Question about Toshiba 32A41 32" TV
Monster cable pulled off connector
Hi Monster cable connected so well to the rca style jack for one of the component video connectors that it has pulled out the metal sheath of that connector from the back of our Toshiba 32a41 tv. Are these soldered or crimped into place? I see no evidence of solder. Connector still works if pushed back in. How does one remove the back to access. It looks as if the connection area on the back can be removed without taking the entire back off? Thanks O
  • 81 Answers
They are soldered in behind
Posted on Mar 20, 2007
How to hookup a bose 321 to a toshiba 58l7300 tv
The Bose system does not appear to have HDMI output. The best-quality method would be to use Component (RGB) cables with analog audio. One RCA pair will be for audio and these are often RED & WHITE connectors, but don't have to be. Any RCA pair will work. Connect these to the Bose RED/WHITE jacks found in the "TV" labeling. Connect the other ends to the Toshiba's RED/WHITE jacks on the bottom row, first two jacks.
Now you need a Component cable. This has three RCA connectors at each end and are traditionally RED, GREEN, and BLUE. Again, colors do not matter as long as you connect the ends so they match. Under the "Component" labeling on the Bose, you will find the three colored jacks. Connect these to the Toshiba's same-colored jacks which are next to the RED/WHITE ones you used previously. These three connectors carry the video signals. They will transfer Hi-Def 1080i signals, not 1080p, but you wouldn't be able to tell the difference.
Switch the input on your TV to "Component".
Dec 29, 2013 | Toshiba Car Audio & Video
Ducati monster wont start
Hi, Anonymous and the usual suspects are:
1. Ignition Switch not in the "ON" position.
2. Engine Run Switch in the "OFF" position.
3. Discharged battery, check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
4. Bank angle sensor tripped and ignition/light key switch not cycled to the "OFF" position and then back to the "ON" position.
5. Faulty starter button/switch.
6. Faulty jiffy stand or clutch pull in switch/sensor.
7. Security alarm needs a reset.
8. Starter control circuit, relay, or solenoid faulty.
9. Electric starter shaft pinion gear is not engaging or over-running starter clutch slipping.
For more information about your issue and valuable free downloads that you will need please visit the websites below. Good luck and have nice a day.
2005 Ducati Monster 620 Wont Start
http://www.ducatimonster.org/forums/tech/205386-2006-monster-620-wont-start-just-clicks-when-i-press-start.html
2004 2006 Ducati Monster 400 620 Motorcycles Service Repair Manual Highly...
Ducati OEM Parts Fiche Lookup and Online Ordering
Ducati Maintenance
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Dec 20, 2012 | 2002 Ducati Monster 620s i.e.
Hello, my Monster 1000 ie does not spark plugs. Gasoline, either. Starter, fine. Please some solution to this problem. Thanks
Hi, Guxiarapa and the usual suspects are:
1. Fouled spark plugs.
2. Discharged battery, check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
3. Loose connection at ignition coil or plug between ignition sensor and module.
4. Spark plug cables in bad condition, shorting / leaking, spark plug cable connections loose.
5. Faulty ignition coil or ignition / electronic module
6. Failed CKP, CMP, or BAS sensor.
7. Faulty ignition switch.
8. Security alarm failing to disarm needs reset
For more information about your issue and valuable free downloads that you will need please visit the websites below. Good luck and have a nice day.
http://www.ducatimonster.org/forums/tech/196908-i-am-also-having-no-spark-issue-please-help.html
1995 Ducati Monster 600 carbed Cranking no spark Tried everything
Ducati Monster S2R1000 2006 2008 Full Service Repair Manual Download...
Ducati Maintenance
Feb 05, 2011 | 2005 Ducati Monster 1000S
2005 ducati monster 620 will turn over but not start
Hi, Corydurham50 and the usual suspects are:
1. Fuel tank empty.
2. Fuel supply valve/petcock turned off.
3. Fouled spark plugs.
4. Engine flooded as a result of overuse of the enricher.
5. Vacuum hose to the fuel supply valve/petcock disconnected, broken, cracked, or pinched.
6. Fuel valve/petcock or filter clogged.
7. Discharged battery, check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
8. Loose or corroded wire connection at the coil, battery or plug between ignition sensor and module.
9. Spark plug cables in bad condition and shorting, cable connections loose, or connected to the wrong cylinders.
10. Ignition timing incorrect due to a faulty ignition coil, ignition module or sensors (MAP, CMP, CKP, O2 and/or BAS).
11. Security alarm needs a reset.
http://www.ducatimonster.org/forums/tech/209511-monster-620-dark-turns-over-long-time-but-wont-start.html
Ducati Maintenance
Dec 25, 2010 | 2005 Ducati Monster 620
Monster connectors not like cable connectors
You were sold an HDMI cable. You need a coax. Wrong cable.
Jan 18, 2009 | Monster Cable (305007B)
Jvc hd 100 camcorder
The Video Output Jack Assembly Board is the part you are looking for. Please see below for a link to purchase this item.
GY-HD100 Video Output Jack Assembly Board VJK
Mar 11, 2008 | JVC GY-HD100 Mini DV Digital Camcorder
Cant disconnet it
all you have to do is unscrew them and then pull them out
Nov 30, 2007 | Monster Cable (109611)
Toshiba 32A41 32" TV Logo
67 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
