Question about Zenith 2 Pack of TV/VCR/DVD/CBL/SAT LRN Remote Control
I accidently pushed the ''comp2'' button inside ''source'' buttoms
I accidently pushed the "comp2" button inside the "source buttons on the remote for my zenith big screen t.v.
It now says "no signal" and I cannot get back to regular stations, can you help me?
Cannot get signel
Posted on Mar 07, 2010
Konka remote sed button
Change the Input or Source button. you are accessing a signal from a source that has no signal.
Dec 28, 2017 | Konka Televison & Video
Model 55p8288
maybe the push button switch is defected ,the solder of the switch is brittle , or crack or cold,try to resolder the switch, if not change it with new one.I incounter like this problem before in the switch , i only resolder the joint then its ok,,try this also maybe can help...
Jul 05, 2008 | Philips Magnavox 51MP392H Rear Projection...
What is wrong with my samsung tv
Try pushing the source button on your remote after the red light stops flashing, Keep pushing the source button until it is on "TV". You may have set the remote to one of the aux settings by accident. My dogs do it to me all the time. Good luck.
Aug 28, 2015 | Samsung Televison & Video
No picture just blue screen
Check your settings button. Most remotes have a video source button...if this button has been pressed, then the tv is probably trying to show you the video screen. On my remote, pushing the button 3 times brings it to the dvd screen. Pushing it twice brings it to cable tv...etc.
Your button may be labelled as something other than video source.
Nov 03, 2013 | Televison & Video
Door locks won't lock/unlock
What kind of vehicle is it?
May 02, 2017 | 1999 Chevrolet Blazer
Need to fix problems with 5104 viper remote
It is possible that you need to reprogram the remote.
1st you need to enter the remote into programming... Hold the Function button until the remote gives a long beep and LED light comes on the remote a (it takes about 8 sec.) Then press and hold the remote start buttom until the remote beeps 3 times and LED lights up. Now your ready to program the remote
One of the door has to be open . Insert the key - turn the key to the On position then press the button on the antenna once and then press it again and hold it
You hear a chirp and then you press the lock button on the remote and then you hear a second chirp to receive confirmation and then release the button and the turn off the key .
Remote should be program
Jan 21, 2013 | Viper Televison & Video
The remote accidently has S video button pushed. I have S Video at the top of a blck TV screen. I'm not sure how to get back to the TV screen because no button is working. I run the TV through the...
Use your TV remote to change the input away from S Video. There should be an Input button or Video Source button. Press this button repeatedly to cycle through the inputs. Depending on how your cable box is hooked up to your tv, your input will vary.
Jul 18, 2011 | Vivitek Televison & Video
Trunk does not open with button inside car. Does open with key remote. Is there a bad fuse somewhere and if so which one?
Your Valet cancel switch is set.
Open your glovebox and you will see a pushbutton on the the left side, if memory serves. When this button is set, the power button will be disabled, but the key fob button will still work.
This is for when you Valet your car, you push the cancel button in the glovebox, lock the glovebox, then give the Valet your Valet key, which will not open the trunk or the glovebox. Voila, no Valet rummaging through your trunk :)
Often full gloveboxes will be the cause of the button getting pushed accidentally.
Sep 26, 2009 | 2005 Lexus ES330
How do I program the 2 component video inputs?
on the remote control, push the left arrow button to display comp1, then the up arrow to display the correct video setting. push the left arrow again to display comp2, then the up arrow again to select the correct video setting.
Same procedure for digital audio (coax1 and coax2)
Aug 04, 2008 | Pioneer VSX-D514 Receiver
Setting up w/TV
Sync your remote with the wii. Open the small white door on the front of th wii and push the red button. Then open the back of the wii remote and push the red button there. The remote should sync and you should be fine.
Jul 06, 2008 | Nintendo Wii Console
Televison & Video Logo
89 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
