Question about Samsung Digimax S800 Digital Camera
Memory problem? I recently purchased a new s800 digimax for a while on the first day it worked fine then when i turn on the camera it says format (yes) when i press yes it says (check sd card)what can i do to fix the problem? Without the card it works fine.??????
    Problem Solver:
  • 32 Answers
If Its in warrentty period don try anything yourself just go to customer support. Sangita
Posted on Jul 24, 2007
SOURCE:
On my Samsung Digimax S800, when I put the memory card in, it says to check sd card. What do I do about it?
When the card worked before, check if you did not switch the lock switch down. And check all contacts on the card and in the camera. They should be clean and shiny.
When you recently bought a new card you could have bough a SDHC card and these won't work in your S800.
The S800 only accepts MMC and SD cards, The SDHC and SDXC cards won't work.
A few years ago you still could buy 4 Gbyte SD cards. Now even most 1 Gbyte and 2 Gbyte cards are already SDHC. SDHC was introduced at least 7 or 8 years ago, so all new devices accept SDHC. The SDXC was introduced at least 4 years ago, so in a couple of years, you perhaps only can buy these cards?
Feb 21, 2015 | Samsung Digimax S800 Digital Camera
I can't install my card in samsung digimax S800
What type and size memory card? The S800 uses MMC and SD cards. It will not work with SDHC cards even though they'll fit into the slot.
Dec 22, 2012 | Samsung Digimax S800 Digital Camera
Memory card after formatting, say check card (samsung camera)
Probably, especially if your card is a 4GB or larger SDHC card, then it's definitely the wrong card. The older Digimax S800 camera can only use standard SD cards (2GB or less). Fortunately, these are very inexpensive these days, and may be found on Amazon if your local store no longer carries them.For others reading this experiencing similar problems, please see this article.
Nov 27, 2011 | PNY 4GB Secure Digital High Capacity...
Card locked samsung s800
Hello Eilee,
Remove the memory card from your camera and check for a tiny switch on it. Make sure it is not set to "Lock". If it is, then switch it back to unlock.
However, if your memory card does not have the "Lock Feature" it could mean that your card is already malfunctioning. Try reformatting it first before buying a new one.
Note: You will loose ALL data from your SD card once you format it.
You can rate my answer if you appreciate it.
Thanks!
-damneddle
Oct 12, 2011 | Samsung Digimax S800 Digital Camera
I can't get the camera to accept a sd memory card. It keeps saying check sd card, but it's brand new. Why is this?
Are you using a 4GB or higher "SDHC" card with your camera? Note that the S800 can only use "standard" SD cards (those 2GB or less). Fortunately, these are very inexpensive these days, recommend checking on Amazon.
For those that encounter this problem, there are several possible causes for "memory card locked", "memory card error", or "no memory card". The most common is trying to use a 4GB or higher SDHC card with an older camera made before SDHC format came out. Other causes include problems with the tiny slide switch on the side of the card, or the electrical contact switch internal to the camera. The problem may also arise from simple formatting problems if the card has never been formatted in the camera (note that this will also erase the card). Troubleshooting tips for this problem may be found at this link.
Jan 05, 2011 | Samsung Digimax S800 Digital Camera
S800 digital cmaera unable to delete photo's memory full but when I go to to delete using the ok button nothing happens
Is the memory card inserted??if yes try to check the memory card on the pc. Maybe the card was wasted or corrupt.So you can see the previous pictures before the mmc corrupted, And it cant be deleted.
If No. try to reformat the unit by pressing menu and settings. After formatting,,click reset for defaulting settings..
Dec 31, 2010 | Samsung Digimax S800 Digital Camera
When I Have The Memory Card Inserted My Camera Will Not Turn On But Once I Take It Out Again It Works Perfectly. Do I Need To Change The Settings?
No there is no need to change the settings. Your memory card is currupted. Please format the memory card in a computer or laptop and use it in your camera.
Hope it helps. Please rate. Thanks.
Jun 22, 2010 | Samsung Digimax S800 Digital Camera
Outside pictures are all white.
I've got the same problem as misred. Is there anybody who knows how to solve this problem? Is it the CCD?
Dec 27, 2006 | Samsung Digimax S800 Digital Camera
Samsung Digimax S800 Digital Camera Logo
122 people viewed this question
Top Samsung Cameras Experts
Jerry Z
Andy Bale
Andy Bale
Are you a Samsung Camera Expert? Answer questions, earn points and help others
