and is there any error message appear, thats why the device is not working.
Comments:
Nov 24, 2008
- If the drive tray is jammed, and the tray cannot be ejected and cleared
manually, the drive should be replaced. Some drives have an emergency
eject hole.
If
for any reason the tray does not eject automatically, insert and press
an eject-bar inside the emergency eject hole to manually eject the
tray. A straightened paper clip with a diameter of 1.2 mm (typical) can
be used as an eject-bar.
NOTE: Make sure to turn off the power before manual disc eject operation.
hi, first you can remove the disc from the drive with a small needle or something small that fits into the hole in the drive tray, it will eject the disc.
after the disc is out, restart the computer, turn the drive on and off, connect it to the computer with usb, turn the drive on, turn the computer on and see if it works, if it doesn't work try another usb connector.
if its still not working have a look into the device manager while its connected and turned on, right click my computer and select manage, then on the left side of the window select device manager now on the right side look for anything with a ! or ? mark on it, or a unknown device, turn the power off on the device and see if something dissapears, what dissapeared is the usb drive, power it back on and right click on it to see the status.
theres a place that says' show cd text' on the burning preferences,but its grayed out ,you cant...
(More)
theres a place that says' show cd text' on the burning preferences,but its grayed out ,you cant click on it.
i mistakely desconnected the usb cable when i was installing the software and then automaticaly stop...
(More)
I MISTAKELY DESCONNECTED THE USB CABLE WHEN I WAS INSTALLING THE SOFTWARE AND THEN AUTOMATICALY STOP WORKING AND EVEN THE CD TRAIL DONT OPEN THANKS.
