Question about Ariston Technologies Ariston FO98P Stainless Steel Electric Single Oven
Ariston oven - when i turn it on the following code appears f4E0
Have turned the cooker on and off again same thing happens.
Cannot operate anything
2 Suggested Answers
SOURCE: Ariston oven error code F8E0
solved by rotate the temperature knob!!!
maybe would be a problem of the potentiometer or knobe of temperature
Posted on Nov 22, 2009
Hi, I've tried to programme my cooker on auto following the instructions, everything works apart from when the time comes to turn the oven off automatically it doesn't work. The buzzer goes...
Are you sure it's the oven still running and not the built in cooling fan...next time look at the fan at the rear of the oven if it's not turning it's off and you will be hearing the cooling fan
Oct 08, 2017 | Ovens
Ariston wall oven error code f53 f03
I managed to resolve that problem. When you have BOTH F53 and F03 error codes, it's not a sensor fault (although F03 is the big cavity sensor and F53 is the top one)... it's a faulty capacitor trouble. On the main board there are 4 electrolytic capacitors, just replace all of them and you're ok again. It's quite simple and very cheap. :-)
Nov 26, 2013 | Ariston Technologies Ovens
Hi Experts! I'm having problems with my Ariston FO87CIX oven. The oven turns on but if I try to set the temperature the oven turn off and the time resets. It's weird but I've worked out that any...
One of 2 things, either the pt100(sensor) is faulty, or the control is defective. Unfortunately you need a digital multimeter to check the sensor first. When in doubt, replace both and all will be well.
Sep 09, 2010 | Ovens
My neff oven error -5-. How do i turn this off?
I also had an error 5 on my Neff B1691 cooker. This indicates that a child lock has been set. To unlock you just push and hold the central control button in for about 7-8 seconds. Do the same again to set the lock again...
Mar 21, 2010 | Neff B1421 Electric Single Oven
Oven keeps tripping mains
If it is a electric oven, then the chances are it is the oven element that is causing the problem.
What is probably happening is that as the element gets hotter, the insulation resistance is breaking down, and causing the trip to operate
Hope this helps.
Feb 02, 2010 | Whirlpool Ovens
Oven stopped heating - F34 displayed.
You get F34 error because there is excess heat within the oven.
You need to clean the cooling fan for any debris or dust, if this does not solve the problem replace the cooling fan.
Hope this helps.
Thanks for using Fixya.
Dec 15, 2009 | Thermador C301U Electric Single Oven
Ariston Technologies Ariston FO98P Stainless Steel Electric Single Oven Logo
456 people viewed this question
Top Ariston Technologies Ovens Experts
ashburton
Dan Webster
Dan Webster
Are you an Ariston Technologies Oven Expert? Answer questions, earn points and help others
