Question about Seagate FreeAgent Pro - 500GB, 7200 RPM, USB 2.0, eSATA, External 500 GB Hard Drive
My computer stopped reading my external hard drive
I have a free agent Seagate 500G External Hard drive. Everything was completely fine... the computer was shut off and I unplugged and removed it from the USB so I could get some pictures off of it to put on my laptop. I plugged it into my new laptop and it wouldn't read the connection and I tried multiple ports on it. I've done this before with my old laptop (Sony V) and never had a problem switching back and forth. Since it wouldn't read I tried to plug it back into the desk top computer and now it won't read it. There is power going to it because the light is on and I can feel and hear it trying to process something like its working, I switched out the USB cable going to the computer and tried multiple ports. I even took a flash drive plugged it into a port and it showed up immediately on the computer and then tried to plug my external back in the same one and it wouldn't work. So the computer reads other devices put in the same port but not my external. There is power going to the external, all connections are secure, its not the USB cord so I ithink its the hard drive itself... how can I get all of my files off of it or get it to work?
Thanks, kim buzzs and squeeks. does not sound like the drive is spinning
Try the drive in a different USB port. If it still fails try another computer. If it still fails then it's possible the drive is bad. If the warranty has expired you may be able to find a tech savvy friend to remove the actual drive from the case and hook it up to another computer directly. If it recognizes fine then the case is bad. If it does not recognize the drive then the drive is dead.
You won't be able to retrieve the files on the drive unfortunately unless you use an extremely expensive service. These tend to run in the hundreds of dollars.
Posted on Nov 22, 2008
I have a 500 GB Seagate portable external hard drive model 9ZA2AH-500. It was working fine untill yesterday. Now when I plug it in all I get is a faint beeping sound Then it stops. I have tried plugging it...
It may be the interface that has failed but I suspect the hdd has failed.
Take the hdd out of the case and fit another drive. If that one is OK the hdd is dead. If it doesn't work, try a new usb to SATA interface.
Sep 25, 2017 | Seagate Free Agent Go Small 12 GB USB...
My computer cannot detect my external drive(500gb seagate)
Okay the problem could be either with your computer or the external drive the first thing you need to do is try the external drive on another computer a friend's or someone's and see if it shows the files if it does not show the files on an another computer as well as your current computer then I suspect the problem is with the drive this is common especially if these drives have dropped or taking a file or gotten old if the drive is clicking and not spinning that's a big problem if the drive is spinning and you can hear it spin but it's not showing up on the computer there may be a different issue you may need to look towards data recovery for that external drive that's the best I can tell you at this time and based on the information you've given best of luck
Jan 24, 2018 | Seagate Free Agent Go Small 12 GB USB...
We have the seagate free agent and don't know where to go to drag our items from main hard drive to the seagate
Double click on My Computer expand the "C" drive / minimise and simply drag from one drive to the other.
Dec 23, 2009 | Seagate Free Agent Go Small 12 GB USB...
Dropped my1TB EXTERNAL Seagate drive, now not WORKING
Probably nothing. Hard drives are delicate machines seeing as th have microscopic lasers that are held by a tiny little arm between the discs. If it fell hard, so will all your DATA
Dec 19, 2009 | Computers & Internet
How do I install my seagate freeagent external harddrive into my macbook? my computer keeps asking whether I want to erase everything on the hard drive first. I'm afraid it will erase any software that...
the soft ware that comes with it will also be erased, as it is a windows based identification,seagate free agent has mac utilities on its site, try to find out on www.seagate.com. you will find one for mac format and mac installation .
Dec 02, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
I have a Seagate External 500g hardrive and I need to down load the mac driver. My computer is a Mac Book Pro 15". Can you tell me how to do this? It says on box to go to www.seagate.com but I can seem...
I called apple about this and they said there is no mac driver, that a mac should read a seagate external hard drive without any driver. My file system was ntfs.
Sep 15, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Seagate free agent pro 500 gig external hard drive NOT RECOGNIZED
You better check with the Seagate people. This seems to be a problem with the casing. And since you're under warranty, you can get a replacement.
Aug 28, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
I reformatted my C: drive and ever since Windows will not recognize my Seagate External Free Agent hard drive. It shows up under ?My Computer? as Removable Disk (I: )? It used to be listed as Seagate...
Try connecting it to another computer. If you can see your data then back it up etc.
After you have recovered your data connect it to your computer, from Disk Manager, remove the partition, recreate it again and then format the drive, hopefully your external drive will be operational again.
There is a possibility that the hard disk has died and you will have lost your data. If you are desparate, hard drive data recovery companies charge an arm and a leg to recover data from dead drives.
Jan 10, 2009 | Seagate Free Agent Go Small 12 GB USB...
Help for Seagate Free Agent 500 GB external hard drive
465.66 x 1024 x 1024 x 1024 = 499,998,617,764 bytes. The problem is the definition of gigabytes.
May 10, 2008 | Seagate Free Agent Go Small 12 GB USB...
Seagate FreeAgent Pro - 500GB, 7200 RPM, USB 2.0, eSATA, External 500 GB Hard Drive Logo
250 people viewed this question
Top Seagate Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
pankaj rautela
pankaj rautela
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
