No picture
Sound like you lost Vertical Deflection. Youshould not have a line across the screen because this could destroy the threeCRT Red, Green, and Blue (Picture tubes) if left on to long. There is a protection circuit built in to protect your CRT’s. Check on the PCB-SIGNALboard (Tuner located on this board) transistors Q-206 Collector should be around 1 Volt Base and Emitter 0V. If the voltage atthis point is greater then 5 Volts the Vertical output IC-401 (Mounted on heat sink 7 pin inline IC) is bad, Part # LA7845. Pin Voltages should be PIN 1= 0V, 2= 34V, 3= 32V, 4= 3V, 5= 3V, 6= 33v, 7= -6V. Data sheet located at http://pdf1.alldatasheet.com/datasheet-pdf/view/40357/SANYO/LA7845.html
