No Gas getting to the pilot
I have a Dyna-Glo vent free natural gas heater in my garage model #RMC-40NGT.....I had problems lighting it and found that no gas is getting to the piolt.......is there some place I can get parts for this unit or some way I can fix it myself
  • BLAACKY Dec 03, 2008
    I HAVE THE SAME PROBLEM WITH MY NATURAL GAS DYNA GLO M# RMA-FT(P)0219----AFTER VERIFYING THE GAS IS PRESENT, I EVEN DISCONNECTED THE PILOT "FEED" LINE----NO GAS---PLEASE HELP----ANYONE HAVE A SIMILAR MANUAL?
Thanks for the response......when I mentioned in the original problem of getting no gas that was with depressing the safety switch to light the furnace,,,,,,,,,I still get no gas when this switch is pressed.....I was looking at the furnace today and noticed there are a couple different lines running through different parts......I'm not sure which is a sensor bulb.........do you a reference site on the web that can help me or a place to find a manual for a dyna-glo heater ?
Posted on Nov 23, 2008
  • 833 Answers
There is generally a safety switch somewhere on the gas control that needs to be pushed for gas to get to the pilot...if not, gas would just build up to an explosive state in the installation.  Find that push button, use a match or other source of flame to light the pilot.  Hold the button for about 15-30 seconds after ignition to allow the unit to 'see' the flame.
If the gas valve is bad, the first thing you might find bad is the sensor bulb.  Take the old one to the plumbing supply store to reference for replacement.  About $5.
I have a dyna glo RMC 40 NGT vent less wall heater that I would like to convert to propane, I need to know which conversion kit to buy, and where. Thank you.
dyna glo natural gas heater Questions & Answers - Fixya
www.fixya.com > Forum > Tags
dyna glo ventless rmc50 ngt can this heater be changed from natural gas to propaneuse, ... Dyna Glo Natural Gas conversion to LP Gas I have a Dyna-Glo natural gas space ... Question about D-E36 Infra-Red Wall Mounted Panel Heater ... dyna glo heater model #RMC-40GT I believe on your particular model , that you ...
Parts for Dyna Glo, Thermoheat and Dyna Glo Pro Heaters
spaceheaterparts.com/category.sc?categoryId=13
Shop Dyna Glo, Thermoheat, Dura Heat, Workhorse LP and oil fired htrs ... Circuit Board 2201181 Dyna Glo & Thermoheat 150k Nat Gas Htr RMC-FA150NGDGD ... This spark plug (ignitor) is used on Dyna Glo and Thermoheat 40K btu LP.
Propane Wall Heaters - Walmart.com
www.walmart.com > ... > Heaters
WalmartDyna-Glo IR18NMDG-1 18,000 BTU Natural Gas - Infrared Vent Free Wall Heater. $170. ... Dyna-Glo 40K Liquid Propane 360-Degree Tank Top Heater. $88.00 ... Dyna-Glo Deluxe RMC-FA125DGD Portable Gas Powered Forced Air Heater.
1352062 Dyna Glo Natural Gas conversion to LP Gas
162.220.53.34/F/.../t1352062-dyna_glo_natural_gas_conversion_lp_gas
Jan 12, 2016 | Heating & Cooling
I need a thermocouple for a dyna glo heater model #RMC-40GT
I believe on your particular model , that you have to replace the entire pilot assembly. As the thermocouple is an intricate part of it. In which case any LP or Natural Gas heater's pilot assembly will fit it. You will have to secify either Natural Gas or LP Gas when ordering.
I have provided 2 links to where you can purchase the pilot assembly you need.
http://www.mrheater.com/OrderParts2.aspx?catid=57
http://www.aandbsales.com/index.html
I hope this helps you & thanks for choosing FixYa.
Jul 29, 2011 | Dyna-Glo D-E36 Infra-Red Wall Mounted...
I have a Dyna=Glo model RMC-40ngt. I can get the
CHANCES ARE YOUR GAS VALVE IS DEFECTIVE. THE SAFEGUARD PURPOSE OF THE VALVE IS TO PREVENT GAS FLOW IF THERE IS ANY REASON THE SAFETY FACTORS DON'T CHECK OUT RIGHT.
Mar 06, 2010 | Heating & Cooling
We currently have a Dyna Glo wall heater in our "garden room" and want to buy another for a 2nd home (will go in garage). Our model number is RMC-50NGT. Where can I buy??
Hmmm ... where did you buy the last one? Are they out of business?
Here is what I found when I used Google:
http://www.mytoolsbee.com/cat164509.html
Ace Hardware may be a place you can order this stove from also.
Thanks for your question at FixYa.com
Feb 16, 2010 | Dyna Glo "" Natural Gas Heater Mn200tba
I have a Dyna-Glo vent-less wall mounted natural gas heater model number RMI-60NG Pilot light ignites.However no gas will supply too the burners.Causing them to be inoperable.What might be the cause of...
If it is a few years old, it could be the thermocouple. These are usually available from Lowes. Take your model/serial # and if you can, take the old part too.
Dec 11, 2009 | Dyna-Glo Heating & Cooling
Dyna-glo parts
thermocouples you can buy from any heating spares oulet or national energy a hone well is most common for useing as a replacement
Feb 03, 2009 | Dyna-Glo D-E36 Infra-Red Wall Mounted...
Natural Gas Heater Dyna-Glo
it s the thermocouple excannge it should solve the problem , try national energy they do spares
Feb 16, 2008 | Dyna-Glo D-E37 Wall Mounted Panel Heater
Dyna-glo parts
the "click" you hear is the pilot valve closing. the pilot valve is spring loaded to shut off when a flame is not detected or is detected then is not. try this desatech site. it is for reddy heaters but they might have the thermocouple you are looking for.
www dot desatech dot com or
www dot robinrents dot com/heaterparts.htm
Dec 04, 2007 | Heating & Cooling
Glo-Warm Wall Gas Wall-heater parts...
We had a problem keeping the pilot light to stay on, and this site recommended that it could possibly be the thermocoupler that was causing our problems also. We ordered the thermocouple, put it on,hooked it back up and it worked great! Thank you so much.
ordered thermocouple from www.masterparts.net
Nov 19, 2007 | Rinnai Desa Vent-Free Infrared Gas Heater:...
Heating & Cooling Logo
256 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
