Question about Bestec (ATX-250-12E) 250-Watt Power Supply
Bestec ATX-300-12EB3 just got a new one...Place back in and no power-up. Green light on back of supply and on mother board.but will no do much of anything else.has all the same plugs....shouldn't there be a 12v output or something. any further input would be great...Thanks, Andy
  • anance Nov 26, 2008
    Green LED on power supply just flashes and computer will not boot.  I tried everything I could think of--swap memory, re-seat cards, different power, etc.
  • 153 Answers
There should be 12v coming from the yellow wire and 5v from red. Open PC and use a multimeter to check the voltage output connect negative probe to the power supply casing and the positive to the red and yellow wires from the molex connectors. If the readings are below the mentioned voltages then the PSU is faulty. Note if readings can be round off to the given values then the output is fine. cheers.
Posted on Nov 27, 2008
My smps is working, but my power is not coming to the mother board
Replace the power supply or have it tested.
Amazon com bestec atx 300 12z You can get a replacement pretty cheap. Most all power supplies can also be tested - Bestbuys geek squad or a small computer repair shop should have the means to test it.
Feb 23, 2013 | HP ATX-300-12Z, ATX-300-12Z Rev. CDR, HP...
There is any different between this mother board p/n 51884327 and p/n 51882625
Take the power supply to a retailer or computer shop in your local area. Pretty standard from what I have found out.
Bestec ATX 300 12Z Rev DDR Replacement Power Supply HP 5188 2625 Have a great day.
Jul 29, 2012 | HP ATX-300-12Z, ATX-300-12Z Rev. CDR, HP...
Bestec atx 250 12z Power Supply - Community power went off today - machine was on when power went off, but now will not turn back on. Now Green light is flashing on back of power supply. Light...
Outages are frequenly accompanied by power surges. It sounds like your power supply got cooked and does not produce enough power to start your computer anymore.
They are inexpensive and are easily replaced. Take a couple of digital pictures of it in your case and then remove it.
Measure the dimensions and go find an ATX power supply that will fit. I recommend that you go up to at least 350 watts. Use your pictures to help you install the new power supply.
If this helps please vote for my solution.
Sep 21, 2010 | Computers & Internet
Power supply light flashing green ,,, tried unplugging mother board still flashes green is it the power supply or the mother board?
Most computer testing facilities will test your current power supply for free. A replacement is very inexpensive to replace. Bestbuy, MicroCenter, small computer shops and buy replacemnent from Amazon.com, newegg.com.. Just make sure you have the correct information for your replacement. The model number on the power supply would be your best bet in most cases. Good luck and have a great day. I buy power supplies as low as $15 dollars Generic
Aug 14, 2010 | HP Bestec ATX-250-12ZD 250w HP Pavillion...
Light on back is soild green but computer does not turn, but if i jump pin 16 and ground i get the power at the plug and computer does power up
that atx connector is faulty it becomes loose because of draw and insert the connector in mother board grips of connector can be tightned by pin the fault may lies in motherboards connector desolder it and replace it
Jan 18, 2010 | Bestec (ATX100-5) (ATX1005B) Power Supply
No power
ok dandan, please tell me you live in nj. I am having the same problem with my puter and did every step you did what is up with this??
Jun 12, 2009 | Gateway Emachine Bestec ATX-250-12E PS...
W2888 emachine just shut down as if it were unpluged
THE LITTLE LIGHT ON THE MOTHERBOARD SHOULD ALWAY BE ON. THE FAN ON THE POWER SUPPLY RUNNING NORMAL OR FAST.
DID YOU ADD ANY NEW DEVICES TO YOUR COMPUTER LIKE UPGRADING THE RAM, VIDEO CARD, NEW INPUT DEVICE.
NEED MORE INFORMATION.
ROD
May 12, 2009 | Bestec (ATX-250-12E) 250-Watt Power Supply
My computer ps is not providing power to the mother board or any of the periphals. It is a Bestec ps the led on the back of the supply flashes very slowly. Any suggestions before I go out and replace it?
Disconnect the ATX main connector, bridge (with a wire clip) the green wire and any black (negative) wire, this should allow you to power up the PSU... now take a digital multimeter and measure the voltages on the 3.3v (orange), 5.0v (red) & 12v (yellow) lines, you will need to place the negative lead off the DMM on any black (negative) wire to achieve this...
If your PSU is off specification ie. more than 5% variance this IS your issue.
FWIW Don't waste your money on another Bestec PSU
Jan 18, 2009 | Computers & Internet
I have an emachine model 3220. The bestec atx power supply has a part rattling round in it. Is it worth me buying a new power supply and if so other than bestec (as I have read bad reports on this item)...
When you say you have no power at all to your computer, have you checked the motherboard to see if you have a green light that comes on? You have to take the cover off and look at the motherboard. If the light does come on, it isn't your power supply. It is the motherboard. Good luck!
Nov 16, 2008 | Computers & Internet
PC not booting
the mother board can have a short and the green light is on, replace the motherboard. when the power box goes bad, most of the time it shorts the mother board out, this has happened to me a few times. Farren
Dec 25, 2007 | HP Bestec ATX-250-12ZD 250w HP Pavillion...
Bestec (ATX-250-12E) 250-Watt Power Supply Logo
586 people viewed this question
Top Bestec Computers & Internet Experts
Allen Lightsey
Allen Lightsey
Level 1 Expert
JonSnell Electronic
JonSnell Electronic
De ice
De ice
Are you a Bestec Computer and Internet Expert? Answer questions, earn points and help others
