Prior to Windows 7 could scan a document into word doc, Now can,c can only get an image, No longer can edit a scan bit of text
SOURCE: I need to scan a document and save as a word doc.
As long as you just 'scan' - using the scanner only then its driver will open the program that came with it. To save it to either a MS document imaging, Word, Powerpoint, Clip Organizer, another photo program, etc, these have to be opened and you do it from any of these.
Your web building program probbly have this function too.
SOURCE: Can not scan legal documents
hi,
HP Officejet 5610 All-In-One InkJet Printer has few common problems. Such as Driver CD
lost, Scanner does not work, Connection problem etc. For find all these software solution
just click here....
http://www.hp.com/printer/prob676ijt65/solution
alkkk-4
SOURCE: HP All-in-One Can't scan without printing
There is an OCR reader in the programs included with the install disk. This OCR will break down your entire document for editing. If you don't have the disk, it very simple to get all the software from the site.
SOURCE: HP C7250 scanning problem
Scan a BLANK sheet of paper.
if you have that black strip it means there sre two possibilities:
>> the scanner glass is not screen
OR
>> the scanner is faulty.
Clean the glass properly using a moist lint free cloth.(do not use alcohol)
if the issue still persists
The only option that you have is to get the printer replaced.
If your printer is still under warranty(i.e if its still not an year old) you can get a free replacement from HP.
wherein they will send you a new printer absolutely FREE OF COST
if its not in warranty then you can opt for the UPGRADE option that HP has.
You can send them this faulty printer and get a LATEST PRINTER at a huge discount..
here's the number to call
1800-474-6836
SOURCE: My HP Photo smart Premium All in one printer C309a
If you have the Win7 full-feature driver installed, try installing the Software Patch. http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?softwareitem=mp-77751-1&lc=en&dlc=en&cc=us&os=4063&product=3737195
If you managed to get the minimal driver set or the OS driver, uninstall that and disconnect the printer from the computer and install the full featured software
http://h10025.www1.hp.com/ewfrf/wc/softwareList?os=4063&lc=en&dlc=en&cc=us&product=3737195
If you can't download the full file and get an installation error from an incomplete file due to connection errors, the link to the full software above also has a link to order a new CD with the drivers.
Sometimes the scan error (when the printer itself works) indicates that the HP monitor isn't running (due to incomplete install or turning off the program (not letting it run at boot, for example). The other cause is a poor connection since scanners need bi-directional communication with the computer. Try a new data cable, plugging into a different port. If you have a print server or USB hub, try a direct connection.
I hope this helps.
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response. Happy Holidays!
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Purchased printer years ago and has worked fine until PC power supply blew and took out mother board and a disk drive. Now connected to Windows 7, the original CD's will not load. Can print no problem. When I scan I can select two options - Photo or Document. Both seem to produce only a jpeg file by default but only offer JPG, BMP, PNG or TIF. How do I get an editable text scan or is this no longer possible with Windows 7 and the Printer/scanner? Would I be better off purchasing a new Printer for Windows 7?
