I juct got my sandisk sansa e250. it worked for about an hour and a half. i turned it off. i went to turn it on again and it didnt work at all it doesnt do anything when i plug it into the computer either. i tried everything please help me!!!!!
-   when i turn it on it says switch to recovery mode
-   Guest
May 11, 2008
-   I have a similar problem to this.My sansa e250 worked perfectly fine since december.But today i put new songs on it and refreshed the battery and then it was on and working fine.But then i turned it off and went to turn it back on and nothing happened.Nothing happens when i try to charge it either.-   Bonzae
Apr 08, 2008
-   Turned it off. Thought it hadn't shut off and pushed off button again. Now it's stuck. Not on or off.-   ps85
Nov 13, 2007
-   I've had the player for about 2 years and I just am having this problem for the first time now. Same fix worked for me. Unscrew back panel, take out the battery, and then put it back in. Started right up.
h-   Guest
Best Solution
posted on May 21, 2007
Guest
Rank: Apprentice
Rating: 0%, 0 votes
oh thats easy if its on and it wont turn on , bascically to restart your mp3 you hold on to power and record and then put it on lock.
Solution #2
posted on Mar 26, 2007
Guest
Rank: Apprentice
Rating: 0%, 0 votes
Thanks so much! Yes, the solution above helped me. Before, my sansa didn't turn on, and i unscrewed it and did exactly what the person above told me to. Thanks
I had the same problem. I just bought one for myself and used it for an hour while turning it off and on successfully about 5 times, and then it just stayed on. It was on for 5 hours stuck in the same position , frozen in time, until I could get home. I unscrewed the back, took the battery out, put it back in and now it seems to work normal. Hope you tried to do that. I think it will fix it. Hopefully it's not an ongoign problem. I've only had mine for one day so far.
Great! Hooking my e270 up to my stereo I shocked it. There were some tunes that I only had stored on there, nowhere else. I thought I would have to lose them if I ever got it to turn on at all. But sure enough, I took the battery out and put it right back in and all works well - all the tunes are there.
the mp3 sansa (rhapsody model e 250 r is not working, when connecting to the computer the blue light...
(More)
the mp3 sansa (rhapsody model e 250 r is not working, when connecting to the computer the blue light still shines. how can i fix this proble
Songs are deleted randomly. Either they are removed from the playlist or they get deleted...
(More)
Songs are deleted randomly. Either they are removed from the playlist or they get deleted completely.
