Question about Lite On LITE-ON SOHC-5236V COMBO BK OEM (SOHC5236VBKOEM) Burner
Drive doesn't play CD-ROM but plays DVD games...
I've had my computer a few years now and nothing has gone wrong with the cd drive...Until now, it doesn't reconize any sort of CD-ROM Disks but will reconize DVD's. I have tried uninstalling the drive and letting windows install it again and the problem still exists, If anybody knows how to fix this problem then i would very much appreciate it. Thanks
  • 1 more comment
  • Anonymous Dec 08, 2007
    SOHC-5236V
  • Anonymous Mar 11, 2009
    Cannot play CDRom
  • Anonymous Mar 30, 2014
    i have blank cd in drive. i use Nero for making cd's . the computer shows the cd in drive but when i try to burn a disc it's not reconizing the cd
  • 22 Answers
1. go to device manager / right click on cd drive / uninstall driver / reboot and windows will reinstall driver 2. go to My computer right click on cd drive properties - check digital cd playback recording - check enable cd recording on this drive driver - update or uninstall reboot your computer
Posted on Feb 01, 2007
My BD-ROM drive doesn't seem to be working?
Click start control panel administration tools computer management device manager scroll down cd-dvd rom drives you might see a yellow question /exclamation mark ? ! or a red X right click to update driver
you might have to physically unplug the leads for this cd/dvd restart your computer then plug them back this should activate the found new hardware wizard
if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope this helps
if this fails to fix the problem
It could be a problem with the lens you could use a liquid type lens cleaner place 2-3 drops on top of a cd/dvd then run it
Sep 10, 2012 | HP Pavilion Elite M9150F Desktop PC
My CD rom is not working
No matter what type of laptop you own or how you use it, the CD-ROM or DVD drive is an important part of the unit. With the CD or DVD drive in place, you can play your favorite music or watch your favorite movies, so when that CD or DVD player stops working it is important to get it back in service as soon as possible.
1.Locate the bypass hole on the CD-ROM drive. There is a very small hole, generally located underneath the eject button, on every CD-ROM drive. Unbend a paper clip and insert it into the hole until the CD tray pops out.
2.Remove any CD that is in the tray and replace it with a CD laser lens cleaner. These laser lens cleaners are available at computer shops and electronics retailers.
3.Run the laser lens cleaning program, then try to play a CD again. If that CD fails to play, replace it with another CD and try again.
4.Shut the computer down and remove the AC power cord if cleaning the laser lens does not resolve the issue. Turn the laptop upside down and slide the battery release lever to the unlocked position.
5.Remove the battery and set it aside. Then locate the screws that hold the CD-ROM drive in place and remove those screws. Slide the CD-ROM drive out of the bay, then slide it back into the bay until it snaps securely into place. Replace the screws that hold the drive in place, turn the laptop back on and try to read the CD again.
6.Log on to your computer and right click on the "My Computer" icon. Select "Properties" from the menu and click on the "Hardware" tab. Click the "Device Manager" button and expand the CD-ROM section. Right click on the CD-ROM and choose "Update Driver" from the menu to download and install the latest device driver from the CD-ROM manufacturer.
I hope you find it very helpful. Thank you for using fixya
Aug 18, 2011 | Lenovo 3000 Y410 Notebook
CD-ROM drive doesn't acknowledge DVD-ROM, what's wrong?
CD-ROMs dont play dvd becuase they are not designed to read dvd.
If a dvd drive for your model is not available, you can buy an external usb dvd drive.
That should solve your problem
Dec 28, 2009 | Dell Dimension E521 PC Desktop
Emachine W6409. will play cd. will not play dvd.
sounds to me like you have a cd-rom drive and not a cd-r/dvd rom drive? are you sure it is a cd-r/dvd rom drive? If its not it won't play DVD's because CD drives use a different codec than DVD rom drives do. CD-r/dvd drive combos use the same codec though as one.
Jun 06, 2009 | E-Machines emachines (emachinees) CD-ROM...
When I try to play DVD, nothing happens.
change the lens of DVD. its a common problem. due to over use.
May 31, 2009 | LG GCC 4520B CD-RW/DVD-ROM Burner
My computer dont want to play dvd
Well, you need a DVD-ROM not a CD-ROM. If you have a CD-ROM and it's not playing then it's because you need a DVD-ROM and it's not working then I don't know, sorry! From Jake @ Dudey-Dreamz.piczo.com
Feb 23, 2009 | E-Machines emachines (emachinees) CD-ROM...
Dell Inspiron 4100 won't play dvd, but will play cd's
You have problem with your cd-drive's lens.
May 20, 2017 | Dell DVD-rom DVD Drive
Lite on cd/rw/dvd rom (SOHC-5236V) fails to read dvd's
your dvd lense might be dusty OR laser might have became weak
try upgrading FIRMWARE
Jan 31, 2009 | Lite On SOHC-5236V CD-RW/DVD-ROM Combo...
Sony Vaio pcg-frv37 dvd rom not working
you need a DVD burner in it to play and Burn DVD's
you have a CD Rom in it now.
Dec 17, 2007 | Sony VAIO FRV37 Notebook
Lite On LITE-ON SOHC-5236V COMBO BK OEM (SOHC5236VBKOEM) Burner Logo
198 people viewed this question
Top Lite On Computers & Internet Experts
Bill DeLisi
Bill DeLisi
paul shaw
Level 1 Expert
Damen Wong
Damen Wong
Are you a Lite On Computer and Internet Expert? Answer questions, earn points and help others
