Question about Kenmore 36665 / 36669 Gas Kitchen Range
Gas oven (Kenmore 911.36665) will not light/heat up
Our oven will not heat up/turn on. However, it will heat up if you turn the Clean setting on.
3 Suggested Answers
marka19
  • 1430 Answers
SOURCE: Oven lights ,but doesn't heat to preset temperature
The problem is usually the igniter not reaching the correct amp draw .When the igniter does not reach the correct amp draw it may allow the gas valve to partially open or not open at all. The igniters are inexpensive and easy to replace. There is a video at http://appliancehelponline.com/gasoventroubleshootvideo.html this will walk you thru the correct procedure for performing this test. It may be a different model but the testing will be the same.You can also enter your model # for diagrams and illustrations of your specific model. Not all models are available. All parts come with installation instructions.
Posted on Jun 17, 2010
Testimonial: "Exact problem and solution, Thanks"
SOURCE: I have the Kenmore Classic Grille oven, model
We have the same problem with our Classic Grille. We bought a new clock/oven control part and it didn't solve the problem (still no light in clock area). Any ideas about what is actually causing the problem? Looks like all the wires are connected...
Posted on Oct 25, 2010
Cannot do anything but self=clean
The oven temperature is regulated by a temperature sensor when placed in self clean the sensor is removed from the circuit and full power is applied to both the bake and broil elements causing an the temperature to exceed in some some models up to 1,000 F. I would recommend against using self clean for the simple fact that no oven cavity to this date has been designed to withstand that high of a temperature and therefore excess heat is passed upward resulting in damaged lock mechanisms, control boards, and other electronic components. More than likely your thermostat or oven control has been damaged and needs to be replaced. I would replace the temperature sensor as well
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
Apr 26, 2012 | Kenmore Kitchen Ranges
The oven does not work. The self clean does not too
kenmore self cleaning range c970-595084 everything works except the oven will not heat up,on self clean door locks but thats all, top elements work, lights work, digital display works, but no power going to oven elements when i used a tester to check voltage. Can anyone tell me what to do? Is there a fuse for the oven only?
ANY HELP IS APPRECIATED.
TY Fr; Clyde
Mar 15, 2011 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Oven is slow ot light and has a gas smell when
Hi, this sounds like a weak igniter, it would have to be a gas oven and the symptoms usually are: takes longer than normal to ignite the burner, may or may not smell gas in the oven, if it does light the burner, there may be delayed ignition (pop), does not maintain set temperature or burner does not come on fully, eventually won't heat at all. On gas ovens, a glo igniter is like a light bulb, the more you cook, the faster it wears out. Bottom line, needs to be replaced. Good luck.
Jan 21, 2010 | Kenmore Ovens
Kenmore gas oven does not reach operating temperature
If your oven is 20 years old the temperature sensor system might no longer be accurate, if you have access to a temperature measuring device that can confirm that the oven is not reaching 350 then run it up and check that its not just your indicator light system. Some oven burners have air control and yours may have accumulated oven soil over the years. If your burner. Is behind a short wall like mine is, use a mirror and torch to check. A clean can bring things back to standard. Flame heat is from a good mix of. Gas and Air...
Dec 05, 2017 | Kenmore Ovens
My Kenmore gas oven does not light.
Remove the oven Racks. Remove the oven base plate. Turn the oven on. You can then see the oven ignitor next to the oven burner. If the oven ignitor does not glow a bright orange,replace it. About a $90 part.
Oct 05, 2009 | Kenmore 30464 / 30465 / 30469 Gas Single...
Oven pilot light won't light
Part of the problem was my own ignorance about this particular Kenmore gas oven. It doesn't even have a pilot light. Instead, there is an electric heating element close to the burner which gets so hot that it ignites the gas. It seems that the heating element also doubles as a temperature sensor, so that it opens the gas valve only when the heating element is hot enough to ignite the gas. This heating element, called the "ignitor", no longer gets hot in my oven even though there is 120VAC applied to it when the oven knob is turned on. Therefore, the ignitor is defective. I ordered a new one on-line from "Appliance Parts of America" for $31.50 plus shipping, and this should fix the problem. If it does NOT, I'll add to this post.
Apr 21, 2008 | Kitchen Ranges
Oven does not heat up, can smell gas.
You probably need an oven igniter, it's weak. Remove oven bottom and find caged unit attached to burner. Replace this oven igniter. The 2 wires can go either way.
Nov 22, 2007 | Kenmore 40494 / 40495 / 40499 Electric...
Kenmore gas range--oven won't come on
My oven will not work. After pressing the desired temp on the oven, the preheat light and oven light comes on. After about 15 minutes, the oven is slightly warm and maybe an hour later the oven may or may not heat to desired temp. Kenmore gas range model #790.72851301.
Nov 15, 2007 | Kitchen Ranges
Kenmore 36665 / 36669 Gas Kitchen Range Logo
123 people viewed this question
Top Kenmore Kitchen Ranges Experts
Sal De
Justin Duby
Justin Duby
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
