Question about Canon PowerShot SD400 / IXUS 50 Digital Camera
Dropped SD400 Hi, I dropped my Powershot SD400 from 1-2 feet and now it is not turning on at all. It does not do anything, not even light any led, make any noise, nothing. Drop was not that high, so we hope that it may be something easy to fix. Can you help me ??? Thanks a lot Rafa
I charged my battery to full again after it won't turn on afte a drop. worked after that. (full charge again) the drop must of drain the voltage in a short instant or something
Posted on Jun 11, 2007
  • 3 Answers
First thing, make sure that the battery is making contact in the camera. Sometimes small bumps can break the (typically) plastic locking mechanism that holds the battery in. If that is not the problem, then the fall probably jarred something loose internally. My guess would be a connection between the battery and the main circuit board has broken off. Unfortunately, if this is the case, you're probably looking at a pretty expensive repair. You can probably either send it in to Canon (should be information that came with your camera on where to send it), or take it to a local camera store that may repair cameras or know of a place that does fairly locally. I see that this camera came out about a year ago, so your reaching the point where it might be cheaper to buy a new one (typically closer to 18 months). You'll have to do some research to decide this for yourself (I trust cnet.com for reviews, and no, I'm not in any way affiliated with cnet) One other note, occasionally when we send cameras out for repair to the companies, if there's no visible damage, then they will sometimes repair it under warranty, and then the person is only charged shipping to send the camera out. Not saying it'll happen for you, but you might get lucky. Good luck, and I hope it works out for you.
Posted on May 22, 2007
Dropped Canon PowerShot into salt water
You're not going to like my answer. Salt water is very corrosive. Once it gets into a camera, even if you allow the moisture to dry out, will continue to corrode the camera and lens elements. Repair shops will not even touch a camera that has been dropped in salt water.
Oct 24, 2011 | Canon PowerShot SD400 / IXUS 50 Digital...
Dropped it on carpet while it was on and now it won't do anything, dead
..same deal here, except it was a concrete floor and I was drunk. It landed right on a corner. Later, taking it apart nothing seems broken or bent, yet not even the green LED indicating power will come on. Best of luck
Jan 04, 2010 | Canon PowerShot SD400 / IXUS 50 Digital...
Camera dropped in snow
Where on earth do you find snow this time of year ? If moisture has got inside the camera, chances are it's ruined, I'm afraid.
May 22, 2017 | Canon PowerShot SD400 / IXUS 50 Digital...
Camera problems
I have the same problem. i dropped it once and now every time i take a picture its all blurry. what can i do???
Oct 13, 2008 | Canon PowerShot SD400 / IXUS 50 Digital...
Dropped SD400 - buttons no longer work
Not only is a repair shop your only option, you'll probably find it will cost nearly as much to fix than to buy a more recent model.
There are three really weak spots in the SD400 and most small digital cameras: the lens mechanism, the battery door, and the built-in lens shade. Care in closing the battery door so you don't break off the little lugs that hold it shut - using a neck strap so you don't drop the camera - and making sure no sand or grit gets into the lens cap mechanism will make your next camera last a lot longer.
Jun 26, 2008 | Canon PowerShot SD400 / IXUS 50 Digital...
Won't Even Turn On
Here are some simple things to try first for a camera that won't power on. They won't work for every case, but they're worth a try:
http://camerarepair.blogspot.com/2007/11/simple-fix-for-dead-cameras-that-wont.html
Feb 16, 2008 | Canon PowerShot SD400 / IXUS 50 Digital...
Camera Will Not Turn on
take it back to the store and confirm them
Dec 24, 2007 | Canon PowerShot SD400 / IXUS 50 Digital...
Dropped camera-two corners dark
Check what the actual pictures look like when they are downloaded to PC or to print. The problem may only be on the screen. It may be very expensive to replace the screen, but you might be able to live with it?
Good Luck
Oct 25, 2007 | Canon PowerShot SD400 / IXUS 50 Digital...
LCD Screen Color is Washed Out and Blue
Hey i found this site that is great on how to change a LCD for the camera
http://digitalcamerarepair.googlepages.com
Sep 25, 2007 | Canon PowerShot SD400 / IXUS 50 Digital...
Canon SD400
its very eas to fix this one..
just use a small screw driver and open it up..
its possible that the gears were just misaligned.
got mine fixed..
Canon PowerShot SD400 / IXUS 50 Digital Camera Logo
54 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Doberman
Are you a Canon Camera Expert? Answer questions, earn points and help others
