Question about Fujitsu Siemens MCM 171E (White) 17" CRT Monitor
Multiple colors - on the left side of the screen from top to middle I have a pure red few pixels wide - on the left site too, from middle to the bottom is blue - on the right side from the top to the middle is blue and from the middle to the bottom is normal - on the rest of the screen the image is tripled at 1-2 pixels distance horizontal: first is red, next is normal and above blue. I test with a picture made by hand if one the basic color(red, blue, green) are missing and are not. I try, deguse, don't work and I move the monitor in another position. Thanks a lot.
5 Suggested Answers
SOURCE:
SOURCE: Line on screen
It sounds like the actual LCD is damaged, i've seen some cases where it was a damaged cable going to the LCD screen but if the cable looks ok then it is probably the lcd screen.
Posted on Nov 09, 2007
if you found out how to fix or what is wrong with tv please let me no shanequinn@tiscali.co.uk
Posted on Jul 15, 2008
budmrtn
  • 11361 Answers
SOURCE: Acer monitor color is blueish
Blue cast is more likely to be due to bent pin, loose connections of the VGA cable, look for that first. It can be the video card itself, so try it with another PC also.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Posted on Nov 29, 2010
  • 11800 Answers
SOURCE: on the left side of the screen a bright pixellated
Failure of the circuits from the buffer board that are responsible for those pixel lines You need to replace both buffer board.
Since in this model there have been used several models of boards you will need to open the tv all the way to the screen , extract the boards, read the model number printed on it then order replacements from here
http://www.moduslinkptstvboards.com/Plasma-Boards-C13.aspx?s=Name%20ASC&p=109
Only the bottom boards that correspond to the failed pixel lines will have to be replaced.
Posted on Sep 06, 2011
How do I remove three vertical colored lines from my Television. One vertical line is green another is red and the final one is blue.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
May 24, 2015 | Panasonic Viera Tc-p50u50 Hd Plasma Full...
Vertical lines on screen kinda pixelated
Just check this link. You can see similar type of fault to LCD TVs. Compare them to that of your TVs and make sure. It sounds that the LVDS cable has loose contact with its connection sockets. Re-seat it once, and check.http://electronicshelponline.blogspot.com/ Pull up previous posts there, either by its left side bar, or view it in Timeslide option.
Jul 03, 2013 | Polaroid Televison & Video
Big black square in middle of screen picture top to bottom about 36 " wide good audio and picture 6" on right and left side displaying.
If you have tried using different input devices, looked for loose contacts
in power outlet, RC Jack, cable and connectors, the TV might need service.
Aug 26, 2012 | Hitachi 55HDS69 55 in. Plasma Television
Samsung HPR4272X/XAA has 2 black bars going from top to bottom.
I really do not know there is the "Stuck Pixel Fixer programs" I think that Program Breakdown another IC. For this issue is absolutely the Plasma display panel have problem. You shall exchange it.
Apr 17, 2010 | Samsung HP-R4272 42 in. Plasma HDTV
I have a LG plasma 42PC1D (4 years old). For the
I had the same problem a few months after buying the TV, called LG and they sent a tech to replace two boards in the tv. No further problems since.
Dec 21, 2009 | LG 42PC3D 42 in. Plasma Television
Sony KP-53XBR35 TV Concave top & Bottom in wide screen, along with color distortion around sides
thats usually a convergence IC failure, Are you able to move the red and blue colors in the convergence adjustment menu?
Jul 14, 2008 | Televison & Video
Toshiba regza lcd 46x3500
This is what is known as a dead pixel. If you have a standard wide screen lcd monitor it has over 1 million pixels. It is not super un-common for one to go bad. It will either always be dark or in your case always be lit. It is not worth it to repair, and in most cases unless you have multiple dead pixels with in a square inch of screen, it is not covered under warranty either.
Each pixel is individual and the problem will most likely not spread.
Jul 08, 2008 | Televison & Video
Colors have seperated on top of screen
convergance ic are bad
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
Dec 14, 2007 | Televison & Video
Multiple vertical colored lines on DVD player screen
check this out http://www.techlore.com/forum/thread/12629/
Sep 26, 2006 | Audiovox D2010 Portable DVD Player with...
Fujitsu Siemens MCM 171E (White) 17" CRT Monitor Logo
73 people viewed this question
Top Fujitsu Computers & Internet Experts
Alun Cox
Carlo Barzo
Carlo Barzo
Are you a Fujitsu Computer and Internet Expert? Answer questions, earn points and help others
