We have a neptune washer with an error code of E2. It will not turn off or do anything. Please help. Thanks
  • Kevin Shafer
    Kevin Shafer Dec 05, 2008
    I think it was rated inappropriate because you didn't answer his question.....He asked what that error code meant and you gave some generic write up about timers that has nothing to do with the error. code. If you don't want to be rated inappropriate, answer the questions that are asked.
    Genius:
  • 1,239 Answers
HI
Most washing machine timers are digital or mechanical. The timer controls most of the operations of the washer: water level, tub filling and emptying, length of cycles, and cycle setting sequences. For this reason, any repairs to the timer should be made by a professional service person. However, there are a couple of checks you can make when you suspect the timer is faulty -- you may be able to install a new timer yourself.
Step 1: Unplug the washer. To access the timer, remove the control knobs and the panel that covers the controls. This may be a front panel, or access may be through a panel at the back of the unit. Carefully examine the wires that connect the timer to the other parts of the washer. If the wires are loose or disconnected, try pushing them into position; they usually fit into their terminals like plugs. Use long-nosed pliers to avoid breaking the wire connections -- never pull a wire by hand.
Step 2: To test the timer, use a VOM set to the RX1 scale. Disconnect the power leads to the timer and clip one probe of the VOM to each lead. The VOM should read zero if the timer is working. Since the timer is a multiple switch, turn it through its cycle and test each pair of terminals in turn. The meter should read zero at all of these points. If one or more readings are above zero, the timer is faulty and should be replaced.
Step 3: To replace the timer, unscrew and disconnect the old one. Install a new timer made specifically for the washing machine. If there are many wires on the timer, have a helper hold the new timer next to the old one as you work. Disconnect the old wires one at a time, connecting each corresponding new wire as you work, to make sure the connections are properly made. Or, draw a diagram showing the connections before removing the old timer. After all the wires are connected, check the connections again for correctness and screw the timer assembly into place.PLEASE RATE AS HELPFULL
Posted on Nov 22, 2008
  • ABHISHEK.C
    ABHISHEK.C Nov 25, 2008
    hi sir i given a correct soluution.if you want contact fixya support  about this.please change your rating i will affect my rating badly.please change it..............................please
No lights on control board, door locked, MAH9700
Unfortunately the control board is dead and will need to be replaced. Here is the board to order if you decide to order it.
The E2 error code was for a stuck button and it would require the control board to be replaced also.
Dec 08, 2012 | Maytag MAH9700AWM Neptune Front Load...
I have a Maytag Neptune MAH 6700 AWW. It is shutting off and giving error code tE. Customer service does not recognize the error code. Can you help?
This is a problem with the signal from the water heating element "Thermistor" a Thermistor is a solid state sensor that senses temperature, in this case water temp. The Thermistor is part of the washers water heating assembly and not sold separately from it. There is a factory repair bulletin associated with the problem and the new part has improved reliability. I can't understand what the Maytag folks you called would tell you it is not listed, it is a common fault in the Neptune. Please rate my help. Thanks
Jan 23, 2012 | Maytag Neptune MAH5500B Front Load Washer
Error code E2 on neptune washer
Heeey - If I remeber correctly code 02 is the failure of the door to unlock, the microswitch fitted next to the door lock operates in unison with the door lock, it may well be the problem with the washer..
Jun 21, 2011 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune FAV6800AW Top Load Washer? makes a
more than likely it just needs a little leveling...lift front of washer . there are 2 leveling feet on each front corner under the washer.. they turn like a screw ..just adjust these feet till its level and you should be ok....shake the washer by hand . if it doesnt move it shoud be level,,,,an unlevel washer makes terrible noises ...as you know..thanks and have a great day
Jan 03, 2010 | Maytag Neptune FAV6800AW Top Load Washer
How do I stop the error E2 code on my washer? I
The E2 shows that there is a motor problem. This can be caused by having an extra heavy load in the machine so take some out and try it. It can also be cause by any iof the buttons being stuck so make sure they are all 'free'. If this fails then you will need to have a new motor and call a repair man unless you can do the job yourself.
Sep 11, 2009 | Maytag MAH6700AWW Neptune Front-Load...
Cycle stops 3E code appears
Well the error code 3E means that the overcurrent is detected at the moter.
Please check it if you have some overcurrent problem!
Thanks!
mannu_rakesh
Sep 01, 2009 | Maytag Neptune MAH5500B Front Load Washer
CANNOT RESET E2 ERROR CODE TRYED UNPLUGGING DID NOT WORK
I have only worked on USA machines but I believe you have a control panel error.
Sep 27, 2008 | Maytag MAH6700AWW Neptune Front-Load...
Power cuts off
The machine beeps E2 all the time. Actually E2 error code means washer door is not closed properly. However washer door does close properly, but the machine still beeps with showing E2 error code. Please help solve this problem.
Many thanks,
Robert
Jul 04, 2008 | Haier XQB60-91AF Top Load Washer
Maytag Neptune Front Loader - E2 error code
The first time my E2 code came on the washer won't rinse or spin. I checked the drain pump to make sure it was working. (1) Take the back off and pull the two drain lines off pump. Be careful the line going to the drain has a backflow flap, make sure you don't tear it.
(2) On the other side where it drains from the washer to the pump is where I found a bobbie pin that had collected lint and was blocking the drain flow.
When it can't drain the E2 code comes on to let you know it won't rinse or spin.
Make sure to unplug machine before removing back,
Hope this helps everybody with E2 problems.
stude
40stude@bellsouth.net
Nov 29, 2007 | Maytag MAH6700AWW Neptune Front-Load...
Washing Machines Logo
71 people viewed this question
Top Washing Machines Experts
