Question about Kenmore 3.8 cu. ft. HE3t Front Load Washer
MY DRYER JUST BEEPS WHEN I TRY TOP START ON ANY CYCLE.
THE DOOR CLOSES FINE, NO LINT SCREEN WARNING, I UNDPLUGGED AND RESET THE BREAKER FOR THE DRYER, STILL WON'T COME ON.
  • 116 Answers
REPL/ INTER FACE BOARD STUCK OR FROZEN BUTTON
Posted on Nov 30, 2008
Were is the reset button onwhirlpool model ler4634bq1
There is no "reset" button. If the light stays on it is almost certain your door switch is broken. The door switch turns the light on/off when the door is opened/closed, and likewise allows the dryer to turn on/off when the door is closed/opened. These switches do break and are relatively easy to change. First, ALWAYS DISCONNECT APPLIANCE FROM POWER; second, remove lint filter screen and unscrew the two phillips screws located on the dryer top next to the lint screen handle; third, using a putty knife release the top retention clips located at the front near each side in the gap between the top and front panels; fourth, swing the top up and back out of the way and remove the two 1/4" hex head screws located inside the cabinet on either side near the top that hold the front panel in place; fifth, disconnect the door switch wiring from the plug connection and lift the front panel up and away from the cabinet. Now you can replace the door switch and reassemble in reverse order.
Sep 12, 2014 | Dryers
Dryer wont start
Hi firew34 - If the dryer will not allow you to operate, try resetting the unit by either unplugging it or flipping the household breaker to the off position. Wait approximately two minutes, turn on the dryer and select a normal cycle. If these troubleshooting steps prove ineffective, you may wish to contact a professional as the unit may possibly have a defective cord, wiring, control board or door switch.
May 03, 2013 | Frigidaire GLET1031FS Top Load Stacked...
My Whirlpool gas dryer is not working
Instructions
Check that the dryer door is closing completely. Remove anything that blocks the dryer door from closing.
Ensure the "Start" button is pressed firmly to start the dryer cycle, the dryer is not overloaded and the clothing is not balled up. Any of these things can prevent the dryer from operating and/or drying the clothes.
Use a level to confirm your Whirlpool dryer is sitting flatly and evenly on the ground. Adjust the dryer as necessary for it to be level as the dryer will vibrate and make unnecessary noise when sitting unevenly.
Examine the inside of the Whirlpool dryer drum and in the space around the drum for loose change, pens, hair ties and other items that could have been left in the pockets of clothing. These items will cause noise and potentially cause the dryer to become inoperable.
5
Examine the Whirlpool dryer's lint trap for excess lint. Remove any lint from the trap and place it back into position. Always clean the lint trap between dryer cycles. Inspect the area around the dryer and in the ventilation and exhaust systems. Remove any built up lint and clean the area thoroughly. Built up lint is a fire hazard and can cause operating issues.
6
Check the gas shutoff valve if your Whirlpool dryer is gas powered. Ensure the shutoff valve is turned all the way to the "On" position.
7Check the electric plug and ensure it fits securely in the outlet.
8
inspect both the fuse box and circuit breaker for any electrical problems. Replace any blown fuses, if necessary, and reset the circuit breaker if it has been tripp
Jan 09, 2013 | Whirlpool Dryers
My Whirlpool Dryer (model no. LGR4634EQO) is no longer heating, or getting hot at all. How can I troubleshoot it??
Hello.
suggestions about things they can do to troubleshoot commonproblems.
Instructions
    • 1 Open the dryer door and remove the lint screen ifthe clothes are not dry after a drying cycle completes. Remove the lint fromthe lint screen and replace the screen. The dryer ought to dry more efficientlyafter the lint screen is cleaned.
    • 2 Open your home's breaker box if the dryer is notturning on or no indicator lights are visible on the front panel. If theswitches for the dryer in the breaker box are flipped to "Off," flipthe switches over to the "On" position.
    • 3 Remove some of the clothing in the dryer or drysmaller loads if you notice that the clothing is wrinkled when you finishdrying a load. Larger loads cause the clothing to wrap around one another whendrying, increasing the likelihood of wrinkles.
    • 4
Pull the dryer unit away from the wall and checkon the position and arrangement of the exhaust vent. An exhaust vent that ispinched between the wall and the appliance or an exhaust vent that is kinkedcan't allow air to flow through it properly, making it difficult for theappliance to dry properly.
    • 5
Make sure the door is closed if the dryerdoes notrun. Also check to make sure that you hold in the "Start" button forat least a second. Pressing the button for less than a second may not give thethe dryer enough time to recognize the button has been pressed and that itshould start.
Thanks for using fixya.
Jul 31, 2011 | Dryers
Press start button and dryer will start and stop , if you press start button again nothing happens , if you unplug dryer and plug back in it will try to start again and stop
Howdy: The motor could be popping it's breaker once the start button is pushed. When unpluged the motor resets and the cycle starts over. But also the dryer thinks the element is too hot and resets the safety switch. The temp thermistor (overtemp sensor) could be clogged with lint or open circuit. Not easy to diagnost. Do you smell burnt wires or lint? Check to be sure the door is completely closed. It may think the door is open and not start. Doug
Dec 09, 2009 | Maytag Dryers
Won't start - 3 beeps when Start button pushed
CHECK THE FOLLOWING--
1. No power to the dryer
Make sure there's power getting to the dryer. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power with a voltmeter or by plugging something else in. Sometimes the power cord disconnects or burns at the dryer, if this is the case, the wiring and the terminal block must be repaired or replaced.
2. Door switch / Door switch actuator lever
The dryer would not start with a broken door switch. Replace the door switch if found defective.
Most dryers have a door switch actuator lever - when you close a dryer door, it presses against the lever, which actuates the door switch. If the lever is broken, the switch would not activate and the dryer would not start. Replace the lever, if broken.
Note: Door switch actuator lever usually comes with the door switch assembly and it is recommended to get the whole assembly since there is almost no price difference between the door switch assembly and just the lever.
May 31, 2009 | Kenmore Dryers
Help
possible door switch ..also may even be door not closing properly try holding switch down with finger and pressing start at same time if starts try adjusting door..if not switch wiring can be acessed by remove 3 screws along back of top and sliding top off on left remove screws holding metal bracket with control bd attached the 2 wire connector goes back down to door switch
Sep 07, 2008 | Whirlpool GGW9250PL Gas Dryer
DYRER PROBLEMS
i took the top off checked all the wiring, cleaned the back vents, and the vent tube going outside. I also cleaned the lint screen and gaurd really good, put it all back together. I also unplugged the dryer waited a few minutes and plugged back in. The dryer had a code flashing saying it lost power, I reset the dryer and it has been working great now. Evedently it must be sensitive.
Aug 18, 2008 | Kenmore Elite HE4 Electric Dryer
GE DPGT750GC Gas Dryer Problem
Using the
Troubleshooter
To locate Troubleshooting Tips for common dryer
problems:
Press the HELP button.
2 On the Touch Screen, select TROUBLE
SHOOTER
3 On the Touch Screen, select the problem
description from the list. You can use the arrows
at the right of the screen to scroll up and down
through the list of additional problems.
4 On the Touch Screen, select a possible cause
for the problem and follow the on-screen
instructions to find a solution.
Pressing the HELP button then selecting HOME
SCREEN HELP
allows you to find additional
information on features found on the Home
Screen. Touch any pad on the Touch Screen for
an explanation of that feature. To exit the feature,
press the BACK button.
DID YOU ATTACH THE SERIAL CABLE?
Attach the serial cable for washer and dryer
connection to the serial port on the back of
the dryer.
Attach the other end of the cable to the
washer before pushing the washer into its
final position.
Problem Possible Cause What To Do
Dryer won’t operate Control panel is asleep • This is normal. Press POWER, the
touch screen or any button to activate
the control panel.
Dryer is unplugged • Make sure cord is plugged securely into
a working outlet.
Controls are not set properly • Make sure the cycle was set correctly,
close the lid and press START.
Fuse is blown/circuit breaker • Check house circuit breakers/fuses.
is tripped Replace fuses or reset breaker.
NOTE: Electric dryers use two fuses
or breakers.
Electronics need to be reset • Unplug dryer, wait 2 minutes, plug
back in and press POWER.
START was not pressed after • Press START.
a cycle was set
Door was opened during • Close the door and reset cycle, to the
the dry cycle beginning if necessary. Press START.
Dryer is too cold • If the dryer has been exposed to
temperatures below freezing for an
extended period of time, allow it to
warm up before pressing POWER.
Otherwise, the display will not come on.
Hope some of this helps. here is a link to the manual:
http://products.geappliances.com/ProdContent/Dispatcher?REQUEST=SKUOBJECTS&DOCUMENT=Use%20and%20Care%20Manual&SKU=DPGT750GCPL
Nov 29, 2007 | GE DPGT750GC Gas Dryer
Washing Machines Logo
56 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
