Question about Lexmark All-in-One Printer with PictBridge
Cannot get to reset
I put a new ink cartridge in , took off tape , closed lid, it won't reset to copy. keeps saying cover open. i've redone it several times.it seems to be stuck on cover open.
    Sergeant:
    Novelist:
  • 327 Answers
There is a sensor in the printer that goes down when you close the cover that sensor is either moved from its place or got broken.just tab the sides of the printer little hard and checkout many times it comes in the position due to tapping it.
thanks.
Posted on Dec 15, 2008
How do i reset ink cartridge cl511for my canon ip2700
1. Make sure that the power is turned on.
2. Open the Front Cover.
The FINE Cartridge Holder moves to the replacement position.
3. Remove the empty FINE Cartridge.
(1) Pinch the tabs and open the Ink Cartridge Locking Cover.
(2) Remove the FINE Cartridge.
4. Prepare the new FINE Cartridge.
(1) Take a new FINE Cartridge out of its package and remove the orange protective tape (C) gently.
5. Install the FINE Cartridge.
(1) Put a new FINE Cartridge in the FINE Cartridge Holder.
The Color FINE Cartridge should be installed into the left slot and the Black FINE Cartridge should be installed into the right slot.
(2) Close the Ink Cartridge Locking Cover to lock the FINE Cartridge into place.
Push down the Ink Cartridge Locking Cover until it clicks.
(3) Confirm that the Ink Cartridge Locking Cover is closed correctly.
6. Close the Front Cover.
Sep 20, 2011 | Canon Office Equipment & Supplies
How do i install mt inks
Please follow the steps below on how to install/replace ink cartridges on your model:
  1. Make sure the All-In-One is on.
  2. Lift the scanner unit until the scanner support keeps it open. The print cartridge carrier moves and stops at the loading position unless the All-In-One is busy.
  3. Grasp the tabs on the cartridge lids, and then lift the lids.
  4. Remove the old cartridges. Store them in an air-tight container or dispose of them.
  5. If you are installing new cartridges, remove the stickers and transparent tape from the bottom of the cartridges.
  6. Insert the new cartridges. Make sure the black print cartridge is secure in the right carrier and the color cartridge is secure in the left carrier, and then snap the lids closed.
  7. Lift the scanner unit and push the scanner support back while lowering the scanner unit until it is completely closed.
Sometimes the ink cartridge carrier won't automatically move to its loading position even when the printer is on and the cover is open. Follow the steps below:
1. Unplug the printer from the power source.
2. With the cover open, hold the solid white strip that connects from the carrier assembly to the ink cartridge carrier and gently slide the cartridge carrier to the center of the printer.
3. Remove the used cartridges.
4. Load the new cartridges. Close the cover.
5. Plug the printer back to the power source.
Aug 30, 2011 | Lexmark X1270 All-In-One InkJet Printer
I just put a new black ink cartridge into my printer and now it says error with alignment I've reinserted the cartridge several time and it says the same thing everytime. What do I need to do? and...
Make sure you are inserting the correct version of black cartridge for your model. Try to remove both cartridges from the printer. Close the cover. Unplug and re-plug the printer into the power source to reset it. When the printer turns on, reinsert your cartridges. You can also try to insert a different known working black cartridge to determine if the other is faulty.
Jun 26, 2011 | Lexmark X6170 All-In-One InkJet Printer
How do i change my lexmark x4650 print cartrige?
Installing/Replacing your ink cartridges:
1. Open the printer, and then press down on the cartridge carrier levers. printmastert_52.jpg
2. Remove the used print cartridge or cartridges. 3. If you are installing new print cartridges, remove the tape from the back and bottom of the color cartridge, insert the cartridge in the right carrier, and then close the color cartridge carrier lid. 4. If a black cartridge is included in the box contents, remove the tape from the back and bottom of the black cartridge, insert the cartridge in the left carrier, and then close the black cartridge carrier lid. 5. Close the printer.
May 15, 2011 | Lexmark X4650 InkJet Printer
How to open printer to change cartridge?
In order to replace the cartriage, please follow the steps below:
1 Keep the printer on.
2 Lift the printer (scanner unit) until the scanner support keeps it open.
The ink cartridge carrier moves and stops at the loading position unless the printer is
busy.
3 Squeeze the tabs on the cartridge lids, and then lift the lids.
4 Remove the old cartridges.
5 If you are installing new cartridges, remove the stickers and tape from the bottom of
the cartridges.
6 Insert the new cartridges. Make sure the color ink cartridge is secure in the left carrier
and the black cartridge is secure in the right carrier, and then snap the lids closed.
7 Lift the printer (scanner unit) and push the scanner support back while lowering the
printer (scanner unit) until it is closed.
Sep 15, 2010 | Dell A920 InkJet Printer
I have a Lexmark X125 printer. I just bought new ink cartridges because I ran out of ink. I followed the directions on the printer to install the ink cartridges and the printer keeps flashing the words...
Remove the cartridges and close the lid. Allow the system to try to calibrate and complain. Open the lid. Check the cartridge bottoms to make sure you removed the plastic cover on the jet heads.
Replace the cartridges and make sure they clip. Close the lid to finish.
if this does not solve it. Remove the cartridges and then unplug the unit from the power. hold the power button down for 10 seconds then give 20 seconds more. this will clear all power. Place the new cartridges in and close the lid. power the unit on and test for success
Feb 14, 2010 | Computers & Internet
Printer (HP5650) has full ink cartridges.window sez almost empty
That is normal, the printer "sees" the cartridges by their serial number, so when you pop in a refilled cartridge, the printer thinks you have put in old cartridges and continue to show low ink level. When you pop in a new one, with a new serial code, the ink level will reset, showing that the cartridges are full again.
You can try this:
1. Open printer lid so cartridges move to center of carriage.
2. Lift clamp and remove black or color cartridge from the holder.
3. Place cartridge on table with copper contact strip facing you.
4. Carefully place a strip of clear plastic tape over the four contacts on the upper left corner of the cartridge.
5. Reinstall cartridge in printer and close lid. Wait until cartridge returns to parking position.
6. Open lid and remove cartridge again. Remove tape from left side and place tape over four contacts at upper right corner of cartridge.
7. Reinstall cartridge in printer and close lid. Wait until cartridge returns to parking position again.
8. Open lid again, remove cartridge, remove tape.
9. Reinstall cartridge and close lid.
Printer will now recalibrate. Once the process is complete the ink level meter should be reading full again.
Doesn't always work, but you can try.
Here are links, so you can see:
http://www.misterinkjet.com/hp56reset.htm
http://www.misterinkjet.com/hp57reset.htm
Hope that helps!
Dec 22, 2009 | HP Hewlett Packard Deskjet 5650 InkJet...
After installing re-filled ink cartridges, both color and back & white, the printer message that shows ink level still shows low level ink? How do we resolve?
Try this procedure:
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Hi, please tell me how to install a new black ink cartridge into my epsonstylus D78 printer
Open the cover. Press the Ink/maint button (triangle shape on button) this moves the carriage to indicate empty cartridge. keep pressing until carriage moves to the ink replacement position. Open ink cartridge cover and remove the cart. Ensure you remove the yellow tape on new cart' before installing and be careful not to touch the chip on the cart'. Push new cart' in until it clicks. Close lid (ensure clicks down), close printer cover and press ink button again.
Please take a moment to rate this solution, thanks.
Mar 26, 2009 | Epson Stylus C86 InkJet Printer
Dell 725 printer no manual need to change ink cartridge
Here is the manual
http://support.dell.com/support/edocs/systems/725/en/index.htm
Replacing an Ink Cartridge
  1. Turn on your printer.
  2. Lift the front cover.
The ink cartridge carrier moves and stops at the loading position unless the printer is busy.
  1. Press down on the ink cartridge lever to raise the ink cartridge lid.
  1. Remove the old ink cartridge.
  1. Dispose of the old cartridge properly.
  2. If you are installing a new ink cartridge, remove the sticker and transparent tape from the back and bottom of the ink cartridge.
  1. Insert the new ink cartridge.
  1. Snap the lid closed.
  1. Close the front cover.
Feb 09, 2008 | Dell 725 InkJet Printer
Lexmark All-in-One Printer with PictBridge Logo
52 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
