Question about Star Logic 17" LCD Monitor
Montior will not come on
I shut down computer, turned off monitor then went to turn it back on after I turned computer back on but monitor would not come on. I checked every wire and connection nothing loose or unplugged. I unplugged every connection and re-plugged it all and still nothing.
  • Anonymous Nov 26, 2008
    I have the same problem.
  • Anonymous Apr 09, 2009
    same problem but my LCD screen drive isnt working as well? what does that mean?
  • 558 Answers
Internal board on the lcd has blown capacitors you will need to replace those on the power board to bring the monitor back up.
Posted on Dec 03, 2008
I have a motororola model MBP8 PU babby montior quick working after power went out they turn on but but don't work
Is it plugged into a surge protector? When the power comes back on to a lot of residents at the same time, a power voltage spike occurs that can damage electronics. All items that have any electronic circuits, need to be protected by a surge protector. Surge protectors do not protect against lightning strikes.
Jun 04, 2014 | Computers & Internet
My hp pavillion mx 50 montior dosent turn on and if it does the green light on turns to an orange what to do to fix it
Check your Monitor Cable at the back of your PC unplug it and chec for bad pin conection make sure your Monitor cable are plug in correclty....
Oct 01, 2010 | HP Pavilion MX50 15" CRT Monitor
Computer monitor wont turn on when you hold the power button a small orange light turns on. What is wrong?!
CONNECT THE MONITOR DIRECTLY TO THE WALL OUTLET
CHECK WHETHER YOU GET CHECK AUDI SIGNAL OR NOT OR ANY MESSAGE---HTEN CHECK FOR THE CABLE---IF STILL THE ISSUE PERSISTS CHECK IT WITH A DIFFERENT CABLE---
THEN CONNECT IT TO THE COMPUTER MAKE IT SURE THE COMPUTER IS TURNED ON AND THE POWER IS GIVEN TO THE MONITOR AS WELL----CHECK THE COMPUTER WITH ANOTHER MONITOR---IF THE OTHER MONITOR IS WORKING FINE THEN CONNECT YOUR MONITOR TURN IT ON AND THEN FLASH A FLASH LIGHT OR TORCH LIGHT AND THEN SEE IF YOU CAN SEE A DISPLAY INSIDE..
WHILE CHECKING FOR ALL THESE STEPS YOUR ISSUE WILL BE RESOLVED IF NOT TYOU GOTTA CONTACT THE MANUFACTURER FOR A FAULTY MONTIOR---
STEPS IN BRIEF:
DO A MONITOR SELF TEST
CHECK FOR THE LIGHTS
CHECK FOR THE CABLE
CHECK FOR THE PHYSICAL SIGNAL
PUT THE MONTIOR ON A DIFFERENT COMPUTER AND CHECK
CONNECT THE COMPUTER WITH A DIFFERENT MONITOR AND CHECK
FLASH A FLASH LIGHT AS A LAST STEP TO SEE A DISPLAY
IF THE ISSUE IS NOT RESLOVED THE MONITOR IS FAULTY..
HAVE A NICE DAY!!!!
Jun 22, 2010 | Gateway FPD1975W 19" LCD Monitor
Montior screen is half shaded and half bright
Do this to check if your monitor is in working state or not...!
Step 1:- Turn on your computer.
Step 2:- Unplug the Video Cable of your monitor which is connected with the computer.
( Video cable:- Cable going from the back of your monitor to the back of your tower. It has a plug with two screws on the plug ends, which you can unscrew to unplug it. Thats how it looks like. Some times it is in grey in color some times in blue.)
Step 3:- Now check on your monitor. If the display says " No Input Signal " :- your monitor is fine. Some thing wrong with the computer graphics.
If there is not display and the monitor light is blinking or solid the monitor has gone bad.
( Note :- Remember when you unplug the video cable do not unplug the power cable of the monitor. )
Let me know if it helps.
May 18, 2010 | Computers & Internet
How to disable the resolution notice on VG930m
Use your monitor buttons to look for Resolution Notice and turn it off.
To disable the notice on ViewSonic 23" LCD Monitor , use the buttons on the
front of the montior to do the following:
* Press #1 button
* Use down arrow to highlight Setup Menu and press #2 button
* Use down arrow to highlight Resolution notice and press #2 button
* Select Disable and exit!!
To disable the notice on NEC LCD 1765 monitor
* Press button #5 on the monitor
* Scroll up and down the menu list with Montior Button #4 and then select
with Monitor Button #5. Go to "Advanced menu" set the Resolution notice to
OFF.
Nov 02, 2009 | ViewSonic Computers & Internet
Monitor won't turn on
I'm assuming you mean that you've tested the computer using another monitor and that the desktop proved to be working fine. If that's the case then the monitor needs to see a reputable repair person for repair.
Apr 04, 2009 | LG L204WT 20 inch LCD Monitor
Montiors shut off
if the monitor goes into standbye when you plug it into the computer , it generally means there is NO signal coming from your video adaptor.
Plug the old monitor in , if it works, ide suspect the new monitor(s) are not working correctly.
if it doesnt work , you need to restart the computer in safe mode by repettitively tapping the f8 button as the computer starts, before it says "starting windows".
If you have a signal on your monitor in safe mode, then most likely you have a bad or corrupted video driver and it will need to be updated.
if you have no video in safe mode , you will need to remove the cover and physiclly check that all add-in card power cables and memory chips are squarly seatied in there slots. MAKE SURE YOU UNPLUG THE COMPUTER AND DISCHARGE ANY STAIC BUILDUP IN YOURSELF BY GROUNDING (TOUCHING) SOMETHING METAL BEFORE YOU TOUCH ANYTHING INSIDE THE COMPUTER.
AFTER YOU CHECK THESE THINGS AND TRECONNECT THE POWER AND TRY TO START......POST AGAIN HERE
Feb 18, 2009 | Systemax Venture PC Desktop
THE ACER MONITOR AL1711 BLINKING IN DIFFERENT COLOURS AFTER THE COMPUTER IS SHUTDOWN - TO STOP IT I HAVE TO REMOVE THE POWER TO THE MONITOR OR BEFORE SHUTTING DOWN I HAVE TO PUT THE POWER OFF FROM THE...
I just had this problem at work and what I did was I powered up the computer and went into the menu. I went to the 2nd to last button and selected the reset. It's working perfectly now. I do not know if it will last but it's easy and free.
Jan 23, 2009 | Acer AL1711 17" LCD Monitor
The montior shuts off and on
If it is doing this during normal use, try using the little control buttons on the monitor itself to navigate through its configuration menu and try to find anything about screen savers, power saving, shut down, anything like this, and disable it all. And set everything else to AUTO if available. :>)
Nov 13, 2007 | Samsung SyncMaster 930B 19" LCD Flat Panel...
Monitor turns it self off
exact same thing has happened to me. I have been told it's some part which often burns out on lcd's which can be replaced easily...
Sep 18, 2007 | BenQ FP91G+ 19" LCD Monitor
Star Logic 17" LCD Monitor Logo
205 people viewed this question
Top Star Logic Computers & Internet Experts
Jerry Greenberg
Jerry Greenberg
scj103
Fernando Torres
Fernando Torres
Are you a Star Logic Computer and Internet Expert? Answer questions, earn points and help others
