Question about Gateway Computers & Internet
Hard drive failed need mother board drivers - Gateway Computers & Internet
  • 56 Answers
I need to know make model & serial number.
or
open the computer and look at the motherboard and it should say somewhere on it
what the motherboard manufacturer and model # is...
All drivers are very specific for each and every Motherboard.
Posted on Nov 22, 2008
Vga is not working my mother board is a n1996
Mabee the hard drive has failed . try entering bios and see if the hard drive is recognised .If not try turning the computer off unplug it then reconnect the drive data cable and power cable
then re- start the computer and see if it is recognised. some models of older hard drives needed a driver installed during set up -- you usually have to put the driver on a floppy disc and hit the f6 button when prompted by windows set up to install third party drivers . I hope this helps
Apr 08, 2011 | MSI PM8M-V Motherboard
Was workin ok but no signal imput now
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electic extensions or just replace them they are probably faulty a computer needs its connections to have an end so any faulty leads will end up with a computer error hope this helps
Mar 29, 2011 | Asrock K7VT2 Motherboard
Tech says i need new motherboard computer won´t turn on
Before you buy a new mother board, (the L300D-13S board is around $185 from China), remove your battery, leave it for about 5 minutes. Use only the Mains power supply and see if it will switch on.
Fit the battery, plug in the Mains Charger and see if the battery charge light comes on. If it does and it won't give you a screen or flash the hard drive light or power up the hard drive, then I am inclined to go along with a replacement Mother Board.
The laptop has to complete the POST and if it doesn't that usually points to Mother Board problems.
Were you trying to upload a newer version of the BIOS before it failed?
Good luck but check ebay and beware there are some really dodgy frauds out there.
Oct 20, 2010 | Toshiba Satellite M35X-S1142...
Failed to unlock HDD System Locked
What you need to do is unplug pc, open up the door panel to your pc and remomo cell battery from mother board then find the jump pins on the mother board they look just like the one in back of the hard drive. The jump pins are connected with a jumper similar to the pins jumper that sets up your hard drive to master, cable select, or slave. You need to reset the mother board the way you do that is by removing that pin jumper and replacing the cell baterry then the pin jumper. If done correctly you will reset your motherboard password setting and bios allowing you to boot your operating system. If you need help google your pc manufacture and model number and search mother board jump pins. Or email me with your pc info to andreioneluv@yahoo.com , and I will try to help you find it. Please rate if this was helpful...
Jun 08, 2010 | Seagate (9W2892-337) 80 GB Hard Drive
Sata power supply with ide only mother board?
If all the motherboard has is IDE connectors,then you can with an add in card. To do this you need to run the installation floppy during a fresh windows installation when it prompts for 3rd party scsi or raid drivers. I'd take the easy road & install a slave drive on the IDE or run an external hard drive in a usb port. Or the ultimate option,build a system using a board with sata on it. Prices are way down on hardware in general,but it's not going to stay that way.
May 14, 2010 | Computers & Internet
Where can I find a driver for my hitachi travelstar IC25N080ATMR04-0
1. You shouldn't need a driver for the hard drive
the Bios ( Basic Input/output system ).
2. You mother board should detect the driver
3. You will have to go into the BIOS setup to see of your hard drive is detect then set the BIOS to boot from the hard drive
4. If your pc takes SATA ( Serial advance technology attachment) then a IDE ( Intelligent drive electronics) will not work with the system without an adapter.
5. Your PC mother board instruction manual will have instruction on hard to access your BIOS settings
Caution: Any changes in the BIOS will not allow some devices attached to your PC to work properly is not properly addressed in the BIOS setup.
Mar 19, 2010 | Computers & Internet
Need to replace mother board would i use one with 939 socket for amd and not reformat my hard drive
... and tell me, what is your question. The hard drive doesnt care what the mother board looks like with the following proviso ... you have a IDE drive not ... the new mother board must support it. You have a serial drive, the mother board myst support it.
As long as you can plug in the drive, the drive doesnt really care.
Oct 09, 2009 | HP Pavilion m7640n PC Desktop
ASUS P5VD1-X
When the computer boots you should be able to se if the mother board detects the hard drive.
if thats not so. go into the mother boards bios and have it set so that it auto see the hard drive,
Dec 14, 2007 | ASUS P5VD1-X (90MBL3C0G0EAYZ) Motherboard
Disk not being Recognised: Windows XP asking for driver
s cuase u r using ur hard disk with different mother board so u need to format it or u need to get teh mother board cd an dchange the boot sequence as cd-rom and run it
Oct 31, 2007 | Seagate Barracuda 7200.7 40 GB Hard Drive
Computers & Internet Logo
53 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
