Question about PNY 4GB USB 2.0 Flash Drive - Grey/Black
Need Windows ME Driver for PNY USB 2.0 Flash Drive Attache
I have a PNY 4gb USB 2.0 flash drive Attache. My Vista system found drivers and installed them on the Vista system. My Windows ME system can not find any drivers to use for this device.
    Scholar:
  • 35 Answers
Here's what you can do,
Download the files using the these links,
http://www.usbman.com/WebDrivers/WinMe%20Sys%20Files/usbauth.sys
http://www.usbman.com/WebDrivers/WinMe%20Sys%20Files/usbhub.sys
http://www.usbman.com/WebDrivers/WinMe%20Sys%20Files/usbmphlp.pdr
http://www.usbman.com/WebDrivers/WinMe%20Sys%20Files/usbntmap.sys
http://www.usbman.com/WebDrivers/WinMe%20Sys%20Files/usbstor.sys
http://www.usbman.com/WebDrivers/WinMe%20Sys%20Files/usbui.dll
Put all these files in one folder and when windows ask for the drivers, select the option to manually serach for the drivers. And point the search to the folder where you saved these files and it should fix the problem.
If this does'nt work, please let me know.
Posted on Nov 26, 2008
PNY Attache flash drive not being recognized
click start control panel administrative tools computer management device manager scroll down universal serial bus controllers you could see a yellow question / exclamation mark? ! or a red X
you will need to update/reinstall drivers
right click to reinstall drivers
if you can see your usb drive but its not working
ports (com&lpt) right click update driver if this fails to fix the problem
check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems for a computer and its parts
if you need more help with this post a reply
hope this helps you
Sep 15, 2011 | PNY 4GB Micro Attache USB 2.0 Flash Drive
Windows XP home edition not regonising PNY pendrive micro attache 2G
control panel admistrive tools ,computer management ,device manager scroll down universal serial bus controllers you should see a yellow question mark?
right click to reinstall drivers or
if you can see your usb but its not working
ports(com&lpt)right click update driver
Dec 27, 2010 | PNY 4GB Micro Attache USB 2.0 Flash Drive
Need driver for pny mini attache 2.0
Here are a few possible sources for your driver software :
http://en.kioskea.net/guide/905619-pny-pny-mini-attache-4gb-usb-2-0
www.paretologic.com/lp/drivercure
http://www.helpdrivers.com/ingles/listado/panel.asp?marca=PNY&perif=otros
http://driverscollection.com/?V=PNY&S=48
try these sites they should provide you with success
Jan 04, 2010 | PNY 4GB USB 2.0 Flash Drive - Grey/Black
I have a 4GB PNY SDhc card in a Targus reader which supports hc cards, but my windows vista won't read it.
It is your windows vista. Vista had trouble with that, when it first came out. Try going to your computer manufactor's website and there should be a driver for vista.
Dec 16, 2009 | PNY 4GB USB 2.0 Flash Drive - Grey/Black
NEED DRIVER FOR PNY 8GB USB ATTACHE
If you're using the drive on a PC with Windows XP or Windows Vista, you don't need a driver - just plug it into the PC and Windows will recognize it and install USB drivers automatically.
Dec 07, 2009 | PNY 8GB USB 2.0 Flash Drive - Blue/Black
IS there a driver for the PNY 4gb USB 2.0 black (and red) memory stick?
Hi
USB memory sticks do not need a driver, it comes with windows, unless you have a really old pc with windows 98 or similiar.
Oct 12, 2009 | PNY 4GB USB 2.0 Flash Drive - Grey/Black
4GB Attache flash drive says it's locked.
Plug in the stick. wait for it to come up on the desktop then click on it once. (do not open it).
From the file menu select "Get Info"
In the panel that opens up you will see a row of coloured squares. Underneath is a checkbox marked "Locked"
Is it empty or ticked?
If it's ticked, untick and see what happens in disk utility. If it's not ticked that then would appear to be a problem with the stick.
For what it's worth, I did a google on this stick and found that there are numerous posts about it becoming read only on Vista, so it may well be a problem with the manufacturer.
Sep 07, 2009 | PNY 4GB USB 2.0 Flash Drive - Grey/Black
Drivers
Go to ADD HARDWARE and try to force the install.
Just so you know, Optima Pro Attaché USB 2.0 Flash Drive was designed with Windows Vista in mind, and works in conjunction with new SuperFetch (intelligent caching) to enhance system performance for quicker startup and windows multi-tasking.
But it's also compatible with most PC/MAC laptop and desktop computers with available USB 2.0 port (Backwards compatible to USB 1.0).
Jun 30, 2008 | Computers & Internet
Optima attache
You may need to uninstall your USB port drivers thru the Windows Device Manager and reboot . Windows will see your USB ports when it restarts and reinstall the drivers which will include support for flash drives including Pny flash drives.
Jun 20, 2008 | PNY Technologies GeForce 6200 128MB AGP...
Flash Drives
Try to use a new Computer having Windows Vista, Dual core, 2 Gb RAM, and at least 160 Gb Hardware.
Your problem is solved.
He! Ha Ha Haa Haaa!
Jan 25, 2008 | Electronics - Others
PNY 4GB USB 2.0 Flash Drive - Grey/Black Logo
673 people viewed this question
Top PNY Electronics - Others Experts
john milligan
Are you a PNY Electronics - Other Expert? Answer questions, earn points and help others
