Question about LG LFX25960ST Stainless Steel French Door Refrigerator
LFX25960ST Ice maker problem
My refrigerator is about 1.5 years old.  The ice maker stopped making ice the other day.  It was working but it was full and the ice was trying to dump more when it was full so I dumped all the ice to allow it to make new ice.  It is not making any more ice.  I tried to move the wire but it will not move.  I thought maybe it was flipped up so I tried to move it but it will not move either direction.  I don't want to force it but don't understand why it will not move.  Can you help?  What else could be keeping the ice from being made?  There are no error codes and everything else is working fine.  I can also get water out of the door so I know the water is on.
  • steve_tiedem Dec 02, 2008
    I have an LG refrigerator with an Ice maker that stopped working.  You said the I/M is bad but what is the I/M?  How do I know that will fix my problem.  I turned off the ice maker and now the wire will move and when I turn it on the arm moves from down position to the up position and the arms that pushes the ice cubes out cycles around.  Everything seems to work fine except now the ice tray will not fill with water.  when it stopped working the wire would not move.  I thought it had just frozen so I thought turning it off and letting it thaw out would fix it but now it does not fill with water.  When it stopped working there was water in the tray but it would not eject the ice. Now it seems to have thawed and work fine but does not fill with water. What do I need to replace?  Can you help?
    I believe I will need parts.  Can you advise?
    Sergeant:
    Champion:
  • 311 Answers
As long as switch on icemaker is on then your i/m died. It needs to be replaced. I can get LG parts if you need one. Please leave feedback. Thanks
Posted on Nov 28, 2008
I have a GE refrigerator, model TPX24BPDA, that has an ice maker that won't stop making ice! Whatever mechanism that senses when the hopper is full isn't working. I can't locate any sensor either.
Ice Maker Doesn't Turn Off If your ice maker keeps making ice, even when it is full:
1Lift the bail wireto shut off the ice maker, and remove the ice bin. Then, using a screwdriver if necessary, remove the ice maker, clean it thoroughly, and then reinstall it.
2If the problem persists,consider removing and replace the entire ice maker and valve. With this type of problem, you can have it repaired, but it's often wiser and less expensive in the long run to replace the unit entirely.
Oct 05, 2016 | GE Refrigerators
Ice maker stopped working
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
jkkjffkj
Jun 27, 2010 | LG LFX25960ST Stainless Steel French Door...
Ice maker stopped working and how to clean the stainless steel?
For this problem you need tech support. There are many things that can cause this and it needs to be diagnosed by an authorized LG tech. In the long run you will save money and get a quality repair.
Jan 24, 2010 | LG LFX25960ST Stainless Steel French Door...
Ice maker stopped working. The cubes gradually got smaller until it just stopped producing cubes
heatman101
iot47
Oct 05, 2009 | LG LFX25960ST Stainless Steel French Door...
No ice
IPour about 1/2 cup of water into ice maker . If it dumps , replace the water valve . If doesn't dump , replace the ice maker . Also make sure the coils are clean of dust , lint , etc...
Aug 12, 2009 | LG LFX25960ST Stainless Steel French Door...
Ice maker LFX25960ST
3 months old?? warranteed for a year call for service , you bought new so you wouldnt have to fix it!
Oct 31, 2008 | LG LFX25960ST Stainless Steel French Door...
Ice maker not working properly
could be the air damper. try adjusting air control for more air at icemaker.
May 30, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Kenmore Frig 59658692890
ok there's a handle in the ice maker 1 position turns it on another turns it off just do that and the ice should stop coming down if it dosent just remove the water connection to it
Apr 07, 2008 | Amana 22.6 cu. ft. Side-By-Side...
LG LFX25960ST Stainless Steel French Door Refrigerator Logo
497 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Mike
Mike
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
