Question about ASUS WL-500W Router (WL500W)
Connecting 2 routers - ASUS WL-500W Router (WL500W)
  • Terrence Hyden May 11, 2010
    what about connecting 2 routers ???
    explain the problem please
  • 57 Answers
You can't have two router on a single network. You can cascade your two routers but only one will as a router and the other one will work as a switch.
you connect the second router to any of the LAN ports of the main router.
Posted on Jun 30, 2009
Laptop running 0n win 7 wont connect to router
1. you will have to designate the laptop or allow it to connect by entering it into the 3com router.
2. try connecting to the router via ethernet cord (that is connecting with a physical straight through cord) that came with the router.
If connected with this then you will have to go into the router via the IP set 192.168..0.1 depending on the router ip for loging in.
2. Go to the "wireless setup" and enter your MAC address for the laptop in the permissions list in the router. Instructions on how to do this is at the manufacturers site. Step by step.
3. Do the following step if instructions not found.
1.Log into router
2. Verify wireless router name( on the computer) >>> ( on/off)
3.Note router name you are connecting to.
4.. Check the laptop do ipconfig /all to see current IP adresses.
5. Set the laptop up in the router by WEP KEY or MAC address.
6.Note router name you are connecting to.
7. Move the laptop about 20ft away and try to log on to the internet.
This is for all routers to set up wirelessly.
Jun 19, 2010 | 3Com OfficeConnect Router
My Belkin n1 router disconnects from telstra every 2 hours - exac
This is a known problem with the Belkin N1 Vision Modem Router. The router keeps time by connecting to a Simple Network Time Protocol (SNTP) server every 2 hours. The solution is to go to www.belkin.com and download and install the pre-release firmware which is supposed to fix "A problem where the router could drop some connections on 2-hour intervals" among other things.
Sep 14, 2009 | Belkin N1 Vision Wireless Router
Need to network a wireless pc with a cable pc via router
man u have a router!!!!!!!!!
no need to share the connection
just configure ur router,
put ur broadband connection log-in information in the router
so the router will act as a gateway
and the router will start the dhcp server, so both of ur pc's will have ip's from the same subnet
when the router connects to the internet
the 2 pc's will do the same,
Jan 19, 2009 | Computers & Internet
Installing acces point
Yes, you can chain routers together if you'd like, however people who connect to the first router connected to the modem will not be able to see the people connected to the chained router. However, people connected to the chained router will be able to see the other people connected to the main router.
Steven
Jan 07, 2009 | Computers & Internet
Set up 2 wireless routers, 1st for printer, 2nd for internet
You should only need one wireless router for everything. The purpose of the router is to "route" multiple devices together. Your set-up should be something like this:
Modem connected to wireless router via Ethernet cable.
Wireless router broadcasting wireless internet connection.
Computer(s) connected to wireless router via cable or wireless adapter.
Computer with network printer sharing enabled.
Turn on wireless printer.
You should be able to detect the printer via Windows.
Sep 05, 2008 | Office Equipment & Supplies
3 netopia 2247 routers daisychained
How far are you running the CAT5 cables from house to house?   CAT5e only has a solid range of about 150ft, and anything near 100ft is pushing it.  You may also need to use CROSSOVER cables when plugging routers into other routers.
Also, who has the actual internet connection?  I'm assuming House 2 does.  One big problem is a router is your Gateway address.  And, if house 2 is the only one with a valid Internet connection (via DSL or Cable, etc), then the router in house 2 is the only "true gateway".  And, all 3 houses need to be in the same physical network (i.e. 192.168.1.0 range or whatever), and all computers should have the same Gateway address...which would be the IP address of the router in House 2.
What you really need in this situation is 1 router and 2 switches.  Put the router in House 2 and put switches in House 1 and 3.  That would be the best way to handle this problem.  It would also end your connectivity problems.
Cheers!
Jul 11, 2008 | Netopia 2247NWG-VGx Wireless Router...
3CRWER100-75 no DHCP IP on child routers
router 1 (base) router 2 (repeater) router 1 (base) is the network, the SSID is where u get your internet connection set router 2 with same SSID, DHCP on. i advise connecting hardline to make sure both routers are working correctly. once thats verified then go wifi
Jun 30, 2008 | 3Com OfficeConnect Wireless 11g Cable/DSL...
Router connections
If you have a laptop in home 2 that is able to connect with NO issues whatso ever I would almost think its a security issue... Do you use the same kind of encryption on both home 1 and 2? (ie WPA or WEP)
Dec 31, 2007 | Computers & Internet
How to connect linksys router with aztech adsl modem
To setup your router
first check..
Connect the Broadband modem to the computer using an Ethernet cable without the router installed and make sure that the Internet connection is active. If it is not, contact your Internet Service Provider. If it can go online,
to setup connection..
Step 1:
Connect the Broadband modem to the router’s WAN or Internet port.
Step 2:
Connect the computer to any available numbered port (1, 2, 3 or 4).
NOTE: In this example, we’ll connect the computer to port number 3.
Step 3:
Make sure the power adapter is plugged to an available power outlet.
Step 4:
check if you are able to go online wired..
if not your router has to be configured first,
to config your router i need some more information
your internet service providers (isp)name , and how many computers do u have totally..
Nov 16, 2007 | Computers & Internet
Open Questions:
ASUS WL-500W Router (WL500W) Logo
272 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
