Question about Sony VPL CX10 Multimedia Projector
Yellow-green tint My Sony projector image(VGA CX10) now has a bright yellow/green tint. This tint is not visible when I view the projector menu. Is the bulb going/gone? Can anybody help? I have set all the resetting to factory default. Thanks.
I had the same problem and found out that it was the cable from the projector to the computer. HD D-sub 15-pin cable.
Posted on Apr 08, 2011
  • Lisa Nichols
    Lisa Nichols May 27, 2014
    I already changed out cables and still have yellow tint. Anyother idea?
Projector image has heavy green tint, change lamp but still getting green tint, what should I check next?
Check the connection. Some pins on the VGA? may have been twisted or broken. Use a different cable.
Apr 01, 2016 | Office Equipment & Supplies
Green tint
what cable are uusing coumpount vga 15 pin to coumpunt or u try new cables
Jan 24, 2008 | Dell 3200MP Multimedia Projector
Colour balance
does it look like that when you view the menu? Across all sources?
Apr 23, 2013 | Mitsubishi XD510U DLP Projector
I have a Christie LX100 Projector when projecting a white image there is some yellow tint. Is this something that can be fixed?
If the yellow tint is uniformly over the whole screen then try changing the video colour tint, hue, phase and other chroma related settings in the menu.
Apr 10, 2011 | Christie RoadRunner LX100 Multimedia...
Our club owns a Canon LV-7240 which has worked OK. Last night we showed an NTSC DVD from Europe and no red showed. We could see what the colours ought to be on the laptop screen. On the big screen,...
Can't answer for the menu issues, but I can garuntee this is not a problem with brightness, contrast or sharpness, and very unlikely that you'll find a solution in the menu. What is likely is that the VGA wasn't plugged in properly initially. When the signal is going down the VGA it's broken up into 5 seperate signals, Red, Green, Blue and 2 sync signals. What is likely is that the green and blue pins havn't properly made contact either inside the projector or inside the laptop. This would also explain why it worked when you tried later because it made the connection properly. I would suggest trying again with the same laptop, if it does it again, try another PC without moving the projector or the VGA connector that's plugged into the projector. This will atleast narrow down your problem, but it doesn't sound like a problem with the projector to me. Also try plugging the laptop that wasn't working properly into a monitor (this will test the laptop)
Mar 25, 2011 | Canon LV-7240 Multimedia Projector
Sony vpl-cx10 ,,powers up but no light
If the new lamp didn't make a difference, it is most likely your lamp ballast that needs to be replaced.
Mar 31, 2009 | Sony VPL CX10 Multimedia Projector
Display has a green tint to it tho it looks fine on the laptop.
A tinted image (whether green or another color) is almost always a symptom of a bad or damaged cable - or a loose cable connection. In your case, you'll likely need a new M1 to VGA cable (Part# SP-DVI-A-R).
Assuming that you've made sure that the cable connections are solid at both ends, there is a simple test to verify that this is a cable issue and not a costly projector issue. While the image is tinted green, open the menu. If the menu colors appear fine while the rest of the image is still tinted green it's the cable.
Jan 21, 2009 | InFocus LP70+ Multimedia Projector
Infocus LP70 - It's all Green
A tinted image (whether green or another color) is almost always a symptom of a bad or damaged cable - or a loos cable connection. In your case, you'll likely need a new M1 to VGA cable (Part# SP-DVI-A-R).
Nov 20, 2007 | InFocus LP70+ Multimedia Projector
Sony KP-51WS500
does it have blue video image?
Sep 29, 2007 | Sony KP-51WS500 51" Rear Projection...
Sony VPL CX10 Multimedia Projector Logo
1,201 people viewed this question
Top Sony Office Equipment & Supplies Experts
shaun taylor
Jaime Hernandez
Are you a Sony Office Equipment and Supply Expert? Answer questions, earn points and help others
