I tried to do a factory restore but it does not seem to work, I can not get wifi which it says my card is working, My device managers have a yellow question mark. I tried downloading from the dell site onto my desktop. I then tried to install it onto laptop but all that happened was I lost the base system device. What am I doing wrong and is there a easy step by step to download the device manager which incluldes base system device, ethernet controller and network controller. I have a inpiron 1501 Thanks
Make sure you got you driver from this page:
http://www.dell.com/support/drivers/us/en/19
If you got your network drivers by doing this search they wont work:
http://search.dell.com/results.aspx?c=us&l=en&s=dhs&cat=sup&cs=19&k=inspiron+1501+driver&rpp=12&p=1&rf=all&nk=f&sort=K&ira=False&~srd=False&ipsys=False&advsrch=False&~ck=related
SOURCE: Wifi card not reconized in device manager
-Please give the exact model of the system or the service tag of the system so I could check the specific information of the system and I could provided the correct driver you need to install on the system
-what windows are currently running on the system?
SOURCE: USB Audio Controller and Interface Won't Install on Dell 600m
This is generally caused by a driver conflict. Uninstall the sound drivers for the built in, then try to install the sound drivers for the RMX. If the hardware wizard finds and tries to install the drivers for both sound cards there may be a conflict, due to the drivers for the built in still being in the drivers cab file, then you will have to completely delete the driver file manually. Once you get the RMX drivers to load, you may have to create a seperate sound profile for the RMX, and switch to it manually when using it, in order to keep from creating a conflict between the two.
SOURCE: Network controller not working.
go to support.dell.com
click drivers and downloads
choose by service tag and type in your service tag located at the botton of the laptop usually composed of 7 alphanumeric digits.
search and then on the result, go to network and you should have the driver there.
SOURCE: My dell xps1210 do not have these driver because I
This link is all drivers for your pc including Ethernet controller. If you have a usb Ethernet card you will have to download the drivers from that manufactures website.
http://support.dell.com/support/downloads/driverslist.aspx?c=us&cs=19&l=en&s=dhs&ServiceTag=2R7RCB1&SystemID=XPS_M1210&os=WW1&osl=en&catid=&impid=
SOURCE: Dell XPS M1210 -- wireless not working and other devices
where i can get driver network conrtoller for my dell inspiron1000
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope this helps you
or
or
you might have to uninstall then restart your computer then reinstall your DVD/CD then reinstall the driver for this device
hope this helps
Switch On
your PC/ Laptop and log in to windows.
Go to 'Start'--->Programs--->Accessories--->System Tools--->Click
'System Restore'
A 'System Restore' window will appear.
Here you will have to check "Restore computer to an earlier time' and
click Next
Now you will find one Month Calendar window with Dates below, go to
the previous month by clicking the '<' sign in the upper left hand
corner of the Month Calendar and select any date that you see in Bold.
Note: It is better if you could remember from which date you are
facing the issue, try to select a date prior to that date.
The detail of that particular date should show "System
Checkpoint" and time on the right hand side box. Select that date.
Now, Click on Next and System Restore will start and windows will take a reboot.
After reboot your problem should be resolved.
