Question about Dishwashers
Whirlpool dishwasher DU1145--need reset codes to restart machine
It will not start at all. All the water did not drain out. I already checked drain hose/disposal. No clogs.
  • dave_will889 May 02, 2009
    acts like it has no power, no buttons work or lights, didn't complete drain cycle.
  • 3 Answers
Reset code: Push 1. Heat Dry 2. Normal 3. Heat Dry 4. Normal
Posted on Dec 22, 2010
On my whirlpool dishwasher du1100xtp when i push the start. it starts the drain mode. it will not start anything else. i checked the draining of water and its all good. i cleaned everything out too. ...
Most machines enter a drain mode when initially started. Then it will pause and then open water valve. Could be water got turned off or you have a bad water inlet valve. Do you know how to check voltages or use a multi meter
Feb 01, 2015 | Whirlpool Dishwashers
Du1145 will not work
frist turn power off to diskwasher then back on see if the button start working if none the button will not work you made need replace the touch pad,some model come with the control panel all in one some are separately.
Dec 23, 2017 | Whirlpool Dishwashers
Whirlpool 7540 start light flashs 4 times
The #4 error code on your dishwasher says it's a drainage error and that the computer didn't detect that all the water drained out of the machine. Sometimes that can be caused by a blocked filter on the pump, a blockage in the drain hose or a water level switch failure...also it can be just a electronic anomalie and the board can be reset then the dishwasher will work as normal. Or of course it could be because the filter is clogged and needs to be cleaned so water will flow through it and drain out.
I have written tips both covering how to clean the pump filter and resetting the control board,refer to them and see if they will resolve your dishwasher troubles.
TIP FOR CLEARING THE ERROR CODES FROM THE BOARD
http://www1.fixya.com/support/r10357661-get_whirlpool_dishwasher_start_when
TIP TO CLEAN THE PUMP FILTER
http://www1.fixya.com/support/r10292354-whirlpool_kitchenaid_kenmore_diswasher
GENE
Sep 28, 2011 | Whirlpool Dishwashers
I have a whirlpool DU1145 dishwasher that seems to be stuck on the same cycle. It shows it as sensing and washing at the same time and never shuts off. HELP! WHat could becausing this??
Sounds like your Touch Pad on the Control Panel is defective.
You can try and remove the 120 Volt AC power from the Dishwasher by turning it off at your Main Electrical Power Panel with the Circuit Breaker (15 or 20 amp) labeled: Dishwasher .
Leave the Dishwasher turned "Off" for 10 minutes. This will allow the control circuits on the Dishwasher to reset. Turn on the Dishwasher and press Cancel and attempt to Drain the Dishwasher. If this works...then try to enter a Rinse Only cycle and if that works... then attempt to enter a Wash Cycle.
If you still have your original problems then you probably have a defective:
(1) Touch Pad Assembly (or possibly a defective)
(2) Electronic Control Module (ECM)
If you need further help, I’m available over the phone at https://www.6ya.com/expert/henry_239f63a136de60f0
Mar 24, 2011 | Whirlpool Dishwashers
Whirlpool model du1100xtpq6 machine will not start clean lite flashes 7 times stops and repeats must be code 7 blinks only drain pump runs when drain/cancel button pushed
Hi, this is an indication that the water did not heat properly. Follow this link to some instructions I put together to help solve this and reset the control so you can use the machine again.
http://www.fixya.com/support/r4628906-flashing_or_blinking_green_clean_light_7
May 08, 2010 | Whirlpool GU1100XTLB / GU1100XTLQ /...
Whirlpool model DU1145 dishwasher won't drain the water at the completion of any of the cycles.
This is due to either the drain pump is clogged/stopped up, or the motor has completely gone out, and needs to be replaced on the unit.
Mar 29, 2010 | Dishwashers
Clean light is flashing du1145 whirlpool dishwasher, will not run
This is a Common Problem. Read the same solution i offered to many Customer's and it actually worked like anything :-
This machine was made by Whirlpool and the flashing clean light is a common error code for them.
If the clean light is the one flashing then your dishawasher could have a heater circuit problem (depending on the age) or this could simply just be water colder than it is used to getting.
Repeatedly press the Heated Dry and Hi-Temp Wash(scrub) which ever yours has untill all the LED lights come on, press cancel twice and try the dishwasher again making sure to run the water at the kitchen sink till it is hot before starting the dishwasher, if this trips and locks you have a problem with the heating element, or temp sensor.
Press the heated dry button followed by the normal cycle button, and then repeat once. You should see all of the lights come on for a second or two, and then the dishwasher will work again.
If you haven't already, take a look under the kick plate in front to see if there is a schematic tucked in there somewhere. Whirlpool has put their diagnostics for specific models on these.
I don't have the specific repair manual for you model.
So, if the above combination does not work here are two more that have worked for me.
HiTemp Wash + Air Dry + HiTemp Wash + Air Dry in less than 5 sec
or
Hi Temp Scrub/Scour + Air Dry + Hi Temp Scrub/Scour + Air Dry in less than 5 sec
Let me know, if you need further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Jan 11, 2010 | Whirlpool Dishwashers
Dishwasher clean light is blinking
indicates a problem with dw not heating the water. various causes. dw should be thoroughly checked, if nothing found wrong, reset computer
Jan 03, 2010 | Whirlpool 24 in. DU1100XTP Built-in...
Whirlpool dishwasher adp550
f4 is a drain error, machine is still sesing water has not pumped out after 4 minutes of draining
1st check and see if water is still in bottom of machine if so check for blockeges under sink where drain hose cnnects to drain pipe.
if water has drained out you may have an water sensor fault or worst case an electronic control board fault
to reset machine hold the start button in for at least 3 seconds and it should do a drain and stop
Feb 19, 2008 | Dishwashers
Whirlpool gu2400xtpt3
I too had Flashing Clean light and only responded to Cancel light by trying to drain. Whirlpool Model DU1145. I too got problem to clear by pushing High temp,Heated dry, High temp and Heated dry. All lights on display lit up then it went through sequences of all cycles.
May 14, 2006 | Whirlpool GU2400XTP Built-in Dishwasher
Dishwashers Logo
925 people viewed this question
Top Dishwashers Experts
Marvin
Marvin
