Question about Kenwood SIR-KEN1 SIRIUS Radio Receiver
Kenwood KDC-MP2258 and Sir-KEN1
Audio stereo unit intermittently can't find receiver. Re-seating cables and resetting has helped, but doesn't hold.
SOURCE:
  • 132 Answers
SOURCE: My car stereo
In standby hold the menu button down untill menu pops up, the use the up down left right and pushing of the joystick to select clock ans set it :)
Posted on Jul 25, 2008
  • 3 Answers
SOURCE: Kenwood KDC-MP438U "USB ERROR"
IF YOU DID NOT PRESS THE RESET BUTTON NEX TO THE USB PLUG, DO IT. IT WILL REINITIATE THE DEVICE TO THE FACTORY; YOU WILL HAVE TO ADJUST THE CLOCK.
I DID BECAUSE IT WAS WORKING AT FIRST.( PAGE 3 OF THE MANUAL)
CLAUDE
Posted on Jan 19, 2009
  • 18 Answers
SOURCE: ipos nano 3
It will work bu tonly after enabling the aux jack.
Place unit in standby mode then press menu for a second and then goto aux and select it to aux on1
Posted on Jul 20, 2009
Nomodo4u
  • 863 Answers
SOURCE: no lock code for car stereo
Here you go buddy:
http://www.fixya.com/support/r538828-security_unlock_code_kenwood_most_models
Posted on Nov 23, 2009
  • 773 Answers
SOURCE: I have a Kenwood KDC 135 car stereo wont un mute.
behind the face plate there is a little recessed reset button. push it using the tip of a pen or similar. that will fully reset the radio to like it was when you bought it.
Some times head units hicup. this is how you reset it. In most error cases this solves the problem.
Posted on Dec 15, 2009
Looking for a Kenwood KDC X397 owner’s manual? .
Yes of course. See the link
hard copy of this Google Search
KDC-MP238/CR KDC-MP208 KDC-138/CR - Kenwood
manual.kenwood.com/files/B64-3898-00_00_KW.pdf
Translate this page
2 ' KDC-MP238/CR/KDC-MP208/KDC-138/CR. Contents. Before use. 3. Basic Operation. 4. General functions. Tuner functions. Disc play functions. General ... Menu Operation. 10. Menu System. Activating Security Code. Deactivating Security Code. Manual Clock Adjustment. Auxiliary Input Display Setting. Receive mode ...
Kenwood KDC-138 CD Player User Manual - ManualsOnline.com
www.manualsonline.com > ... > Home Audio Kenwood > Kenwood CD Player Record the serial number, found on the back of the unit, in the spaces designated on the. warranty card, and in the space provided below. Refer to the model and serial numbers. whenever you call upon your Kenwood dealer for information or service on the product. Model KDC-MP238/CR/MP208/138/CR Serial number.
KENWOOD KDC-138 INSTRUCTION MANUAL Pdf Download.
https://www.manualslib.com > Brands > Kenwood Manuals > Car Receiver > KDC-138 View and Download Kenwood KDC-138 instruction manual online. Kenwood CD-RECEIVER INSTRUCTION MANUAL. KDC-138 Car Receiver pdf manual download. KDC-MP238/CR KDC-MP208 KDC-138/CR CD-RECEIVER INSTRUCTION MANUAL AMPLI-TUNER LECTEUR DE CD MODE D'EMPLOI REPRODUCTOR ...
Connecting Wires To Terminals - Kenwood KDC-138 Instruction ...
https://www.manualslib.com > ... > Car Receiver > KDC-138 > Instruction manual
Kenwood KDC-138 Manual Online: Connecting Wires To Terminals. To Kenwood disc changer/ External optional accessory (KDC-MP238 only) Fuse (10A) Wiring harness (Accessory1) Power control/Motor antenna control wire (Blue/White) TEL mute wire (Brown) Not Used (Blue) White/Black White...
Kenwood Car Stereo Head Unit Replacement Wiring Harness Plug ...
https://www.amazon.ca/Kenwood-Stereo...Wiring-Harness/dp/B005X273W8 Rating: 4.7 - ‎15 reviews
Kenwood Replacement Stereo 16 Pin Wire harness; Top quality all copper 18 gauge leads. Perfect Fit.Molex type 6 inch long black color; KDC KRC DPX KTS models see the descrition for model compatibility; Kenwood power harness plug 16 pin indash radio and video units; Allows for installation of an aftermarket radio ...
Mar 23, 2018 | The Computers & Internet
Kenwood kdc-x399 troubleshooting
Check Kenwood wiring color code and function against vehicle harness color code and function. They are not always the same.
Aug 03, 2016 | Kenwood Car Audio & Video
Need to remove kenwood kdc 315s stereo to replace my heater unit on 95 civic, how do you remove stereo?
If you remove the outer trim ring look on each side toward center edge you will notice 2 slots one on each side of unit. You will need a set of Kenwood keys to remove the unit from the cage. If you do not have the keys for the unit you will need to take it to a stereo install/repair shop and have them to pull the unit for you.
Hope this helps!
Sep 26, 2010 | Kenwood KDC-315S
I have a Kenwood car stereo model # KDC-MP342U. Protect mode has been activated on it. I found I had a frayed wire on a speaker from window movement and have replaced the wire. When I reset the radio and...
hold down preset 3 & 6 + reset
press preset 1 - shows dc err
press preset 1 - shows dc ok
press preset 2 - shows dc 2-4
press preset 2 - shows dc 2-0
then unit should be ok with eeprom reset
Jul 18, 2010 | Kenwood KDC-MP342U Car CD Player
Dec 15, 2009 | Kenwood KDC-135 CD Player
My car stereo
Jul 25, 2008 | Kenwood KDC-135 CD Player
Kenwood cd receiver KDC-MP436U
Protect:- The speaker wire has a short circuit, or touches the chassis of the vehicle, then the Protect function is activated. Wire or insulate the cable properly and then press the reset button. If the "Protect" code does not disappear, consult your nearest service centre.
Mar 20, 2008 | Kenwood KDC-MP235 CD Player
SAT Radio installation
What you need is the SCC1 (Sirius tuner) and the KCA-SR50 (Kenwood adapter). The ESN number can be found on bottom of SCC1 before you install it.
Mar 17, 2008 | Kenwood KDC-MP435U CD Player
Kenwood kdc-322 faceplate problem?
I found my Kenwood KDC322 faceplate doing the same thing(cutting out) I cleaned the contact points on this 'ribbon' behind the faceplate by rubbing the discoloration off with a pencil eraser. The lights have not cut out again.
Apr 04, 2007 | Kenwood KDC-322 CD Player
Intermittant display of song title and artist
I believe it's actually a firmware issue with the SIR-KEN1. I havethe same setup and have the same exact problem. I have to cycle thru my "SRC" button and get back to Sirius for it to work. Not a happy camper. I read on the Sirius Backstage forums about the firmware, although I have written Directed Electronics (SIR-KEN1 manufacturer) and never received a response.
Nov 12, 2006 | Kenwood SIR-KEN1 SIRIUS Radio Receiver
Kenwood SIR-KEN1 SIRIUS Radio Receiver Logo
95 people viewed this question
Top Kenwood Audio Players & Recorders Experts
 Grubhead
Grubhead
rigger094
Mike Duncan
Mike Duncan
Are you a Kenwood Audio Player and Recorder Expert? Answer questions, earn points and help others
