RCA HDTV R52WH74YX61 blown fuse
Hi I pulled the blow fuse and went to radio shack to try and replace it no luck
The fuse says .6a/125v and P233
It has some symbol F. before the 6a not sure if this is . 6 or 6amp
could not find either one at radio shack any help with alternitive fuse ?
Thanks
Jeff
  • Jeff Costello Nov 23, 2008
    Hi
    Thanks for the info
    The .6a fuse was fried black as coal
    I replaced it with a 1.0a just to try it it cooked as soon as I plugged in the set
    is thefl231 in the same location as the .6a fuse?
    thanks
    Sergeant:
    Champion:
  • 346 Answers
There are 3 small red rectangular shape objects to the right of the flyback transformer these are fuses the fl231 most time goes bad .fl231 is the location number under the green circuit board. the location number can also be wriitten on top(brown side of the cicuit board)
you may have to put back the .6a you took out was it ok?
TRITRONIC ELECTRONICS sell parts . cathray 416 241 1106 sells also
Posted on Nov 23, 2008
How do you test a fuse
How do you test a fuse?
• for RCA FL231
(400ma, 125V) +40V Supply Power Supply/Deflection PCB
OEM RCA FUSE RCA259213 FL231 400MA 125V 3960400000 ...
• for
FL221 (1.25, 125V) -13V Supply Power Supply/Deflection PCB
FL251 (1.25A, 125V) +13V Supply Power Supply/Deflection PCB
FP400 (6A, 125V) AC Input Mains Input Doubler PCB
FP602 (1A, 250V) DVD Power Supply Mains Input Doubler PCB
here are some links to guide you:
http://www.electronicrepairguide.com/how-to-test-a-fuse.html
http://www.dinosaurelectronics.com/Test_Fuse.htm
hope these helps,
thanks for choosing fixya for assistance!
Aug 25, 2012 | RCA HD52W59 HDTV Projection Television
I went to Radio Shack to buy my open 6.3 slow-blow
Yes you can try it,Go to this website Mats Electronics they list all kinds of Parts/Supplies
1-800-628-1118
Apr 28, 2010 | Panasonic CT-36SX12 36" TV
Tv problem with a fuse
Your degausing thermistor is bad and needs to be replaced. The part number is D4DDF1R50001
Once that is replaced put a new fuse in put the set back together and you should be good to go. You will need to replace the fuse with the correct size and its part number is
XBA2A00101F
Sep 10, 2009 | Panasonic CT-36SX12 36" TV
Panasonic ct-32sl13g blowing fuse by power supply
You will need to remove the back of the TV. Don't worry, it's not that bad.
There are 4 screws across the top, one on each side, one right next to where the power cord goes into the back of the case, and the two more by all of the video connections **These are the most important to remove because they attach the main board to the back of the case.
Once you have remove the screws then the entire back of the set will slide off. If you look where the power cord attaches to the board you will see a small fuse. This is a 6.3 Amp 125 volt fuse. You can replace it with a 6.3 Amp 250 volt fuse from your local Radio Shack. A four pack costs between $3 and $5.
Make sure that you check that it works before putting it all back together. Check for any loose connection cables while you're back there. I found a few when I did this.
Apr 15, 2009 | Panasonic CT-32SL13 32" TV
Sony str-de845 Powers up, relay clicks, fuses BLOW!
This condition, may be produced by defective components (Q506, Q507). you can remove those transistor, replace the fuses, power-on and wait for relays click. if the fuses not blown again, them replace both transistor.
Mar 05, 2009 | Sony STR-DE845 Receiver
No Power on rt2580
According the parts list on the model unit your fuse is suppose to be F101,FUSE 6A 125V. Is it possible that you have an undersized fuse?
I don't believe that one amp differents would cause your unit to blow like that but, you never know. More than likely you have a bad component in the power supply or power amp.
Then again, with an average replacement cost of $150 online; it not worth getting too deep into the repairs.
Jan 29, 2009 | RCA RT2500 System
NO POWER rca hdtv R52WH74YX61
if the fuse you took out at first was fried black as cool, how do you know it was .6a
now the fl231 as I told you before is close to the flyback transformer
Go to google search -type in flyback transformer --enter
scroll down to get video results for flyback
click on the picture
now you will see what a flyback looks like
you should not try to fix tv if you have no idea of tv repair.it is very cmplicated and fatal .there is serious high voltage in tv sets
Nov 23, 2008 | Televison & Video
6.3a slow-blow 125v fuse
Hi, If the fuse physically fits into your unit then it will work. However- - - WARNING! Although 6.3 amps on a 250v fuse will allow the current to flow it will not afford you the circuit protection you require for a 125v circuit. If the circuit develops a fault then there is a danger that you burn out the circuit before the fuse. As you have already blown one fuse I would suggest tracking down the fault before you do any thing else.
The Scrivener.
Oct 12, 2017 | Pioneer VSX-D458 Receiver
It will work, the amp rating is most important, 125v / 250v does
not matter.......note: if you blow the fuse again, the TV will
need service.................T.
Dec 08, 2007 | Panasonic CT-36SX12 36" TV
6.3 slow-blow fuse
Important parameter is 6.3 amp slow-blow,voltage rating = 125v
or 250v OK, No Worries.............................T,
Televison & Video Logo
241 people viewed this question
Top Televison & Video Experts
Electro Med Services...
