Question about Canon Digital Rebel XT / EOS 350D Body only Digital Camera
Blurry photos of indoor sports
I'm in Program mode, ISO speed at 1600 - most shots are blurry; auto flash set to "on" . (Some gyms are bright enough I don't need a flash, but others are dark so I bought a flash attachment)
  • 1 more comment
  • Anonymous Dec 22, 2008
    Takes great sports shots outdoors but when i take it inside with the same setting it takes blurry pictures with a tail behind the person
  • rpoir Jan 11, 2009
    I have the same problem - spring baseball photos are awesome. Fall baseball (it gets dark earlier), baseball under the lights, or indoor soccer photos are blurry!
  • sucipto_harj May 11, 2010
    hi just wodering, what is aperture and speed that you setup? lense that you use? any IS feature on the lense? since its not only about ISO
markevans
  • 148 Answers
SOURCE: CANON Rebel RTI Outdoor pictures are dark
learning to use light metering correctly can have its challenge.
the manual will guide you on how to set up to read light from the subject. spot metering a dark area will cause general overexposure, or a washed out look. spot metering a bright area will cause a dark image. if you are on spot meter and shoot two people standing together against a bright lit background, your meter will see between them if they are centered, and read all that bright background, setting the camera to a less sensitive combination of aperture / shutter speed, resulting in a dark image. use field averaging meter setting and be sure you are metering the subject and not the background. try shooting a wall that is fairly clear of other colors and uniform it light hitting it, you should have a correctly exposed image. since it works in other modes (at least 1, anyway) then it is unlikely you have an exposure compensation issue. that is the only other non defect issue that would cause your problem.
once you confirm that you have these settings correct and still get a dark image, its time to have it serviced.
good luck
mark
Posted on Dec 24, 2007
  • 155 Answers
SOURCE: Blurry photos that are really frustrating!
Evening & Indoors? The kit lens is really going to struggle here. Your only immediate solution is to use ISO 1600 which makes the shutter faster but adds a little noise to the pictures.
You really want to get a better lens for indoor work. If you need cheap, try the 50mm f1.8, it's a prime not a zoom, so you will need to use your feet to "zoom" but it's incredibly good for indoor / low light work.
I upgraded to a 17-55mm f2.8 IS, it was rather expensive but I have never had a blurry indoor shot since - I do also use an external Speedlite flash with it though, which also helps tremendously.
It's an expensive hobby!!
Posted on Feb 26, 2009
Gurudristi
  • 98 Answers
SOURCE: Underexposed image on Auto mode
You can change the ISO setting also to Auto. If you have the advanced guide (see pp 80, 107).
Press the ISO button it will switch from various ISO setting to AUTO.
Do remember in Bright light , a lower ISO number like 80 will give you very fine images, while as the light level goes down, the ISO number will change to a higher number and the image will become more grainer.
I hope I could answer to your query.
Please do rate. Thanks
Posted on Feb 27, 2009
  • 157 Answers
SOURCE: Z740 cannot focus on long-distance indoor shots
Have you tried changing the mode? ie portrait, closeup, macro etc?
Posted on Jun 19, 2009
pixeldawg
  • 71 Answers
SOURCE: when on sports setting, my camera shoots slow and
More than likely, your exposure- specifically your shutter speed settings- are too low. When you have fast action, you must have a higher shutter speed (Higher, meaning that the DURATION of the exposure is less. So, an exposure of 1/250th of a second is more desirable than an exposure of 1/30th of a second when shooting indoor sports. (This difference equates to about 400% more exposure, duration-wise). When shooting sports indoors, a "Fast" lens, meaning that the front of the lens is bigger, which allows more light into the camera at one time. (This normally equates to "F-Stop" settings. So, a 50mm F1.4 lens will be a "faster" lens than a 50mm F2 lens. The lower the F number, the "faster" the lens. This also equates to higher prices...) Another consideration for shooting stop-action sports photography indoors is using higher ISO settings. When you double the ISO number, you cut the amount of light required to make a good exposure in half. So, ISO 200 requires half the light of ISO100, and 400 requires half the light of 200 and so on. Typically, I use a setting of ISO 800 or higher for indoor sports (Which, BTW is my speciality...). The trade-off for using higher ISO settings is that it introduces more noise into the image, which many people find less desirable. I also wrote a few articles for POPULAR PHOTOGRAPHY & IMAGING about shooting sports. The "football" article will more than likely be the most help to you. Basically, ALL sports photography is shot the same way, and if you use these techniques, your work will greatly improve. Here is a link to those, and hope they help!
http://www.popphoto.com/Blogs/Sports-Photography
http://www.popphoto.com/Features/Shooting-Talladega-Superspeedway
http://www.popphoto.com/Features/How-to-Photograph-Football
Posted on Jul 10, 2009
Why are my photos washed out when taken outside?
Check that your settings are on auto - to get the best in/out pics
Sep 20, 2014 | Canon PowerShot G3 Digital Camera
I'm using the sports mode and all my shots are blurry and orange
It may just be too dark for action photography. Try turning your ISO up to 1000+. Set your computer in Tv (Time Priority Mode). Use the top wheel to adjust the shutter time to something like 200 or greater. Keep an eye on the aperture value. If it starts flashing, you don't have enough light to support your settings.
Aug 12, 2012 | Canon EOS Digital Rebel XS / 1000D IS...
I have a Nikon d200 and need to take sports photos in a basketball court The sport is very fast moving. What should I set the camera to. Lately the photos are dark and or blurry
You want the fastest shutter speed you can get and the largest aperture possible.
If you're close enough and it's allowed, use the flash. The flash will freeze the action. However, it's likely to give you a dark background instead of a blurry background.
If not, use the Aperture Priority mode. Open the lens to its maximum aperture (smallest f/number). This will give you the fastest shutter speed for the existing lighting conditions. The fast shutter speed will freeze the action and the large aperture will blur the background, though the amount of freezing may be limited if the lighting is relatively dark, as in a high school gym.
Be aware that if you're shooting indoors you're going up against the laws of physics. The human eye can adapt much better than any camera. A high school gym will appear light enough once you've been inside for a few minutes, but it is much, much darker than a bright day outdoors.
Apr 28, 2012 | Nikon D200 Digital Camera with 18-200mm...
My Rebel XT automatic sport mode photos are all blurry. I noticed that the shutter speed only reads around 13. There is also a pause indicating a slower shutter speed. Any suggestions?
There isn't enough light for that scene. 1/13th of a second is the fastest at that ISO (automatically set by camera in Basic Mode) and Aperture (auto set by camera too, in Basic Mode) that the camera can handle to provide a reasonably exposed image. Try using Tv on the Mode Dial, set a higher ISO (trade off is image noise) of around 800-1600 or even 3200 if available on your camera. Set shutter speed at 200-1000 (1/200th to 1/1000th of a second) and see if it freezes your subject. An external flashlight with hi-sync mode would help in this situation if the subject is not too far away.
Dec 16, 2009 | Canon Rebel XT / EOS 350D Digital Camera
I have the Nikon D60 - Ive taken sport/action pictures
The main difference between the two shooting conditions is the amount of light you have to work with. For the indoor action shots, set the ISO setting to the highest available through the menu (1600 ISO) to maximize the ability of the camera to work with the diminished light. The other (but more expensive) way to achieve better indoor shots is with the use of a "faster" lens, ie one with a lower maximum f stop number (f2.8 is faster than f3.5, for instance). Also ensure you are shooting with your lens at its widest f stop setting (lowest number).
Jul 26, 2009 | Nikon D60 Digital Camera
Blurry indoor results- using flash
Built in flash units on digital cameras are only meant to be used out to a distance of 6-12 feet. When taking photos of events ie graduations, sporting events, concerts you need to do two things. 1). Change the ISO setting on your camera. This is the same as the old film speed ratings the higher the number the more sensitive the camera becomes. try ISO 1600 or above in low light. 2) You have a mode setting, set it for the type of lighting that is in the space you are in, incandescent, flourescent or whatever, it's easy to do. and finally 3) Turn off your flash! When your flash is on your camera closes up the aperature and takes the picture at a higher rate of speed in anticipation of reflected light off of nearby objects, so your pictures will be darker and blurrier with the flash on.
Even high grade professional flashes only work out to 20-30 feet so they won't help you. Read your cameras manual on taking pictures in low light conditions. It will give you all of the above in great detail. You have a great camera but you need to learn how it works, don't give up on it.
Jun 02, 2009 | Sony Cyber-Shot DSC-H1 Digital Camera
Nov 04, 2008 | Canon EOS 400D / Rebel XTi Digital Camera
Adjusting light??
Did you check your settings? You may be outside of the range (red figures for speed and or f stop) in your selected mode, for example if you selected 1600 ISO for indoor shots and forgot to set it back to a lower ISO value.
Alternatively you can use AUTO mode, it's the most foolproof.
If you selected 1600 ISO don't forget, when you change the ISO to a lowe value, also put the camera back in high resolution, it stays in 1MP mode by default.
HTH...
Jul 07, 2008 | Fuji FinePix S602 Zoom Digital Camera
Blurry indoor photos C-750
Use A mode and set the biggest aperture you can set (f3.5 ?) this this will then allow the camera the fastest shutter for the availbe light. In low light conditions this still may onlt be 1/4 sec which is still to slow for hand holding a camera. Best you turn your flash on huh.
Sep 12, 2005 | Olympus Camedia C-750 Ultra Zoom Digital...
Having problems with the flash\ blurred and grainy images
You should not use the flash for these shots (unless you connect a powerful external flash), it won't help you at this distance. You should use the shutter priority mode and experiment with shutter speed (no flash) to get the best result - for sports action it should probably be faster than 1/100 sec. If the light is too low you may use higher ISO setting - 200 or 400 (though higher ISO will result in grainier images, it may be your only option for blur-free photos).
Sep 07, 2005 | Olympus Camedia C-2100 Ultra Zoom Digital...
Open Questions:
See all Canon Digital Rebel XT / EOS 350D Body only Questions
Canon Digital Rebel XT / EOS 350D Body only Digital Camera Logo
462 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
