Question about Verbatim STORE-N-GO (95312) 8 GB Hard Drive
Verbatim external 640gb harddrive is unreconised.CONSTANTLY.
Why does my pc keep telling me that my external hard drive is unreconised.ive been trying to fix this for 3 days non stop.im well annoyed with it.ive tryed many ways to install it but no luck.ive try it when its on and when its off.ive tryed it after reboot but nothing...UNRECONISED is all i get...it mounts for a second then disappears again.ive plugged it into my pc usb at the back and even tryed a multi usb connector.ive use one with my phones and mp3 player with no problems....im on a budget as it is.i cant afford a new one again.im screaming through frustration with all this messing about.it managed to mount once but then disappeared.??
    Novelist:
  • 177 Answers
Ok.. here's a few ideas...
Before Connecting the external drive:
first close ALL RUNNING PROGRAMS
REINSTALL DRIVERS..REBOOT
make sure no programs are running once again...
make sure your usb cable is WORKING...
NOW...
Connect.....Wait for it (a minute or two MAX)....
If this doesn't work, then I suggest using a few google searches..
Try the following/similar: Searchwords
External Hard Disc Recovery Tool (or toolkit)
*Also, Never NEVER erase any default/hidded files that came preinstalled/included on that drive....(eg...system files)...
let me know if this helped...c-tekk@hotmail.com
Posted on Mar 19, 2009
Trouble with Transcend 640Gb external harddrive; chkdsk does not work.
You will have to format it. Format it in NTFS mode since it is high capacity drive. I think you are trying to use it for the first time. This also occurs if you have problem in hard drive but it is rare. Let me know after formatting, it is working or not. I will help you further.
Increase Engine Horsepower
Jul 23, 2012 | Transcend Computers & Internet
Verbatim hard drive
Hard drives are fragile, and if they fall sometimes you get lucky and other times no. The only solution is to bring it to a computer store in hopes they can extract your files.
Mar 05, 2012 | Verbatim External, USB 2.0, 500GB...
My daughter just dpopped my hard drive on the floor and now it's not recognised on my pc....any help!!?? It's a verbatim 640 GB
The Verbatim external harddrive may be damaged beyond warranting repairing, either from you, or a professional computer shop.
Allow me to explain the construction of an external Harddrive, plus the Harddrive located inside the case, and what may have resulted from the fall.
Basic construction of an external Harddrive, (IDE or SATA)
1) Plastic external case. Also referred to as an External Enclosure. Usually comes apart in two halves.
2) Small circuit board located inside, with an interface that the Harddrive plugs into.
3) Harddrive. IDE or SATA. Can be a 2.5 laptop harddrive, or a 3.5 desktop harddrive that is used.
[A laptop harddrive is 2-1/2 inches across in width. A desktop harddrive 3-1/2 inches.
If you have the Verbatim Leather Wallet 640 External HarDDrive it has a 2.5 inch laptop harddrive inside. The harddrive is a SATA unit.
http://en.wikipedia.org/wiki/SATA
View of an average 2.5 inch (Laptop) 640GigaByte harddrive,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=5260951&CatId=2681
(The harddrive inside the Verbatim external harddrive enclosure, may not have a clear see-through cover to observe the internal workings )
The back end of the harddrive has contact pins. These pins line up with an interface.
The interface is a block with matching socket holes for the contact pins.
(Or more than one interface may be used)
The interface 'block' may be attached directly to the circuit board, that is inside the Verbatim external enclosure (Case), or may be attached to cables (Wires) that are then attached to the circuit board.
A) Point; The circuit board may have a crack. (Copper circuit trace is torn, or more than one)
[Circuit Board. Also known as PCB. Printed Circuit Board. Crude description of construction is a laminated board with very thin copper wires on it.
This information details out the construction of PCB's,
http://en.wikipedia.org/wiki/Printed_circuit_board ]
If cracked the circuit board MAY be repaired. Finding the open circuit, (Broken circuit trace. 'Copper wire'), may be VERY tough.
The circuit board may be replaced. From the factory will cost $$$$, and perhaps the loss of information that is on the harddrive.
To my knowledge the needed circuit board is not sold to the average consumer. This would mean obtaining another like Verbatim 640GB external harddrive, and using it's circuit board.
Not feasible.
More feasible; The harddrive would be removed, an inexpensive external enclosure procured, the harddrive then installed inside, then the USB cable from the external enclosure is attached to a working computer, and personal information is then copied off.
(Hope you're not an English teacher, and reading the above, lol!)
B) Basic construction of a Harddrive:
1) Inside the hollow empty metal shell of the Harddrive are two motors.
The Spindle motor, and the Actuator motor.
There are 3 to 6 Platters inside the Harddrive. (Perhaps more in today's Harddrive's)
The Platters resemble CD or DVD disks, and are usually composed of metal or glass.
The Spindle motor drives the Platters.
EACH Platter has a magnetic media applied to it's top surface, and bottom surface.
The magnetic media is arranged in a pattern of 0's and 1's.
1 being ON, 0 being OFF.
(The magnetic media is arranged in Sectors and Tracks much like a CD or DVD disk)
The Read/Write Head arranges the magnetic media. The Write portion of the Read/Write Head does this. (The Read portion does as it implies. It reads the information on the Platter)
There is a Read/Write Head on the Top, and on the bottom surface for EVERY Platter.
When the computer is off the Read/Write Head is in a parked position, and away from the Platter.
When the computer is on, the Read/Write Head is 'hovering' right above the surface of the Platter.
The distance of the Read/Write Head to the surface of the Platter is VERY CLOSE.
The Read/Write Head is attached to an Actuator Arm. This arm swings the Read/Write Head back, and forth across the surface of the Platter.
(When operating, the Actuator Arm can swing the Read/Write Head back, and forth across the Platter at Hundreds of Times a Second!)
Point; If the Verbatim 640GB was plugged into your computer with the computer on, and then dropped, one or more Read/Write Heads could have crashed into a Platter. (Or Platters)
This would result in wiping off some of the magnetic media, and may have rendered the Harddrive useless.
I know. I'm just a ray of sunshine.
I would suggest removing the harddrive out of the Verbatim's case, and installing it into a matching external enclosure, to try to remove any needed data.
OR take it to a professional service that recovers information from damaged harddrives.
An external enclosure is cheap,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=1086960&CatId=2781
This is to just check out the harddrive, and see if it's still functional.
For questions, or clarification to what I have stated please post in a Comment.
Regards,
joecoolvette
Apr 24, 2011 | Verbatim Computers & Internet
I continually get the pop up asking whether I want to scan & fix the verbatim HD after I have done it a number of times
Hi
You just installed in your computer a USB virus scanner sofrware. Just uninstall this software and this message will disappear every time you plug external HDD.
Regards
Apr 05, 2011 | Verbatim (R) Wallet Drive(TM) USB Portable...
Hello, i have a VERBATIM hard drive USB 2.0 it cost me a lot of money :-( i've hardly used it! it has been handled in cotton wool tonight, when transferring data to it from my computer it has...
1. First power down the computer and the external hard drive.
2. Disconnect the drive.
3. Wait a minute.
4. Start your computer.
5. Connect the Verbatim drive again.
6. Wait a minute. (While waiting, check the screen for popup messages telling you the harddrive is ready and received a drive letter.)
7. Check "My Computer" for the harddrive.
8a. If you see it there, click it and make a copy of the data you have stored on the drive immediately!
8b. If the drive does not show up, you probably have a problem that will take deeper looking-into.
A clicking sound from a harddrive is never a good sign. While it does not mean immanent ***** of the drive, getting the data from it is now a matter of luck. In any case you should not trust the drive and should replace it as soon as possible.
Jul 01, 2017 | Verbatim SmartDisk Firelite Portable USB...
Lacie 1tb external hard drive into ps3 is not regconised
I have the same issue, however with my verbatim 500g its ok. i believe it is because the lacie is a desktop external and therefore is compatable with windows xp and 7 alone.
Verbatim is a "portable" external hard drive which makes it compatible with several different systems. I would suggest returning it, I just formatted my old verbatim harddrive and set up mediaasharing. Through my router. You can actually route the lacie harddrive by going to my computer and right click the icon. Next go to share with; advanced settings and allow all. Then when you turn your ps3 on search for media servers... I would suggest to google media server for ps3 to get it all seet up. GOOD LUCK
Jun 07, 2009 | LaCie Hard Disk 1TB Desktop with Hi-Speed...
External hard drive
bad hard drive, try it on another laptop makesure there's power going to it the usb cable by itself wont work it needs power
please rate
Mar 05, 2009 | Verbatim External, USB 2.0, 750GB...
Computers & Internet Logo
169 people viewed this question
Top Verbatim Computers & Internet Experts
Martin Murray
Arora Singh
Arora Singh
Computer Links
Are you a Verbatim Computer and Internet Expert? Answer questions, earn points and help others
