Question about KitchenAid KP2671 Professional 6 Series Stand Mixer
Attachment drive failed
The drive for the attachment hub failed while using the grinder attachment. The mixer drive still works but the attachment drive does not. Can I get the parts and fix this myself?
Given the dismal reputation of this machine I am reluctant to spend the money to send in to a repair depot but would be wiolling to try and repair it at home.
Thanks
  • 3 Answers
How to use food grinder attachment
The mixer's planetary is not disconnected when the meat grinder is attached and continues to turn.
If the noise you hear only occurs when the grinder is in place, then the grinder may be assumed to be the cause. Consult the meat grinder's instructions and make sure that nothing is loose or overtightened.
Mar 04, 2015 | KitchenAid Kitchen Aid K45SSWH Classic...
Need help getting food grinder attachment troubleshooting cant get mine to operate
When you use an attachment the mixer will still stir. You need to remove the beater when using an attachment.
Mar 04, 2015 | KitchenAid K45SS Classic Stand Mixer
I have a kitchen aid 5 at. Mixer when I use my grinder attachment I notice oil/ grease on shaft what is that caused from
Sounds like a problem with the bushing around the accessory drive. If still under guarantee take it back and get it sorted. If out of guarantee take it to an authorised service centre.
Dec 15, 2014 | Food Mixers
Kitchenaid Artisan Stand Mixer has stuck hub bevel gear (KSM150PS)
The bevel gear sits above the worm-follower gear. I think you mean the drive attachment gear.
I think I have the same, or similar problem. I ground a piece of meat that stopped it from working. The drive-attachment-gear turns if I push it in, but then it pops out. I am still trying to figure out what part is causing the issue - the drive attachment gear, or maybe even the worm follower gear.
Feb 24, 2013 | KitchenAid KSM150PSGR - Artisan Series...
Makes clunking noise when mixing or using attachments. Gear slipping?
Hello Angelfyro72,
Does the machine make the same noise when there is nothing attached to it at all? I have a few suggestions but I need to know this first. I do not believe that it is a gear but actually in the backend of the unit. Please post back to this discussion thread.
Thank you for chosing FixYa.com
Mar 03, 2011 | KitchenAid Food Mixers
I was using meat grinder attachment and stand mixer stopped running
I just got the same problem too. There was a little piece of fat in the meat and it stopped the grinder. I removed it but the attachment rotates a full turn and then stops. The same happens with other attachments even under practically no load.
Dec 02, 2010 | KitchenAid Food Mixers
Front attachment won't turn
It sounds like one of the gears inside the head has failed. You will need to remove the head and take it apart to work out which one. It should be relatively easy to get hold of the part you need once you have identified it. Please post your model number for us to point you to the right parts list.
Jan 13, 2010 | KitchenAid K45SS Classic Stand Mixer
The pasta/meat grinder attachment stops turning
Its a 325 watt mixer. If you grind or mix dough often you may consider getting something stronger or turn it off every ten minutes or so and let it cool down. We burned a 325 and got the 575 watt "600" series and no problems ever since. I know these things are expensive. The 325 is more mixer than grinder. The attachements fit ANY size mixer but some are not recommended for use in all mixers.
If its quiting see my posts on "doesn't run at sitr" and "Removing the motor cover" To get inside and clean those contacts.
Feb 08, 2009 | KitchenAid KSM150PS Artisan Series Stand...
Hobart A200
Yes A-200 are number 12 I would find a hobart grinder they will have a big H in the casting on the neck get one with a stainless pan and stomper to push product down the throat. If you wait on Ebay and put it on your watch list they do come along. look for no rust. Make sure it has the big H in the casting. the other after market ones seem to not last long like the metal wears on the worm and hub to fast. also you always know where to get a piece if you need it if its a Hobart. not so with the forign jobs.
Dec 29, 2008 | Hobart A200 Stand Mixer
Grinder attachment
Cindy,if it has a screw take it out,grab a flathead screwdriver and work your way around the cap.Some mixers have been painted or just the gunk over the years make the cap hard to pull off.The push button i have never seen on a hobart mixer near the hub.Give me the serial and spec number.
Nov 12, 2008 | Hobart A200 Stand Mixer
KitchenAid KP2671 Professional 6 Series Stand Mixer Logo
214 people viewed this question
Top KitchenAid Food Mixers Experts
Appliance engineer
jack arons
Are you a KitchenAid Food Mixer Expert? Answer questions, earn points and help others
