Question about IBM 300PL (PC 300 PL 733) PC Desktop
New cd rom doesn't work
Op sys can't find the CD rom anymore, A, C E and F drives are recognized but the D isn't even though the device manager shows it.
So does anyone have the Mother Board dip switch settings for the 300PL ?
  • masher16 Nov 22, 2008
    I swapped the original DVD rom with a RW and it worked fine then I switched back to the DVD ROM drive and that is when the D drive was gone. I have been in admin tools drive/disk mgmt and the D drive doesn't show up anymore only things that show up are A (floppy), C main, E: USB and F a second harddrive which was there from day one.
    I did disconnect the 2nd harddrive F and the USB E and try reinstalling the DVD but in this case all that was visible were A and C and still the BIOS showed the DVD drive as installed.
    The BIOS still shows the DVD-ROM drive but it's listed in slot zero with my C drive. I did check to make sure it was set for slave but it still won't recognize it.
    I did swap it to another slot and still doesn't work.
    I tried master and slave config on different cables but still it does not show up in admin tools disk mgmt; but as I said the bios shows it there.
    Lets see what else ?
    Oh yeah both the CD-RW and the DVD drives work in another PC so it's not a drive problem.
    Interesting when I go to admin tools / computer mgmt storage/removable storage/physical locations it shows the DVD-ROM drive as crossed out in red, IE disabled but I cannot enable it.
Have any you added any drives to your computer recently? If so you'll have to check the jumper settings on your drives. If nothing has changed to your computer between the time it was working and when it stopped then you most likely have a dead drive.
But since you say the device manager sees your drive you'll need to go into your administrator tools in the control panel and select computer management. Under storage select drive management. If you see your drive listed but has no drive letter you can right-click the drive and assign a drive letter. The change should be immediate.
Posted on Nov 22, 2008
My DVD/CD-RW drive isn't recognized/ doesn't play disks.
It may be bad. Has the laptop been damaged? Dropped? Open Device Manager, DVD/CD Rom drives, is it listed? In Start Menu, Computer, Is it listed? Try re installing the DVD rom driver, the MS Vista 32bit drivers can be found here: http://www.dell.com/support/drivers/us/en/04/Product/vostro-a860
Feb 02, 2013 | Dell Vostro A860 Notebook
Bd rom wont eject
If it does not eject, how does it open?
Make sure it has power (ejects). Check Device Manager in Safe Mode by pressing F8 during boot. Right click My Computer > Manage. Select Device Manager > View > Show Hidden Devices. Now delete all DVD/CD-ROMs and reboot. Windows will say "New Hardware Found" and install. Check BIOS by pressing F key (correct F key is noted during boot) and make sure BIOS see's the Optical Drive.
Nov 28, 2012 | Computers & Internet
Acer aspire 5740 DVD not recognized
Oct 25, 2012 | Computers & Internet
My dvd player is not recognized by my computer anymore.
Click start control panel administration tools computer management device manager scroll down cd-dvd rom drives you might see a yellow question /exclamation mark ? ! or a red X right click to update driver
you might have to physically unplug the leads for this cd/dvd restart your computer then plug them back this should activate the found new hardware wizard
if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope it helps
Jun 04, 2012 | Pioneer Bd-rom Dvd±rw Laptop Drive...
HP dv6745 cd/dvd rom drive isn't recognized in dev. manger but is in my Bios
hi
take your OS CD , insert into CD bay-- when prompted to , select REPAIR
this will correct any corrupted registry errors that my be found in your OS, which is causing the lack of recognition for the CDROM driver
good luck
Jan 03, 2012 | HP Pavilion DV6745US Notebook
Computer does not recognize CD/DVD disks in drive. My Windows XP PC has suddenly stopped recognizing disks in my CD/DVD drive. Device Manager shows that both of the listed drives (TST Corp. DVD +RW...
Most likely a problem with the reader on the CD/DVD Drive.
Very easy to swap out a different CD/DVD Drive. Add the new device and see if that resolves the issue.
May 02, 2017 | Computers & Internet
Cd Drive Doesn't work anymore.
Okay. Restart your computer and after, go to device manager (right-click on My Computer/Properties/Material/Device manager). Do you see a CD-Rom/DVD drive?
Sep 01, 2008 | Computers & Internet
DVD NOT SHOWING
hi frined
change ur data cable & power cable & try to ditecing
if not show then do one ting go in a device manager >system devices>pci bus>right click on it & uninstall then ur pc is restarts
& insatll ur all divce drivers correctly
thnx using fixya
Apr 01, 2008 | LG (CRD-8400CB) CD-ROM Drive
Cd-rom
Check it from Device manager;
Right Click my computer. Go to properties.Hardware tab; Device manager; See under device manager ! any yello sign; ETC;
If you could not find any alternate Best Solution is try replacing CD DVD Rom
Regards
Rafique
Mar 17, 2008 | HP (PR017UA) PC Notebook
IBM 300PL (PC 300 PL 733) PC Desktop Logo
80 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
