may be the problem..
Lastly, if your blower is moving air and your exhaust isn't restricting that air movement .. you will need to verify that your gas burner is igniting .. You should be able to hear the gas jet ignite and remain lit during the start up sequence.. If that isn't happening then you may have problem with your gas valve itself, the temp sensors and sometime the non-resettable fuse opens and disables the gas flow altogether.. Depending on your technical abilities.. will dictate how far into repairing the dryer you want to go.. Just remember that all troubleshooting inside the dryer should be done with the power removed or disabled.. Hope this helps you..
Regards,
Rick
Posted on Nov 22, 2008
  • Rick Gelin
    Rick Gelin Nov 22, 2008
    Hello Paul,
    Based on what you stated, it would appear that you aren't getting a flame established and that could very well be the non-resettable fuse has opened..or the igniter is defective. If that fuse opens, then the gas valve will not open and you will not establish a flame for heat generation. If the ignitor is defective, then you wound get a flame established in the alotted time and that hardware will shut off the gas. Unfortunately, unless you are comfortable dealing with that hardware ( meaning: the gas system and associated components) then you are probably better off leaving that repair to a trained professional. After it is repaired, please post the solution here so that we can get closure on the findings..
    Regards,
    Rick
Why wont my Maytag Neptune gas dryer stay hot when I'm drying my cloths?
If you are sure that it is a gas powered dryer, the problem could be thermostat, flame sensor etc.
Oct 05, 2015 | Maytag Neptune MDG6700A Gas Dryer
The upper cabinet of our Maytag Neptune MCG8000AW Gas Dryer has always "dried" my dress shirts to come out without wrinkles. Now it seems to have power and light but it is not producing any heat
Most of the time a "no heat" condition on a gas dryer is due to one of two things: burned out ignitor Appliance Parts and Accessories Repair Appliance Parts Discount Parts... OR it could be a thermal limit switch that has failed which are easily replaced with this kit Dryer Thermostat Kit At one time, there was a TSB (Technical Service Bulletin) out on this particular dryer that referred to a change that was made to the electronic control board eliminating the need for an external heater relay in December 2002 (Series 61). The new control board is supposed to work in place of all previous electronic control boards. Good luck.
Mar 12, 2014 | Maytag Neptune MDG5500AW Gas Dryer
Dryer do dryer does not dry clothes
possible bad heating element or corroded internal connections if electric. bad gas jets inside dryer if gas dryer. refer to appliance service tech.
Aug 22, 2011 | Maytag Dryers
Maytag Neptune gas dryer MDG4000AWW not heating properly.
Note: Normal drying time for a dryer is about 45 minutes (some may take up to an hour).
1. Venting
Make sure the dryer vent hose, as well as the rest of the vent duct, is not clogged.
Unless regular maintenance is performed, chances are there is a lot of lint accumulated inside the dryer. This might affect the drying time and could be a fire hazard. Make sure to have your dryer cleaned regularly. Because this might involve taking most of the dryer apart, it is recommended to have a qualified appliance repairman perform this task.
2. Thermostat
There are a couple of cycling thermostats inside the dryer. If one of them breaks down, it might affect the dryer's performance. Replace the defective thermostat.
Jul 15, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Not heating properly, many cycles to dry loads
Check the following to address this issue--
1. Venting
2. Thermostat
3. Heating element
A heating element might only be partially burned out, in which case it would still work but will take longer time to dry the clothes. Replace the element if found defective.
Jun 02, 2009 | Maytag SDG3606A Gas Dryer
Heat and clean vent, but way too long to dry
WHAT IS WRONG WITH YOUR DRYER?
small_8_20.jpg For a detailed Dryer illustration, click below.
Gas Whirlpool Style Version 1
redarrow.gif Gas Whirlpool Style Version 2
redarrow.gif Gas Maytag Style
redarrow.gif Gas GE Style
redarrow.gif Electric Whirlpool Style Version 1
redarrow.gif Electric Whirlpool Style Version 2
redarrow.gif Electric Maytag Style
redarrow.gif Electric GE Style
Warning! To avoid personal injury or even death, always disconnect your appliance from its power source--that is, unplug it or break the connection at the circuit breaker or fuse box--before you do any troubleshooting or repair work on your appliance. Also, because some components may have sharp edges, use caution while working on your appliance.
Electric dryers aren't very complicated. Here are some common symptoms that you may experience with your dryer:
There's an error code on the digital display
It doesn't work at all
There's no heat
It won't tumble
Drying is too slow
It overheats
It seems to run forever
It's noisy
It won't start
The light doesn't work
It blows fuses or trips the circuit breaker
My clothes smell bad!
My clothes are marked or torn
DON'T FORGET TO RATE';
Aug 22, 2008 | Whirlpool LGR7646E Dryer
Initial gas burn does not reignite
small_8_19.jpg For a detailed Dryer illustration, click below.
Gas dryers aren't very complicated. Here are some common symptoms you may experience with your dryer.
There's no heat
It won't tumble
Drying is too slow
It overheats
It's noisy
It won't start
Hope this may help;
DON'T FORGET TO RATE;
Jul 26, 2008 | Whirlpool LGR7646E Dryer
Dryer no heat but runs
There's no heat
It won't tumble
Drying is too slow
It overheats
It's noisy
It won't start
DON'T FORGET TO RATE:
May 15, 2008 | Whirlpool LGR7646E Dryer
Spins but no heat
There's no heat
It won't tumble
Drying is too slow
It overheats
It's noisy
It won't start
Apr 11, 2008 | Whirlpool LGR7646E Dryer
Smell Gas.
you need to clean out you venting ...it is most likely clogged or filling up
Jan 02, 2008 | Maytag MDG2706A Gas Dryer
Dryers Logo
227 people viewed this question
Top Dryers Experts
