Question about Microsoft Windows 98 for PC
HP 1210 c/ps will not print
I have connected the above mentioned printer to my Gateway windows 98 PC. It keeps prompting me that the USB port is not being recognized. Help!!
  • 158 Answers
You will need the usb port drivers for windows 98 and the usb drivers for the printer as the earlier windows 98 had'nt the usb drivers included with operating system an as the new motherboards came about with usb ports then a new in 98 was needed to catter for this that's why you have win 98 first edition and win 98 se edition please chech that you have the driuvers installed for both parts to work.
good luck
Posted on Nov 23, 2008
Not able recognize the usb device for windows 7
If you can, check that the printer is still recognized on another pc. It's possible that the printer is faulty.
If it does work on another pc, then the next step is to try a different USB port on your computer, preferabbly one at the back of the computer, not the front.
Also make sure you have install the drivers before you connect it to your computer.
Apr 05, 2010 | HP PSC 1210 All-In-One InkJet Printer
C4400 scanner printer will not scan to pc.
kindly uninstall the printer driver and software restart the system and don’t connect the usb cable 1st install the driver cd and when it prompt you for connect the usb cable then connect it and follow the instruction. It will resolve your problem.also change the usb cable and the usb port.
Nov 16, 2009 | HP PSC 1210 All-In-One InkJet Printer
Hp psc1210xi all in one with gateway can't print!
install the drivers of your printer again. and change the usb wire if it is to old.thats it.
Apr 28, 2008 | HP PSC 1210 All-In-One InkJet Printer
what happened to the cd which came along with the printer? lost it or is it ot supported for win 98? anyways you wot get the drivers from the internet. you may have to upgrade your pc to win xp, so that you will get the drivers for the same.
thanks and regards
Mar 09, 2008 | HP PSC 1210 All-In-One InkJet Printer
PC power resets w/ HP PSC 1210 plugged in
one of these updates causes a conflict more than likely a microsoft hotfix, try using a different usb port and unplug and plug printer back in
Jan 15, 2008 | HP PSC 1210 All-In-One InkJet Printer
Hp psc 1210 all in one
Please follow the below given instructions to resolve the issue.
Please click on Start >> Programs >> HP >> HP Director.
Click on Settings >> Print Settings >> Printer Settings.
Click on Quality Tab at top of Printer Settings Window >> Set the Paper type as " Plain Paper " .
Click on Layout Tab at top of Printer Settings Window > Set the Paper size that you are using >> Click on Apply and then on OK.
Try Printing, that should resolve the issue that you are experiencing with.
If the issue still persists, try installing alternate drivers by following the below given instructions.
Installing the Alternate drivers:
1. Right click on My Computer, select Explore and then goto Control Panel, and then select Printer and Faxes.
2. Double-click the Add Printer icon. Click Next.
3. When prompted, choose Local, and then click Next.
4. In the Manufacturers list, choose HP.
5. In the Printer list, choose the HP Deskjet 870C printer, and then click Next.
6. Choose the port as parallel port, and then click Next.
7. The printer name should be listed as HP Deskjet 870C Printer.
8. Click No when the "Do you want your Windows based programs to use this printer as your default printer?" message appears. Then click Next.
9. Click No when the "Would you like to print a test page (recommended)" message appears. Then, click Finish.
Configure the alternate printer driver
1. Right-click the HP Deskjet 870C printer icon placed in the Printers window.
2. Select the Properties menu item.
3. Select the Details or Ports tab.
4. Select the DOT4_00x (where the "x" represents any digit) port from the Print to the Following Port list.
NOTE: The All-in-One model number should appear as part of the port destination.
5. Leave the printer identified as HP Deskjet 870C printer, and click the Apply button.
6. Close the Printer Properties window.
If Deskjet 870c is not listed, you may even try with Deskjet 990c or 550c
Hope that above information will work.
Jan 05, 2008 | HP PSC 1210 All-In-One InkJet Printer
Can't print using USB connection
Unplug printer and un install software. Delete printer in printers folder. Restart pc. Install software first and then connect printer. Also make sure your usb drivers is correct.
Sep 29, 2007 | Samsung ML 1210 Laser Printer
Unable to print
If both printers are connected through a parallel switch, be advised that changes on the switch do not take effect until the computer is restarted. Those boxes worked fine under DOS, but Windows does not support them. Connect the Samsung printer to the USB port and make sure you use a good quality cable and not those thin and cheap cables.
Aug 30, 2007 | Samsung ML 1210 Laser Printer
Microsoft Windows 98 for PC Logo
154 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
