Question about Epson Stylus CX6000 All-In-One InkJet Printer
Epson Cx6000 my cx6000 will not print does anyone know what could be wrong. I changed the cartridges and done head cleaning etc but problem persists Thanks
  • 2 more comments
  • Anonymous Jan 12, 2009
    I change the ink but it does not work.
  • jjs8 Jan 15, 2009
    my epson cx6600 will print as a copier, but will not recognize epson cartridges and will not print on line or any of my documents.ajs
  • wingatemothe Apr 12, 2009
    Changed ink cartridges, then communication errors, then couldn't find the printer (searching), then gaps in printed document, then printed one thin line on the side. We tried "re-positioning", then tried cleaning the heads, and now it sounds like a freight train coming thru the house. Sporadic problems since we got it- under pressure to print at tax time!
  • sugartopaz Apr 20, 2009
    I did the nozzle check and did not print the black. I put in all 4 new catridges and now do not print the yellow and blue.
    I did nozzle checks and head cleaning and its the same.Now after 1 hour it seems as if I have to buy new ink again.
Sorry to say but after reading countless forums, visiting the epson web site, and talking to their tech support; they've screwed us. I've noticed that every epson CX series has countless ink cartridge misshaps, and none printing issues. First off I recommend you cut your losses now and don't buy anymore ink for it because it will not help, and I also recomend not ever buying Epson again. My CX6000 had brand new ink, the black never printed and after 2 nozzle checks my ink was very low or gone(so it says). I learned that the ink is not gone its a programming error with the chip on the side of the cartridge. Also I believe they have scammed us because phone tech support told me to take out and put back in the cartridges which "expends" the cartridge if you have seen that error and from Epson website itself says once you remove a cartridge it becomes expended or already use and the printer will reject using it. And their Epson repair stores charge 15$ just to look and see what the problem is then "fix" whatever it may be (probably something expensive). The thing is they F'd us and might as well get a new printer. best of luck to you.
Posted on Jan 08, 2009
I have all new ink and my cx 600 says I'm out of ink except the yellow. I called Epson and they recommended I either take it in to be repaired or purchase a new model and offered a "discount" passcode to their website of refurbished models. They offered free ink if i buy a new model. The problem is I already have 8 new containers of ink because my printer kept saying it was out! I have cleaned it I am going to take it apart and clean it again. It has very low miles and is about 3 yrs old.
Posted on Feb 13, 2010
I've had this problem a few times and all i did to fix it was just pull out the power cord from the printer without turning it off. I cant say it has happened a lot but a few times since i got it. Works every time for me.
Posted on Jun 16, 2009
Epson clean print head
EPSON Stylus CX6000 Series, How to clean print head
May 27, 2014 | EPSON Stylus CX6000 Series
My epson stylus cx6000 has stopped printing black. I've cleaned the print head, changed the cartridge and it still won't print black. What else can I do?
Be sure you are using genuine epson ink. Epson printers are "smart" and will not allow generic ink to work properly. Even after you replace a generic with a genuine it may take several print outs and alignments to get it to print again.
May 05, 2011 | Epson Stylus CX6000 All-In-One InkJet...
Lost my cx6000 owner's manual. Is it available online?
you can't get any replacement for the manuals but you can download it through Epson Support site.
Click here for the link.
Jan 06, 2010 | Epson Stylus CX6000 All-In-One InkJet...
Colors don't print clearly and black lines run across the page
With Epson, You must use Genuine Epson Cartridges. This is what happens, when they are not.
Epson has it rigged, that way. Believe me, I have learned from experience.
If they are Genuine, then I suggest, use a new cartridge. See what happens.
Most of the Epson, are always on Sale, for a good price. It would cost most to take it to a repair shop.
Good Luck.....
Dec 29, 2009 | Epson Stylus CX6000 All-In-One InkJet...
The Black is not printing, even after cleaning the head several times
With the EPSON'S you must "Genuine" Epson Cartridges. It does not print good with Generic.
I went thru 2 sets of cartridges, trying to clean the heads alot of times. Finally, had to buy another one.
If you are using generic, change back and see what happens and try again. If not , Good Luck.
:0(
Nov 18, 2009 | Epson Stylus CX6000 All-In-One InkJet...
Replaced all cartridges will not print black
Before you replaced the ink cartridge, did you let the ink in the previous cartridge run completely dry? If you did, then the printer heads are completely dry and it will take awhile for ink to start flowing again.
Jul 31, 2009 | Epson Stylus CX6000 All-In-One InkJet...
Epson sx600fw
Here is how you fix it
http://www.inkmagic.com/epson_clogged_printhead.htm
Jul 04, 2009 | Epson Stylus CX6000 All-In-One InkJet...
Epson cx6000 will not print
Have you tried replacing the cartridge....to verify
keep me posted
Cheers
Nov 13, 2008 | Epson Stylus CX6000 All-In-One InkJet...
Epson Stylus  CX6000 All-In-One InkJet Printer Logo
820 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
