Question about Samsung Televison & Video
My Samsung SM2032MW seems to have become locked on 1 analogue channel no matter which channel buttons I press. Works fine when I switch to digibox input.
Neto
  • 123 Answers
SOURCE: Motorola Talkabout T5500 Menu button doesn't work
I think you radio has a problem and will need to be checked, rapaired or replaced.
Posted on Dec 16, 2006
SOURCE: I am trying to fix a Sharp 27k-s100 television.
Can you use the remote control to change the channels? If not, it may be that to need to reprogram the remote to work with your TV. I just had the same problem. I have GE universal remote and have reprogrammed it to work with my SHARP 27k-s100 TV by following these instructions: http://www.ehow.com/how_9190_program-ge-universal.html The code that worked for my TV is 173. Other codes listed for SHARP are: 004, 006, 012, 029, 095, 111, 112, 113, 122, 171. Good luck!
Posted on Sep 11, 2007
SOURCE: DVB not working on panasonic
Check the arial cable - not just the connections. Problem noted was due to an inferior cable that was not up to the job. It also ran alongside a central heating radiotor and pipes - not a good combination apparantly!
Posted on May 05, 2008
SOURCE: Connecting Digital Decoder to Analogue TV.
The av channel is 0 and then you need to search on channel 0 as i mean tune into the channel
Posted on Sep 14, 2008
marketex
  • 371 Answers
SOURCE: Denon AVR-1403 receiver switched from digital to analogue.
There are three modes (Auto, DTM, and PCM) on the input mode switch, on the main unit, selected by repeatedly pressing the input mode switch.
However, if you have already depressed the Analog button in, on the main unit you have predetermined the mode as analog.
On the remote, the INPUT MODE switch combines toggles for 5 choices, [Auto, PCM, DTS, Analog,
Ext. input]
My guess is that either the input mode switch on the main unit and/or the remote are toggled to analog.
Posted on Apr 11, 2009
I have a p42ho1au plasma can't pick up digital channels do I have to reset it ?
From what I can find out, this television would seem to be an analogue television, and would therefore require a digibox to receive digital television.
Feb 13, 2015 | Televison & Video
Can't get Digital TV (freeview)
Change the input to antenna.
If it says cable:
On your Samsung remote is a button that says antenna. You want it to say AIR. Air is an ATSC tuuner that allows you to receive over the air HD with a pair of rabbit ears.
If it says AIR:
If it says AIR and you still can't get the HD channels. In the menu it will say Channel. In that sub menu it will say autoprogram. Make sure you have an antenna connecte to AIR in the back of the set and autoprogram AIR only.
Any questions respond to this post and I will respond.
Jan 12, 2008 | Samsung LE32R74BDX 32 in. HD-Ready LCD...
Sky box green light on permanent
Sounds as if the software is corrupt. Try a forced software update...
1) Switch the digibox off at the mains power, so no lights are displayed on the unit
2) Press and hold the BACK UP button on the digibox (not the remote control)
3) Whilst holding, switch the digibox back on at the mains power so the red standby light is displayed
4) Wait approximate. 10-20 seconds for the remaining 3 lights to display, at which point you can release the BACK UP button
5) Allow the digibox to download the latest software, which can take 10 minutes before returning to standby
6) Leave 60 seconds then power up as usual
A software update/refresh will leave your recordings intact. You won't lose anything.
If this doesn't solve your problem, then the next step is more drastic. It's a Full System Reset and Planner Rebuild. Be advised though: Your recordings are at risk!
1) Switch your digibox on
2) In sequence, press on your remote 'SERVICES > 4 > 0 > 1 > SELECT' (this will access the hidden menu)
3) Select the relevant option (usually the bottom two) and follow the on-screen prompts (note that it's likely your digibox will reboot between processes)
Applies to Sky+HD Digiboxes only, running latest EPG
1) Press Services on your remote control. 'Options' in the Top Menu will be highlighted in orange.
2) Press the Right arrow once to highlight 'Settings' in the Top Menu.
3) Now press the Down arrow once to highlight the 'settings' tab in the Middle Menu.
4) Press 0, 0,1, Select on your remote in quick succession. The 'Setup' tab will then be highlighted within a hidden menu.
5) Select the relevant option and follow the on-screen prompts (note that its likely your digibox will reboot between processes)
Sky Digibox Planner Rebuild / Full System Reset (if stuck in standby)
Applies to Sky+ and Sky+HD Digiboxes only
Same as above, but applies if your digibox is stuck in standby and you cannot get to the hidden menu:
2) Press and hold the 'right and left arrow' buttons on the digibox (not the remote control)
4) Wait approximate. 30 seconds for the blue Sky+ ring of lights to display, at which point you can release the 'right and left arrow' buttons
5) Press 'SELECT' on the digibox (not the remote control)
6) Now the system will format the hard drive, the blue Sky+ ring of lights should spin backwards
7) Allow the system to format, which can take 10 minutes before returning to standby
8) Try to power up!
Sep 02, 2014 | Televison & Video
We have a Funai analogue tv and a Sony analogue DVD recorder, we need to know how to connect them using 1 or 2 digiboxes.
If your TV and DVD recorder have two SCART sockets each, then you can connect the two boxes to the second scart of each device. When recording the channel selected will have to be AV2. If either of them hasn't a second scart socket. Then I suggest you get one of these scart switching boxes from places such as Amazon.
The buttons on the unit will allow you to record, whilst still watching the TV. 12_17_2012_5_01_21_pm.jpg
Dec 15, 2012 | Televison & Video
Tv seems to be locked, cant access the program settings has it got a hotel lock?
hi,
u can remove the lock by fallowing settings.
1. press menu button and select channel and press enter.
2. select channel manager and press enter.
3. select channel lock then press enter.
4. select off and then press enter.
ok
Dec 15, 2010 | Samsung LA22A450 22 in. LCD TV
TV works fine on analogue however won't work on digital even when re scanning. When it happened the television froze and then wouldn't work. Now all is has is "no channel available. Please scan" do you...
Power the TV off and uplug from the mains, now remove the aerial, now press the standby button the TV, now plug the mains back in and switch to a DTV channel, wait 5 secs and then put the aerial back in whilst still on that channel, now rescan.
If that didn't work, reset the TV to factory defaults and rescan again.
Thanks
Oct 08, 2009 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
DVB not working on panasonic TX26 LXD52. Can't change channel nor access any menu's, guide etc when in DVB mode. Analogue tuner and av functions working fine. Remote works fine in analogue mode with...
Apr 30, 2008 | Panasonic Televison & Video
DVD Set up
If it's the Espejo 311i model (mine was £30 from Morgan) I don't think you'll have any joy trying to select channels direct from the unit. Mine works fine with a Freeview box but channel selection is strictly on the latter, then the SCART goes into the recorder's No. 2 socket (No. 1 goes on to the TV). You can record whatever the box is receiving by selecting 'EXT2' as the source. Even if you never record analogue it's a good idea to plug an aerial feed into the Mico so it can set its clock. Note PDC doesn't work (for me anyway) when recording via the SCART. If someone has set it up strangely you can reset from scratch by unplugging, holding the front panel On switch in, then reconnecting to the mains while keeping the button pressed until the first setup screen appears on your TV. It will auto-tune to any analogue signals it finds on the aerial input. I could probably scan at least some of the manual if you are really stuck.
May 10, 2007 | Mico DVDR310 DVD Recorder
Televison & Video Logo
Jerry Greenberg
Jerry Greenberg
