Question about HP Computers & Internet
I have a dv6000 pavilion hp laptop, when pressing the power button, the blue lights come on and the screen dosnt. the fan and dvd drive make a noise for a few secs then the laptop turns its self off then sometimes back on but still doest work
  • callum2005 Nov 22, 2008
    the blue light always comes on when charger is plugged in and it was on full battery as its always plugged in. many say there are motherboard issues with this typical model, but can be easily repaire , please help with thanks
Hi. the batery is coming up as full still when i turned it on, coul bit still be the battery?
Posted on Nov 22, 2008
    Sergeant:
    Champion:
  • 334 Answers
Sounds like your battery is dead. make sure that the charger is working properly.
  • Greg Wilkins
    Greg Wilkins Nov 22, 2008
    can you access the cmos battery? Just take it out if you can and put it back in. unplug the charger take your battery out and plug it back in. Try to start the computer without the charger. If it does the same thing i still say the battery is probably down. Because all the blue light tells you is the charger is pluged in. Trying to limit every option because you will probably have to send it in to Hp if its the motherboard
How do I solve a problem with starting up windows in my hp pavilion g6? Whenever I start windows a blue screen appears and the computer restarts.
Sounds like your hard drive has either failed, come disconnected, or someone performed a full format of the drive which wiped out the partitions or the boot sector of the drive. Worst case you will need to replace drive and purchase reinstall disk from hp. Best case you will only need to purchase reinstall disk from hp. If you do need a new drive, I recommend purchasing it from hp directly, as it will already be prepared with hps proprietary boot configuration files which must be present for hardware to be recognized by system bios.
Dec 31, 2016 | HP Computers & Internet
Hi ive got a HP Pavilion dv6000 laptop with a black screen ,i have tried a external monitor and i have checked the ram but still black screen ,the lights are on and the fan is running..please help
Just try to power cycle the unit by removing all power sources (battery, ac adapter) and pressing the power button for at least 15 seconds. If this will not work and you did not get an image from the external monitor, then you need your motherboard replaced.
Good luck.
May 19, 2011 | Computers & Internet
Newer HP Pavilion dv6000 turned off while in use and wont turn on
1.Start your computer and see if your hear your fan noise,and cannot see anything on screen then there is problem with your power supply.
2.If you cannot hear your fan noise,and do not see anything on screen,then there is problem with your motherboard
3.if you hear fan noise and can see something on screen,then it is the issue with your hard disk (very less cases)
Mostly it would be the 2nd case that you will have to get your motherboard replaced
Jul 27, 2010 | HP Pavilion dv6000z Notebook
HP dv6000 laptop will not power up
the motherboard has a defective power mosfet on the bottom of the MB beside on the power connector.
Jul 27, 2009 | HP Pavilion dv6119us Notebook
The screen does not show and the power light goes on and off intermitently What could be the problem?
http://www.youtube.com/watch?v=CgTbkTK2iwk&feature=related
Just did this to a HP Pavilion dv6000. It worked.
for viewers benefit:
Initial problem: the notebook wouldn't boot up. when power button was pressed, blue lights will come on and only stayed on for less than 3 sec and then nothing, fan would not be spining plus no noise of hard drive activity. battery was installed and power supply was plugged in.
after watching this and similar videos decided to give this a try. I didn't have any foil paper, used a similar heat gun only heated the gpu for little more than 6 min. right after i pushed the chip ( it was kinda hot) then let it cool down,. put everything back together now is working fine. for everyone out there that tried this and it worked has anyone had additional problems with the repair. thanks.
Jul 11, 2009 | HP Pavilion dv6000t Notebook
Pavilion dv6000 when power button is pressed,
Have you tried to boot the laptop with the power cable connected? Is the charging indicator on when you connect it to the adapter? If the charging indicator does not light up, check if your adapter output and try booting it with the power cable connected.
Jun 19, 2009 | HP Pavilion dv6000t Notebook
HP DV6000 Notebook - Dead/No Post
All I know is wife's did the same and they replaced the board, not repaired it.Hers was out of warranty and they fixed it free
Feb 10, 2009 | HP Pavilion dv6119us Notebook
AUTO SHUT OFF HP DV6000
Youre cpu heatsink is clogged with dust not breathing properly and causing it to over heat and shut down.Must remove keyboard heat sink should be on top right removed heat sink and clean dust .Use air can and spray whole laptop.
Oct 02, 2008 | HP Pavilion dv6000z Notebook
HP 6227 BLANK SCREEN
LINK
The HP DV6000 has problems that HP is aware of. Check to see if yours is eligible for free extended repair.
May 10, 2008 | HP Pavilion dv6000z Notebook
HP Pavilion dv6000
hi
Dude very simple, uninstall the graphic drivers completely and reinstall them.
do give me feedback
bye
yasir sardar
Feb 27, 2008 | HP Pavilion Notebook
Computers & Internet Logo
89 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
