Question about Kenmore 24 in. 15999 Built-in Dishwasher
Kenmore DW model 15999 Lower Spray Tower Came off
I have a Kenmore dishwasher model 15999 .
When I opened the door and started to pull out the lower rack, it looked like something was catching and preventing the rack from coming out. Protruding thru the lrack was a cone shaped object which I pulled thru.
The manual says it is the Lower Spray Tower. It also looks like the circular plate is raised up from it's normal position.
The users manual just points out the spray tower and nothing else is described. Does anyone have any idea how I can reattach this cone shaped item so I can get back to the business of washing dishes?
Thanks, Cyndee
Yes, I was able to get it fixed.
The spray tower actually fits in the rack (I had thought it fit in the top of the lower spray arm - wrong!)
If you were to look at the spray tower itself, it has 2 little clip like plastic protrusions that with a little twist will clip onto the lower rack!
Push the lower rack in and you can see where the center would be, (right over the middle of the lower spray arm ).
Now pull out the rack and take the spray tower and slip it under the rack up thru the bottom in the position you noted was the center (from above).
Now with the spray tower in place, slide the rack back inside the dishwsher and you will see that the tower will be sitting directly over the top of the exact middle of the lower spray arm.
Voila!
Posted on Nov 24, 2008
Why does the lower spray arm keep coming loose on a Kenmore 587.15189402
Is this one of those drawer-style dishwashers, or a regular DW? I can't seem to find that model number in my search. If it's a regular (door-opens-downward) DW, then you probably don't have the lower wash arm attached properly. On some DW's you turn the hold-down "screw" in the reverse direction to tighten it. If it's a new Kenmore Elite DW, then you turn the lower square or geared section 1/8th turn clockwise to lock it. Of course, you may have a damaged or stripped plastic part that just won't stay....
Oct 20, 2014 | Kenmore Dishwashers
Mod m.d.c.5100aww ser28126829ax I had a repairman come out. He said the "sprayers" are plugged. I'm on a fixed income. With my bills I can't afford to get it fixed. Trying to fix it myself. I...
Most dishwashers dispense the detergent via gravity and the sprayer arms spraying against the soap dispenser once the little door flips open during the wash cycle. Since it sounds like the soap door is opening I would look at the sprayer arms and make sure they are free of food particles or other debris that might be keeping them from rotating and spraying properly. Here are some instructions for performing this check.
Remove the lower dishrack from the unit. Reach into your dishwasher and spin the lower spray arm. Take note of whether or not the arm moves freely or if its movement is restricted. It should not be restricted in its path of motion. Now gently pull up on an end of the spray arm. The spray arm should be free to wobble up and down. Unscrew the arm retaining knob (some of these are left hand threads) and take the arm out for inspection and carefully examine the spray arm seams. If they have split or are damaged, the dishes may not receive the amount of water pressure required to fully clean the dishes or to rotate the arm properly. What’s more, if water is in fact spraying out of the spray arm from its seams, it is possible that it can cause your dishwasher to leak. Make sure there is no debris in any of the holes.
If your dishwasher has a spray tower, pull up on it as far as it will go and then let it fall back down. Again, this movement should not be restricted. It should be a fluid and smooth motion. Also, unscrew the spray tower and examine it for any debris or foreign objects. Remove any that you find.
Gain access to the upper spray arm by removing the upper dishrack. Perform the same tests for the upper spray arm as you just did for the lower spray arm. Keep in mind that the upper spray arm may not wobble as much as the lower spray arm.
On a final note, some dishwasher models have a water tube that meets up with the upper spray arm once the upper dishrack is pushed back. It is a good idea to check to make sure this tube is aligning properly with the upper spray arm and that this has not split or is damaged in any other way.
Mar 24, 2008 | Dishwashers
How to remove the pump from the motor on a Kenmore dish washer model 363.14572000
Steps:
1)Shut off power to the dishwasher at the circuit breaker and turn off the water line to the dishwasher by locating the shut-off valve, which is typically inside the cabinet beneath the kitchen sink.
2)Remove the four screws that hold the dishwasher kick plate in place.
3)Locate the motor,which is typically centered beneath the bottom spray arm.
4)Lower the dishwasher door and take out the bottom dish rack.
5)Remove the spray tower and spray arm assembly by unscrewing the bolt through its center.
6)Take out the filter immediately beneath the spray tower.
7)Disconnect the motor wires from the wiring harness,making a note of which wire connects to which terminal.
8)Disconnect the pump assembly and drain hose from the motor.
9)Remove the motor from the base of the dishwasher by unscrewing the four bolts holding it in place.
10)Repair or replace the motor and reinstall,taking care to reconnect the wires the same was as they were attached to the old motor.
11)Attach the pump and drain hose to the motor.
12)Replace the filter,spray tower and lower spray arm assembly.Reattach the center bolt in the spray tower.
13)Restore electrical power and turn on the water supply valve.
14)Run a test cycle to check for leaks underneath the appliance.
15)Replace the kick panel in front of the dishwasher.
Jul 31, 2010 | Kenmore Dishwashers
Dish washer, Water leaks out of right front corner during first
it sounds like your machine is over filling. the gasket is not supposed to be under water. check the overflow float inside. it looks like a little hat or cone. it should move freely up and down. if it is stuck down, your machine will fill up too far and then leak. good luck
Oct 30, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
My Kenmore under counter ultra wash dishwasher model 665.15825691 has started leaking at the lower corners of the door. The leaks seem to occur during the final rinse while the water is being heated. I...
Happened on my dish washer too. Remove lower rack, remove lower spray arm by removing the center plastic nut, check screws (torx) on outside edge of pump. Tighten these as necessary, mine were loose causing water to spray forward against the tub causing leakage.
Jun 27, 2009 | Kenmore Dishwashers
Kenmore dishwasher model # 665.15522000 leaking badly
Hi, Make sure the jets in the spray arm ore not plugged at all. Check the black bellows on top the lower spray arm and see if it has a split in it. Let me know if these help or if I can assist you further.
Vic
May 21, 2009 | Dishwashers
Dishwasher lower spray arm falls off
These parts can be replaced easily and reasosnably cheaply for example the top spray arm is about £20.00p. But you need the back water feed tube as well as the lower spray arm which should come as one package. (depending on model i'm going by bosch). You shouldn't have to pay more than £30.00p + p&p. Hope this helps.
May 19, 2009 | Dishwashers
No water flow to
So, you know that the screen in the water fill hose is not blocked, right?
The next most common problem is a failed float/ float switch. When that switch fails to open/close properly, no water will enter.
Last, the solenoid valve where the water fill hose connects to the DW, could be failed.
Good Luck!
May 05, 2009 | Hotpoint 24 in. HDA3400G Built-in...
Water doesn't heat up
The most common reason for no heating is the failure of the heating element which is located beneath the lower spray arm. Inspecting it for breaks and damage would be the first step. If you do not see obvious damage, after triple checking that poser is off to the DW, pull the kick panel from your DW and check where the heavy gauge wires connect to the two terminals of the heating element.
Please post back here with further questions or what you found, OK?
Dec 14, 2008 | Kenmore 24 in. 17462 / 17464 / 17469...
Kenmore 24 in. 15999 Built-in Dishwasher Logo
410 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
vince
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
