Question about Motorola Mobility i560 Cellular Phone
Need to replace flip lcd housing
I need to replace the flip, I have a new flip but not sure what screws to undo to replace part.
  • 66 Answers
Its pretty simple
1. remove 4 screws in the back of phone.
2. remove back cover
3. unclip lcd connector from main board
4. remove main board
5. reassemble with new flip
Posted on Nov 22, 2008
Motorola w845 quantico disassembly
I have never done a w845 quantico but have done several V860 barrage phones in my time. Both of these phones have a similar design. On the barrage if you flip the screen open, on the inside of the flip there are 6 screws, undo those screws and place where you will not loose, then the top part will separate with just a little nudging (front cover from back) the earpiece in the barrage is in a small compartment and has two contacts (no screws just some adhesive) remove and replace, clip the front back together and replace screws. Most important part is to make sure you do not damage the LCD cable in the hinges of the phone.
Dec 22, 2012 | Motorola Mobility W845 Quantico
How to dismantle lcd of Neo Basic B3362n
A replacement screen maybe available from this WEB site.
www.lcdparts.net
The screen is removed by undoing the hinge screws, careful unclip the video connector from the motherboard.
Keep the screws together as you remove them so you will know which screws are needed to install when you fi the new LCD screen
Undo the screws that hold the bezel that surround the LCD screen, then remove the bezel (it may be also held in place with double sided tape).
When the bezel is removed the LCD screen is secured to the hinge assembly by more screws around the edge of the LCD screen.
When you install the new LCD screen, reverse the order you took in removing the LCD screen.
These WEB sites may assist you in repairing the LCD etc.
Nov 30, 2012 | Computers & Internet
Change sceen
www.lcdparts.net
Replacing Display hinges
http://www.laptopparts101.com/display-screen-hinges/
Laptop repair info
http://www.laptoprepair101.com/
Feb 11, 2012 | Computers & Internet
Is it an easy fix to replace the bulb on a Sony KDF-E50A12U HDTV LCD
yes just be careful not to pull off soddered wires close by
May 03, 2010 | Sony KDF-E50A12U 50" LCD HDTV
How do you replace an LCD screen on Nokia E66
Undo 6 screws on back of rear housing, [2 near sim reader, rest on body .] When back pops off , be careful to release Sim flex , as it will tear easily. Disconnect main flex between 2 halves of phone.Remove main board , then undo 2 small screws at the top of phone .This will release the front housing. The LCD JUST FLIPS OFF THE CONNECTOR ON THE FRONT FLEX, be gentle with the handset and removal! . To rebuild , just repeat in reverse, as is quite simple, but BE GENTLE!!
Sep 15, 2009 | Nokia E66 Smartphone
Replace flip on my nextel i850 phone.
1. Remove battery cover and battery
2. Remove the four T-6 screws from back of the phone (you will have to raise the antenna to access one of them)
3. Seperate the housings.
4. Disconnect the flex connector/data cable that connects the back housing to the motherboard.
5. Disconnect the cable attaching the flip to the motherboard (at top of board)
6. Remove keypad from old part and put it in the new part.
7. Insert motherboard into new flip/front housing and connect cable to board.
8. Reconnect cable from back housing to motherboard
9. Replace and tighten 4 screws and you are good to go.. very easy repair.
Mar 24, 2009 | Nextel i850
Psp not reading
the memory card is not inserted well.
Feb 20, 2009 | Sony PlayStation Portable (PSP) Console
How do you replace the lcd screen on A LG shine KE970
Take off the back plate that houses the battery, undo the four screws, then look where the bottom of the battery is just below are two cover caps remove and undo the two screws below now separate the cover. There is a circuit board under neath the panel unplug may seem tight but go careful, underneath this there are a futher six screws undo these and the two halves of the phone will separate. Now undo all the screws you can see here including the two that are under the two covers at the top they look like moulding marks separate the halves, undo the screws on the roller switch,lift this and you will find a ribbon connector that appears to be glued it's not, go careful and separate. Congratulations you have now removed the LCD. All you have to do now is remember which screw goes where and reverse the whole process. Good luck.
Feb 08, 2009 | Cell Phones
Top flip section of phone broken,
Yes you can do this but it is safe to take the phone to a mobile repair shop and have them repair it for you.
Aug 14, 2008 | Samsung SCH-u740 Cellular Phone
Question??
It is easier to replace the whole lcd flip screen. It is only 2 screws and it is about 10 dollars more.
See these 2 procedures for the difference.
replacement of the Sidekick 3 LCD flip screen.
Sidekick 3 LCD Screen Only Replacement
May 26, 2008 | T-Mobile Sidekick® 3 Cellular Phone
Motorola Mobility i560 Cellular Phone Logo
90 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
