Laptop will not charge
May laptop will not charge. Can someone advise on how to check what the problem is. To identify is it the power lead or the connection in the laptop. it philips freeevents
  • 56 Answers
Have the battery tested. The battery holds the charge.
Posted on Nov 22, 2008
Not powering up at all. Taken battery out and should power up through charger however nothing. Model sony vaio pcg-3d1m Please advise if anyone else had similar problem. Thanks
When you connect the power adapter into the laptop, does the power LED light up? If not then - The battery adapter or the adapter's power lead or the laptop's power socket could be faulty. Check power adapter's DC plug that connects into the laptop power socket with a multi-meter, the voltage should be slightly higher than the voltage that is printed on the label on the bottom of the adapter. If the voltage is zero or way below the voltage that is printed on the label then the power adapter is faulty and needs to be replaced. If the adapter is OK then connect it to the laptop and power it up, then look at the power/battery charging LED light and wriggle the power plug in the laptop's power socket. If the power/battery LED light flashes and in a certain position this LED light stays firm, then the power socket is either faulty or it has a dry solder joint where it is connected to the motherboard. This can be repaired but it requires the laptop to be completely dismantled to get at this power socket and repair. If you cannot DIY then I suggest you get a quote first.
Dec 06, 2012 | Computers & Internet
Compaq prserio cq41 cannot start
If your laptop works fine while plugged in but stops working while unplugged it's likely that either your laptop battery is bad or your laptop is not charging the battery properly.
Below are steps that can be taken to help identify the cause of this issue.
Leave power plugged in
Make sure the computer has been charging from the power plug for at least two hours before attempting to unplug it.
Remove and reconnect battery
In some situations the battery can become loose.
Removing it and then put it back into the laptop.
Third-party utility
Use a third-party battery utility to determine the total capacity of the battery. For example, BatteryCare is a free software utility capable of doing this.
Replace battery or AC adapter
If your computer is still in warranty we suggest skipping to the next step.
If the above steps have been completed, we suggest replacing the battery in the computer or AC adapter.
In most situations it's a bad battery.
check all power and data leads from motherboard to hard drive and all of your cd/dvd drives make sure connections are secure dust free and not faulty
computers need all power and data to travel through every working device and to finish its cycle
so any faulty lead will end in computer error or shutdown or fail to boot
make sure your computers RAM modules are securely seated with no dust in the sockets also the Cmos battery has charge and seated with no dust in the sockets
some motherboards cmos batteries are soldered in
hope this helps
Sep 17, 2012 | Lifetime Compaq Presario CQ41 Replacement...
Compaq Presario CQ61will not switch on replaced power adaptor nothing please advise
test all power and data leads that attach to your hard drive SATA
the leads from your (motherboard to your hard drive) make sure they have a secure dust free connections and are not faulty
make sure all leads that are attached to your drives dvd\cd have secure connections and are not faulty
even something as small as faulty fan lead can cause you problems
computers need all of the data and power to travel through every working device and to have an end for a computer to be able work properly
a motherboard and a hard drive any leads between them will fail before your motherboard or your hard drive check all electrical extensions make sure they are securely seated even the cd/dvd drives need to have current go through make sure these devices are working
check the CPU central processing unit make sure it has thermal paste and dust free secure seating
also check your computer ram modules and cmos battery make sure it has charge and they are dust free and securely seated some motherboards cmos batteries are soldered in
hope it helps
Jul 16, 2012 | Compaq Presario Computers & Internet
Battery light went on while driving and radio went off in my 2003 pt cruiser
Check or have checked the alternator. If it is bad the radio is not the only thing that will shut off. When the battery drains enough the engine will shut down.
Jul 30, 2011 | Chrysler PT Cruiser Cars & Trucks
My AC adapter suddenly can't seems to be able to charge my battery. Please kindly advise
Ifthe laptop battery is more than 3 - 4 years old then the battery could be wornout. Rechargeable batteries have a finite number of charge and discharge cyclesand will lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up atall. ORThe battery shows a 100% charge but when the adapter is disconnected thebattery drops off to zero capacity in a very short time. Ifthe battery drops to an unacceptable charge level then the battery needs to bereplaced. Whenyou connect the power adapter into the laptop, does the power LED lightup? If not then - The battery adapter or the adapter's power lead or the laptop's powersocket could be faulty. Check power adapter's DCplug that connects into the laptop power socket with a multi-meter, the voltageshould be slightly higher than the voltage that is printed on the label on thebottom of the adapter. If the voltage is zero or way below the voltage that isprinted on the label then the power adapter is faulty and needs to be replaced. If the adapter is OK thenconnect it to the laptop and power it up, then look at the power/batterycharging LED light and wriggle the power plug in the laptop's powersocket. If the power/battery LED light flashes and in a certain position thisLED light stays firm, then the power socket is either faulty or it has a drysolder joint where it is connected to the motherboard. This can be repaired but itrequires the laptop to be completely dismantled to get at this power socket andrepair. If you cannot DIY then I suggest you get a quote first.
May 08, 2011 | Compaq Presario CQ40 Series Laptop Charger...
Acer 5315 won't charge unless i hold the lead in at the back! i've replaced the battery already now wondering if the lead is the problem ? what do you think?
Most laptops push a lot of power through that plug.
Have someone who knows about repairing them take a look to make sure the lead is the problem first, otherwise, it is a problem inside the laptop.
The contacts inside the laptop overheat and become unsoldered. A good repair shop should be able to fix it without new parts by resoldering the connection inside the unit.
Aug 19, 2010 | Acer Aspire 5315 Notebook
My inspiron 1525 is not charging. Have replaced battery and charging lead and still does not charge.
Based on what you have stated, you replaced the battery and charging lead but the laptop still won't charge. What do you mean by charging lead?
Are you referring to the power adapter?
Since you already changed those two things, then the problem could be the power jack of the laptop and/or the connections inside the laptop.
Try to plug the power adapter slowly and try to wiggle it. It you feel that the power jack is wiggling, then the problem is a loose power jack that is why it won't charge. And you need to have a tech tighten that up for you.
Have a great day!
Oct 05, 2009 | Dell Inspiron 1525 Laptop Jet Black
Screen picture froze, powerd down, powerd up, blank screen
open cbinet of crt,
then internally check circuit connection.
or check for external lead connect very well or not ,one of power,and data cable.
Jan 25, 2009 | Acer Aspire 5100 Notebook
Having problem with DELL E1050 Adaptor
if the laptop is getting power from the adaptor but the battery isn't charging it is one of two things. Either the charging leads inside the laptop are broken or have no connection to the battery OR the battery itself is bad. To test the battery try to find someone with the same computer and try your battery in their computer if everything checks out it is a problem with the computer. I sure wish they would get this power stuff strait with laptops. Its been how many years now??
Dec 30, 2008 | Dell Inspiron E1505 Notebook
I have a 2nd hand companq armada M300 notebook with docking station. It came with power lead which appears to fit both docking station and laptop - the machine powers up fine if I plug the power lead...
http://h18000.www1.hp.com/products/quickspecs/10381_div/10381_div.HTML
There is a manual for your armada, the battery is inside the hinge, and you put the charger in the hinge..not sure if it on left or right side of it
If the battery is healthy then it will be full charged in a couple of hours from emty to full, if the battery ise´nt that healthy, it can take 10-12 hours of more
Good luck to you
If you find my answer helpfull, dont forget to vote
Dec 18, 2008 | Compaq Armada M700 Notebook
Computers & Internet Logo
Brian Sullivan
Brian Sullivan
David Payne
David Payne
