Question about Star Logic 11000952 Mouse
Touch sensitivity I have a Starlogic trackball optical mouse and the main digit is far to sensitive - just lightly resting the digit finger clicks. Can the sensitivity be controlled through the software or is it mechanical and it is what it is?
    President:
  • 8,637 Answers
Not sure about your mouse but if you go to the Control Panel and click on the Mouse icon you can the adjust the sensitivity. Hope this helps. Bud
Posted on Jan 17, 2009
Where is pc settings/ calabrate located in lenovo c260
From page 21 of the user manual, "The monitor is touch-sensitive thanks to its touch-sensitive screen. A touch screen is an input device just like a mouse or a keyboard, and the user's fingers transmit position information via the touch screen to the computer. With this technology, you only need to touch the pictures or words on the computer display lightly with your finger, and the computer will react. Touch Screen Calibration Prior to first use or whenever the touch screen reacts in a different place where you are touching it, start the calibration program. The procedure is as follows: 1. In Control Panel, select "Hardware and Sound". 2. In "Hardware and Sound" window, select "Tablet PC Settings". 3. In "Tablet PC Settings" dialogue, click "Calibrate" button. User Gesture Instructions for the Touch screen The Touch screen supports single touch and rotational movements, enlargement and reduction multi-touch operations, and the user can transmit position information to the computer via touch. The touch screen uses a very low pressure movement recognition method, which only needs the finger to move lightly on the computer display screen or make a simple hand gesture to be detected by the main computer processor. 16 User Guide 31506537 C260 UG V1.0 (Win8.1)(EN)(R).indb 16 2013-12-6 11:54:06
Nov 30, 2014 | Lenovo C260 Touch 19.5 Pent 4GB 500GB
How do i adjust the sensitivity of my touch pad for my Toshiba laptop PSLB8U-05202F
1.Turn on the computer and log into Windows as normal. Open the "Start" menu and click on the option labeled "Control Panel."
2.Double-click on the icon labeled "Mouse.". The "Mouse Properties" window will open. Navigate to the tab labeled "Device Settings." Click on the button labeled "Settings." A window labeled "Properties" will appear.
3.Examine the left panel of the "Properties" window and expand the option labeled "Sensitivity." Click on the option labeled "Touch Sensitivity."
4.Reduce the touch sensitivity setting by moving the slider to the right, towards the "Heavy Touch" label. Experiment with different levels of sensitivity until you find one suited to your needs.
5.Click on the button labeled "OK" to close the "Properties" window; repeat with the "Mouse" control panel. Your new touchpad sensitivity settings are now saved.
Sep 14, 2011 | Toshiba Satellite L305-S5908 Notebook
Cursor is jumping all over the screen before you can point at what you need - Dell D620 - Windows xp pro
Firstly try a different mouse to find out if the mouse is the issue - If so a new mouse is probably needed (assuming you cleaned the trackball/laser - video instructions can be found below)
If the mouse is not the issue, then enter mouse settings on Windows XP, and try adjusting the sensitivity etc. This can be done by going to Start -> Control Panel -> Mouse and adjusting "Pointer Options"
If this fails, try downloading drivers for the mouse (assuming it is optical).
Mar 02, 2011 | Computers & Internet
I have a TOSHIBA NB100.The mouse pad is too sensitive .I can even move the cursor hovering my finger above it without touching the pad .I thinlk it causes words and letters to come out as a jumble. Is...
control panel----Mouse----Should bring you to a screen with several tabs at the top-----pointer options tab---Select a pointer speed this should slow down the mouse movement----then go to the first tab (touchpad) and you can change the touchpad sensitivity. Hope this helps
Jan 07, 2011 | Computers & Internet
I have a Dell laptop computer with Windows Vista Basic. The mouse on the screen has become very sensitive and sometimes it clicks on an item when it scrolls across the screen. How can I make it less...
  1. Right-click on the desktop and select Personalize > Mouse Pointers . The Mouse Properties settings window will open.
  2. Alternately, click Start and type Mouse in the Search field, and select Mouse when it becomes available in the program list. The Mouse Properties settings window will open.
  3. Select the Device Settings tab. Select the Synaptics TouchPad device and click Settings . In the Properties for Synaptics TouchPad window, expand the Sensitivity topic.
  4. Select the PalmCheck option to adjust the sensitivity of the touchpad to avoid erratic cursor movement caused by accidental touching of the pad during normal typing.
  5. Select the Touch Sensitivity option to adjust how much finger pressure is required to move the mouse on the screen and how responsive the touchpad is to taps.
Jul 12, 2010 | Dell Vostro 1000 Notebook
Track ball requires multiple press to get it to do anything
Hi, to change the trackball or trackpad sensitivity of the BlackBerry smartphone, complete the following steps:
1) On the Home screen, go to Options > Screen/Keyboard.
2) In the Trackball or Trackpad section, click Horizontal Sensitivity or Vertical Sensitivity to change the sensitivity level.
3) Press the Menu key and select Save. The new sensitivity levels are saved.
A higher sensitivity number indicates a higher sensitivity level for the trackball or trackpad.
The trackball user interface found on certain BlackBerry smartphones is similar to the trackball used in a mouse in conjunction with a desktop computer.
In the event debris comes in contact with the trackball and affects the usability of the BlackBerry smartphone, rapidly roll the trackball up, down, left, or right to potentially correct the problem.
If rapidly rolling the trackball does not correct the problem, please contact your wireless service provider for support options.
Try to re-install the BlackBerry Device Software using the application loader tool, before you re-install the software please back up the BlackBerry smartphone data.I hope this information will be helpful to you
Nov 19, 2009 | AT&T Blackberry Curve 8300 Smartphone
Acerr Aspire 5315-2940
I don't know if you mean that your cursor suddenly moves as you are typing? If so, it is likely your touch pad is too sensitive. I have a mouse w/mouse pad but never disabled the touch pad. So i disabled the touch pad and it solved it for me. If you want to be sure it is the touch pad being over sensitive, then type a paragraph but keep your fingers and palms far away from the touch pad. If the problem improves, like it did for me, then the touchpad is too sensitive. You can go into the settings for the touchpad to change the sensitivity setting to make it less senstive and see if that works and it does not then press Fn +F7 keys to disable the touchpad.
Aug 26, 2008 | Acer NSK8458AN Keyboard
Logitech 4 button trackball,
I love this trackball mouse, yet they are very sensitive to wear and trash that causes them to fail. Wal-Mart sells great ones like the Logitech LX3 optical mouse that are not as sensitive and have more features
Oct 22, 2007 | Logitech Marble Mouse Trackball
Doesn´t work with pro/engineer (panning an zomming)
Oct 01, 2007 | Logitech Marble Mouse Trackball
Logitech Marble Mouse 904360-0403
Jun 19, 2006 | Logitech Marble Mouse Trackball
Star Logic 11000952 Mouse Logo
60 people viewed this question
Top Star Logic Computers & Internet Experts
Jerry Greenberg
Jerry Greenberg
Jerry Umali
ray gallant
Are you a Star Logic Computer and Internet Expert? Answer questions, earn points and help others
