Question about HP Photosmart 7450 InkJet Printer
My photosmart printer is saying out of paper, but the paper tray is full. Printer will not grab the paper
  • 55 Answers
A detailed trobleshooting procedure for the error is given in this link...
Posted on Nov 22, 2008
Hp photosmart 3110 keeps saying it is out of paper - -it isn't!
Some printers do not register one or two sheets of paper. Be sure to insert paper all the way in to the paper sensor. Check your tray selector as it may be set for small 4x6 or 8 1/2 x11. If the 4x6 is pushed into the forward position it will not allow access to the full size tray. Try rebooting the printer. If it is still not working correctly, delete the printers drivers and reinstall them.
Mar 01, 2011 | HP Photosmart 3110 All-In-One InkJet...
I cant get the machine to grab the paper and it says its out of paper, yet its not out of paper.
Hi, the Ip3000 has 3 different feeding trays...
make sure that the printer is trying to "grab" the paper in the tray that you have chosen to use in the printer properties box...
when you give the print command can you see the rubber roller moving to grab the paper in the top feeder tray???
if the roller that feeds the printer is not moving you may have accidentally changed the settings to grab paper from the bottom tray...the one right under the door that opens to let printed pages out of the printer...
the 3rd feeder tray is the DVD/CD printing tray...
I suggest that you look at the printer Properties for remedial action...
hope this helps you with your problem...
suggest you place paper in the bottom tray before making adjustments to see if it is trying to grab the paper from there...
Dec 08, 2009 | Canon PIXMA iP3000 InkJet Photo Printer
My HP 2575 Photosmart all-in- one will not feed paper. Message says out of paper when it is full of paper
there is paper feed sensor inside the printer. make sure it is there and not broken off. the sensor is in the back center of the paper tray, and is spring loaded. if you can't find it, shake the printer with the paper tray facing down to see if a black piece of plastic falls out. the printer will also have this error when the printer cannot pick up the paper. clean the rubber roller with "rubber renew". you can use rubbing alcohol but rubber renew is recommended. the roller is often full of dust and fine paper debris.
Nov 15, 2009 | HP Photosmart 2575 All-In-One InkJet...
Can't print on photo paper from iphoto
When running a piece of photo paper through the printer you must first remove the stack of regular paper from the tray and run only one photo paper at a time. Thank you, Dana
Oct 08, 2009 | HP Photosmart C6180 All-In-One InkJet...
Hp photosmart pro B9180 does not sense paper
Hello sir; You need to clean paper pick up roller, and rubber pad(right underneath the roller) as well as paper sensor.
Jan 12, 2009 | HP Photosmart Pro B9180 InkJet Printer
Easyshare 500 printer
Be sure the paper tray is full.  Though not a satisfactory solution, I've found the little steel tab that lifts the paper up to be grabbed by the roller just doesn't lift it far enough.  I keep the paper tray full.  Now I only have the problem if I let the tray get down to only one or two sheets.
Dec 11, 2008 | Kodak EasyShare Photo Printer 500
Hp 3310 paper feed
Take off the back of the printer - there is a door running almost the full length which has a latch. Using regular rubbing alcohol and a Q-TIP(R) cotton swab, clean the little rubber rollers which grab the paper from the tray. The rollers you need to clean will be low and on the left as you look at the back of the printer and they are about 2 inches inside the printer. There are 2 of them. Paper dust builds up on them and they fail to grab the next sheet of paper, causing the error message. Works every time!
Sep 14, 2008 | HP Photosmart 3310 Printer
Constant "load paper in tray" error even when paper is loaded.
Contacted HP CEO, office getting some interest now!
Re bad paper feeder Did not use main tray feeder until now!
Nov 30, 2007 | HP Photosmart 3310 Printer
Hp photosmart d7160
hp photosmart d7160
how can i print 4x6 photo paper ? it says load paper in the main tray its only printing with large plain paper , even if its set to photo tray , and if i put the 4x6 in the main tray it says wrong paper zize ...
Nov 10, 2007 | HP Photosmart D7160 InkJet Printer
Printer cannot grab paper,
The rollers in these printers go bad all the time. Your best solution would be to take it to a local printer shop and get the rollers replaced.
Jul 19, 2007 | HP Photosmart D7160 InkJet Printer
HP Photosmart 7450 InkJet Printer Logo
53 people viewed this question
Ben Johnson
