Question about Philips 34PW9817 34" TV
Tv shuts off by itself
IT'S A PHILIPS MODEL 32PT6441/37 TELEVISION.
IT SHUTS OFF FREQUENTLY BY ITSELF.
WHILE IT'S OFF IT FLASHES A GREEN LIGHT IN A SEQUENCE OF 1 QUICK FLASH ,1 LONG FLASH ,AND 11 QUICK FLASHES REPEATEDLY.IT TAKES AT LEAST 10 SECONDS FOR THE SCREEN TO APPEAR AFTER TURNING IT BACK ON. I'VE UNPLUGGED IT FOR 6 HOURS AND IT DIDN'T FIX THE PROBLEM.PLEASE HELP AS I'VE BEEN BORED ENOUGH TO ACTUALLY COUNT THE BLINKS.THANK YOU!
    Top Expert:
  • Philips Master
  • 75,774 Answers
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
http://homenol.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "brand name" to your device, [Exclude the model number] in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Counting of number of blinks to Philips TVs is entirely different to that of other brand TVs. It is not a direct count procedure. The site have details about how to count the number of LED blinks [Fault Codes] to Philips brand TVs are given; along with details of the faulty circuit location.
Posted on Jul 15, 2017
SOURCE: Philips 34PW9817 34" Shouts off and red light continuously blinks
I am having the same problems with my 34PW9817. I spoke with someone at a Philips service depot today regarding the problem and they suggested that I unplug the unit and leave it that way overnight. The tech told me that more often that I would expect, this solution fixes the problem. They mentioned something about this allowing the microprocessor to reset itself. If that doesn't work then I am supposed to expect a repair of between $210 and $265 for problems relating to the power supply. The backlog on getting the unit in and out of the service depot is about 5 days for my area (Denton, TX). I am planning to try the reset tonight but do not expect this to really do much. The problem didn't start until my last move (San Antonio -> Dallas) and other than this, I have had excellent service and picture quality out of the unit. Will update this post after I rectify the problem. David
Posted on Mar 13, 2007
  • 1694 Answers
SOURCE: philips 32PT6441/37 32"
Install horiz driver kit # 483531057673 and replace 47mf/25v
capacitor in horiz drive circuit. Fix applies to all L04.01U chassis.....................................T.
Posted on Nov 25, 2007
  • 48 Answers
SOURCE: Phillips 32PT6441/37 32 Inch Screen / Power problem
I fixed this very problem several times on this set. You must check some parts and, if bad, replace them correctly and safely. I can tell you what to look for for a small cash fee, but I don't know how this works on this site.
Posted on Jan 28, 2008
  • 1779 Answers
SOURCE: Philips 30PW8420/37 TV Won't Turn On
The led code indicates vert failure for one. ( 3 blinks )
The 2 blinks indicates excess beam current of which could be your picture tube or re-adjusting the G2 voltage on the HV transformer which is very critical on philips sets.
Posted on Apr 10, 2008
SOURCE: red light flashes
This is a well known and very common problem with all Philips plasma tvs 42 and 50 inch. The problem is they used under rated capacitors in the power supply. If you have electronics experience or a friend that is, remove the cover and look in the back for malformed or leaking capcitors. Replace them and see if that takes care of the problem. The caps only cost $2 or $3 each, so the cost to try this is pretty reasonable although you might have an added cost of buying beer for your electronics friend. If this does not fix your problem you are down to replacing boards that can be purchased around $300 ea.
I have found my set will come on "finally" after I get the back of the set warmed up and the bad caps finally charge up. Hope this is useful.
Posted on Feb 27, 2009
My panasonic pt-521cx16 starts, green light flashes, then shuts itself off again
Have you even replaced the bulb / lamp on this TV - other than the green light - did they turn solid red / orange at any point? My initial thought is you need to replace the bulb.
Jan 22, 2018 | Panasonic PT-52LCX66 Projection Television
Our 50" plasma has a
The television shuts itself off and the light blinks in the front to protect itself when something is wrong with it. It will come back on a few times when unplugging and replugging but by doing that and not getting repairs done it has gone into a coma and will most likely not turn on again until it has been serviced. You can try leaving it unplugged for several days to see if you can get it to come back on.
Nov 29, 2010 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
When I power up, 5 seconds later this back projector TV turns itself off
t does sound like a bulb problem, either its over heating and shutting off to protect itself, or its already shot. Give a TV repair shop a call and see if they can give you an approximate price, then decide to ditch or repair it.
May 30, 2009 | Televison & Video
T.V. will shut itself off, power light flashes
my toshiba tv shuts itself off after about an hour or so
Jan 18, 2009 | Toshiba TN55V71 55" Rear Projection...
Green flashes then tv turns off
or a new lamp. you could first replace the lamp.
the screen might work fine for a couple of seconds, but then it fades away or deteriorates. This means the lamp is going bad.
Aug 23, 2008 | Sony KP-51HW40 51" Rear Projection...
Green flashes and shutting off
I went to the Sony web site and there is a recall i believe for that problem. The one year warrenty was extended to an additional three years for that.
Dec 15, 2007 | Sony KP-51WS500 51" Rear Projection...
Philips 34PW9817 34" TV Logo
66 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
