I turn on and with full battery or ac adapter does not matter..... can be in midst a typing a sentence or scrolling and my Netbook just powers down for no reason.
Are you sure it's not just getting hot? try with a cooling pad, and/or blow that ****** out with some compressed air.
If you need further help, reach me via phone at https://www.6ya.com/expert/joel_63c670a84e9f6a97
Testimonial: "Yes very helpful and Joel Wilcox Thank you so much appreciate your expert solution and such quick resolution Wow Great "
Joel Wilcox, May 16, 2012
Thanks for solution but this happens as soon as turn it on with in 5 minutes? Could it be that hot in so little time?? I will try some compressed air will only help, won't hurt. But if I can say haven't used in maybe 3 or 4 months been in case, now started toi try use and have this problem. Can it get that hot that fast??? Thank you
i'd recommend plugging it in for at least 4 hours with it turned off to charge the battery for a while
SOURCE: Toshiba M115 S3094 Battery Probelm
Your battery not able to hold a charge is a bad battery.
Love your precise description & diagnoses. Wish others would describe their troubles as well as you!
Have a great day!
SOURCE: no power and there is a clicking noise in ac power adapter
Any news on this? I have exactly the same issue this morning.
SOURCE: Laptop won't turn on, blinking blue light
Jeremy,
It depends what failed on the motherboard. If the charging circuit is failed then you may indeed need a new mobo. The fact that it was working wouldn't be affected by the dead circuit as it only effects th laptops ability to recharge the battery or run from power.
Try talking to hp online tech support as they offer a $500 flat rate repair on many models. They can be access by going to www.hp.com and clicking the "contact us" link the the chat with live technician link.
Chris
Armor-IT
SOURCE: hp compaq nx9110 runs only on battery when it is plugged to AC
It sounds like you have a faulty power jack, and possibly a dead battery as well. You should take it to a person you may know that can order and solder a new one in or take it to your local electronics repair shop. I do repairs like this on a daily basis for my computer business.
SOURCE: I have a HP dv7 laptop it does not work with the
he is right, just get a new AC adapter that will resolve your problem
for hp pavilion dv7 laptop ac adapter or you can also get a car charger for hp dv7 laptop
