RCA R56WH78 picture quality is blurry/3D
My picture is bowed at the top and bottom and the picture looks 3D, I have read a lot of posting, and everyone is saying that you need to change the fl231 fuse. How do i know that this is what i need to do? i found the fuse, but it looks fine. it is connected to the board, and the rubber cap over the fuse is not broken or cracked. What should I do?
    Genius:
  • 1,030 Answers
Rubber cap? i dont feel you have the correct fuse. fl231 is a small rectangular brown fuse next to flyback. I have written detail instructions on the replacement of this fuse. look under willtab profile under tips in tricks section. intitles the fl231 fuse problem. this also help you indetify if this is the problem.
Posted on Nov 23, 2008
Fuse was replaced and the tv works but the picture is in 3d and the top and bottom of the picture is bowed and also somewhat blurry
This is a suggestion: if convergence is off does the label on the back of the set indicate this is a PTK195 Chassis?
If so I can tell you the likely bad part and how to find it.
Before you rate this information let me know what you find.
I am here to help.
SD TECH
Aug 13, 2011 | RCA P46924 46" Rear Projection Television
Lines are bowed at top and bottom,picture is blurry
Is the convergence option still listed under the on screen menu setup options, or has it disappeared?
Jan 22, 2010 | RCA R52WH76 Television
RCA 36'' Tube TV Picture is Blurry
Out of focus picture. have many reasons. Check and replace damaged component/s at its horizontal scan output section circuit. Check the LOT (Line Output Transformer) too for damage. Replace the horizontal scan output transistor. Check the input voltage to LOT. If the voltage is absent check the feeder resistor; if any. If you wish to get some details; check the site linked here. Pull up older posts.
http://electronicshelponline.blogspot.com/ Type in this key phrase " my service table today " in the search box at the top right of the the home page, to get gathered some pages which has the details of practical experiences of the author of that site. The search result might display about 20 Nos of related posts. Press the "All posts" at the bottom of the list, then you can select them one by one.
Jun 03, 2017 | RCA Televison & Video
Screen is bowed on top and bottom. What could be our problem? Picture, letters & words blurry.
go to hatch screen adjust all colrs to make white color boxes , also adjusts linear lines
Dec 31, 2009 | RCA Televison & Video
Screen showing lots of colors caving in on top
You have no power to your convergence circuit. Depending on what model RCA you have will determine which parts are bad. Will cost about $200-$300 for a repair shop to repair.
Jul 08, 2009 | Televison & Video
3D picture with bowing effects
model number is located on bottom rear cover, your convergence circuit has failed but without model nobody can give you further info, re-post and we`ll try to help, video-tek
May 28, 2009 | Televison & Video
Problem with my rca projection television
my RCA R52WH74 HDTV IS STARTING TO LOOK BLURRY. ALSOMY SCREEN LOOKS LIKE IT STRETCHING MY TV PROGRAMS....... CAN U GIVE ME A SOLUTION
Mar 16, 2009 | RCA HD52W59 HDTV Projection Television
Screen looks like its in 3d
LOOK FOR OPEN FUSE (CTM) BY IHVT, THE MIDDLE ONE.
Feb 20, 2009 | RCA P52937 52" Rear Projection Television
Picture problem
3d pitures are a indication of convergence problem. is the picutre bowed in at top and bottom. DO you have the convergence option under the setup menu.
Nov 03, 2008 | RCA HD52W56 52" Rear Projection HDTV
Picture is blurry and is shaped like a bow tie on my tv
This is a convergence problem that you can fix if you can solder. Let me know if you wish to attempt the repair and I'll post additional details and instructions.
Dan
Oct 10, 2008 | Mitsubishi VS-55707 TV
Televison & Video Logo
285 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
