Question about GE Washing Machines
I am storing a washer in my garage and winter is coming fast it being november in michigan , how do I accomplish this?
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 185 Answers
Hi awningking:
I would take all the hoses, (hot & cold input and drain output) and lay them down on the ground and make sure any water that was in them, comes out. I would then seal up each hose with plastic taped down over the open end, (to make sure no little creatures make there home up the hose.
That ought to do it.
Hope this helps Good luck Loringh PS Please leave a rating for me if appropriate Thanks
Posted on Nov 22, 2008
What was the weather like in Plymouth in November 1950?
phone the weather bureau for that information
Jun 06, 2016 | Plymouth Cars & Trucks
CAN I PUT THIS REFRIGERATOR IN THE GARAGE??
yes of course you can they even work when in an unheated garage
Jan 25, 2016 | Refrigerators
CAR STALLS ON START UP. 1987 mercedes sl 560
Check fuses (for tachometer), fuel pump and blew through injectors: they can have some residue ice from gasoline
Jan 22, 2018 | Mercedes-Benz Cars & Trucks
Engine runs but only a steam of water comes out of gun with trigger on. washer is stored in a heated garage in winter.
you need to remove and clean the unloader valve. The way this valve works is when you release the trigger the pressure is diverted around the pump through the inlet side so you don't cause damage to the pump. This valve is usually located next to the discharge pipe on the pump where your pressure hose hooks up to. Remove and clean. Be sure to clean port that you remove the valve from also. Use carburetor cleaner. Lubricate the valve with a light coat of lithium grease. This should cure the problem. If not let me know.
Jul 25, 2011 | Briggs Stratton 020273 Elite Series...
It is winter time in michigan and my 2000 ford expedition is having fuel pump problems. When it is warm like in the garage it will start right up. But if it sits outside in a parking lot or something for a...
When you start the truck if it does not idle fast and then cut down you are not getting a cold start routine. That routine is built-in and it is suppose to enrich the fuelmix and speedup the idle. It kinda works like a choke.
This feature is triggered by a water temperature sensor. The other water sensor operates your temperature gauge. You just need to go to a parts store like Autozone and see a picture of the part and its location. It will probably be better to remove it from a Cold engine because the thermostat will be closed and you should not lose much antifreeze.
Remember to tell them you want the sensor for the computer controls and not the dash gauge.
I hope you find my solution helpful.
Dec 06, 2010 | 2000 Ford Expedition
Will I damage a refrigerator if I locate it in an attached (to house) garage? I live in southeast Michigan, and I am concerned that winter temperatures may damage the operation of the appliance.
mine is in a garage and as long as the ambient(inside) temp does not fall below +5 i have had NO PROBLEMS FOR THE PAST 20 YEARS.but i run my fridge with an inside temp of +5C,checked every month.
Oct 26, 2010 | Whirlpool Refrigerators
Hooked it up with water started engine and no
Your water system is plugged with "gunk"
You will need to slush it out with water and air pressure if you can until it runs clear
Apr 04, 2010 | Briggs Stratton 020273 Elite Series...
How to store for the winter
in a garage out of the weather would be fine
Dec 06, 2009 | Electrical Supplies
How can i drain all wter from a sears estate washer while a go o
disconnecting the hoses from under machine( usually pump hose is the lowest, all water should drain from machine, we used to place windshield washer fluid to hold them outside overwinter in used appliance store.
Nov 12, 2008 | Jenn-Air JCD2295HES Side by Side...
Washing Machines Logo
77 people viewed this question
Top GE Washing Machines Experts
Tim Whalen
Marvin
Marvin
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
