After turning on car works fine then might do it again later sometimes when car is parked over night or a cupple of hrs it wont turn on then try again 20 mints later or so then works fine.
SOURCE: vw golf 1990 - problem
1. This could be because the fan motor is not workin. Check the fuse and check to see if you are getting power to the fan motor. If these checks are ok, then I would suspect the fan motor.
2. This will most likely be the drive belt that runs the alternator that either needs adjusting or replacing.
3. You will need to check your ignition timing.
Regards
Ray
SOURCE: trouble starting equinox
I had a similar problem on an 02 Silverado. Replacing the fuel pressure regulator fixed the problem.
I had the same problem. Turns out,( and I didn't believe it when I was told) but, my problem turned out to be cheap (inferiour) plugs and wired. I was reccomended to use NKG plugs and Borg-Warner wires.
SOURCE: Car won't shift out of park while turned on
YEP BRAKE LIGHT SWITCH FUSE IS BLOWED.WHEN ITS BLOWED IT WILL KEEP BRAKE TRANSMISSION SHIFT INTERLOCK SOLENOID FROM WORKING.YOU CANT GET CAR OUT OF PARK.IT NEEDS POWER TO WORK.FUSES BLOWS AT BRAKE SWITCH NO POWER.YOU WILL NOT GET IT OUT OF PARK.SO CHECK FUSE THAT COULD BE YOUR PROBLEM.
SOURCE: our 2001 lincoln ls was running fine, then all of
I would love to answer this question but I am having the same issue. I have a 2000 LS with the V8..replaced the battery about 2 weeks ago and last night I went to go home and it won't start. All the bells ring when I turn the key but when I turn to the right to "start" position, nothing. No clicking, no noise at all. I called the Lincoln dealership and we went over the alarm light "not flashing" and shifter position. They have no advice other than "tow it in".
The vehicle had been running fine.
