Question about Euro-Pro EPH18-236SS Vent-A-Hood Euro Pro Series 18" Wall Mount Specialty Hood
Vent-A-Hood dumping water on Cooktop
In the Oct-Nov time frame, we find a cup of water on the cooktop in the morning every couple of days. It looks to be coming thru the inside of the vent draft and it does not need to rain. The water accumulates in the fan housing. At some point, it spills out on the deck.
The 6 inch vent rises 2 ft above the hood, turns at a 45 12 feet to a 45 thru the roof. It is all dry on the outside of the vent. The roof vent is not rusted.
We contacted VentAHood. They have "never heard of this" and do not have a suggestion
    Sergeant:
    Champion:
  • 338 Answers
Only thing i can think of would be a condensation issue. see if it is when you have a temperature change outside while it is warm in you home.
Posted on Dec 07, 2008
Need 4 Creda stove top range burners that are 7.25 inches round with 2 sides being square on each burner.
Creda Cooktop Product Support ' ManualsOnline.com
kitchen.manualsonline.com/support/creda/cooktop/
my gas cooktop was continually clicking and smoke ... i am looking for the manual fora creda colonial t ... Creda glass cooktop GH100, need a burner ignition.
Creda Spares, Parts & Accessories
www.4creda.co.uk/
We have parts for the full range of Creda models, so we're sure to have the part you ... Get the best performance from your Creda cooker hood with our range of ... fan oven elements, replacement control knobs, door gaskets and oven hinges.
CREDA GAS Cook Top Cooktop 4 Burner White 30" x 20 ...
bellingham.craigslist.org/app/5414687535.html Craigslist Inc.2 days ago - CREDA GAS Cook Top Cooktop 4 Burner White 30" x 20" HIGH ... make / manufacturer: CREDA ... The grates have some cosmetic chipping.
Jan 25, 2016 | Creda Kitchen Ranges
How to replace a fuse?
It is fused through the house breaker box.
Mar 15, 2017 | GE Select-Top 30" Modular Downdraft...
Amana gas cooktop clicks when not in use
Take a look at the solutions that have been posted regarding igniters. i suspect a dirty or wet push-down knob. you will see that others have had water/moisture causing problems. drying mights solve it, but it may need a a bit of a clean. keep trying. it must have taken me a couple of hours to solve.
May 07, 2010 | Amana AKS3040 Gas Cooktop
Burner control will not depress or turn. This is a fairly new GE gas cooktop and this burner has been used only a couple of times.
constantly cleaning with spray cleaner or too much water may have leaked down into the steam of the valve and rusted it. replace the valve and lycon switch
Nov 22, 2009 | GE 30 in. JGP326 Gas Cooktop
My new home already has a hood vent for the range. I have a gas Jenn air downdraft range. I prefer to use the hood vent as the downdraft is not very efficient. Do I have to connect the blower on my range...
The poupose of either is to eliminate any smoke created by the range or grille and move as much of the cooking odors to the outside. I wouldn't use both at the same time, but if the hood is vented to the outside, it would be just fine to use only the hood. Aregular cleaning will be necesssary. The downdraft has limits as to the distance it will efficiently exhaust air. Flex hose should not be used. And excessive bends or vent length, cuts into the efficiency.
Oct 29, 2009 | Jenn-Air JED8230 Electric Cooktop
Installing JED8230ADB Cooktop Grill with down-draft exhaust
I can't imagine directing the downdraft vent back up to a traditional hood type system. Why bother, just don't use the downdraft or get a cooktop without a down draft and save money.
In granite, yes for any cooktop as long as someone can cut the correct size hole. Cooktops must be installed so the top is just about flush with the countertop. They all come with a template for cutting the right size hole in the countertop.
Feb 24, 2009 | Jenn-Air JED8430 Electric Cooktop
Raplacing 3 wire cooktop with 4 wire cooktop
if you look in most panels the ground and the neutrals are tied to the same ground. they might be in a different location within the panel but they are common to each other. if you are concerned about having a seperate ground get yourself a ten foot, one inch diameter copper rod drive it into the ground about nine foot six inches. then mix up a strong salt water solution, about a couple of gallons and pour it around the rod. voilla, you have an independent ground. this might sound like a bunch of bull ----, but it is valid information. if you still have reservations call the building department in your town and they will verify it for you.
Jan 06, 2009 | Jenn-Air JED8230 Electric Cooktop
Clearence to hood fan
I just had a similar cooktop installed with a micro over it. From the bottom of the upper cabinet to the top of the burner frames you need 33 1/2 inches and from the bottom of the micro to the burner frames you need a minimum of 16 1/2 inches.
Aug 01, 2008 | Amana AKS3040 Gas Cooktop
Installation of new electric cooktop
If you're talking about a downdraft style cooktop, you will just need to measure the discharge vent diameter and shape and match that up. Not all are the same shape but most are 6" diameter
Apr 22, 2007 | Whirlpool 30 in. RC8700 Electric Cooktop
Kitchen Ranges Logo
356 people viewed this question
Top Euro-Pro Kitchen Ranges Experts
Oloyede Monsuru
Marvin
Marvin
Paul Carew
Are you an Euro-Pro Kitchen Range Expert? Answer questions, earn points and help others
