Question about Bosch Exxcel WFO 2264 Front Load Washer
Bosch washing machine won't drain and the door won't open.
I have a bosch washing machine exxcel 1400.
I put a load of washing in and put the machine on. The cycle won't finish and the door won't open. When I turn the dial to rinse/ spin / drain, nothing happens.
What can I do?
  • nconnor Nov 22, 2008
    Thank you for this advice. I drained off several litres of water. I then found a couple of bits - old coin, broken paper clip in the filter. However it still doesn't work in the spin cycle. What can I try next?
  • Anonymous Mar 29, 2014
    Washing machine door is locked. Now that the cycle is finished the door will not unlock. I have tried turning it on and off with no luck.
  • 135 Answers
Sounds like you have a blocked pump.To empty the machine manually lower the drain hose into a bowl or bucket.Once emptied the door should open.On most modern machines there will be a filter behind the kick plate at bottom front of machine, Check this for any foreign objects then try a spin before putting on again.If problem persists come for further options.
Posted on Nov 22, 2008
  • pedropony2 Nov 23, 2008
    If the pump runs but drum does not turn then the next step is to check the motor brushes.To do this take back plate off machine and remove belt and motor.At rear end of motor you will see brush holders with a wire attached.Remove brush to check for wear.When new the carbons are around 40mm long. Let me know how you get on,
2 Suggested Answers
SOURCE: my bosch exxcel 1600 has justarted to bep when
Just wondering if you ever found a solution as I was about to post the same question.
Posted on Nov 16, 2009
Exxcel 1400 s express washing machine key light is on cannot use . or find operating manual help
pick the last program you put on ????
then you hold the button with the clock on it for five seconds the lock should now be off
please leave feedback if it helps
Jan 06, 2013 | Bosch Exxcel WFX 145S Front Load Washer
Bosch Exxcel 1400 washing machine problem
Bosch Exxcel 1400 washing machine This video will show you how to find the fault on a Washing Machine that Won't Drain or empty the water away on Bosch
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
And don't forget to like us on facebook
Oct 20, 2012 | Bosch Washing Machines
Bosch excell 1400 won't drain although the pump is spinning. took all the pipes off before and after the pump cleaned them, drained a couple of times then stopped manually drained it witnessed the pump...
If you are certain that there is no blockage or restriction anywhere and the filter is clear, then I would suggest you replace the pump to solve the problem.
They can work intermittently sometimes,due to wear on the pump impellor.
Jan 30, 2011 | Bosch Exxcel WFO 2465 Front Load Washer
Bosch exxcel 1200 express fault code f04 what is it
i had this problem,no drain or spin,opened the flap at bottom right hand corner and pulled out small hose to drain machine opened circular filter cover (some water may come out) and found a 5p and 1p blocking filter after removing ,machine worked fine.
hope this helps
Apr 02, 2010 | Bosch Exxcel WFX 2467 Front Load Washer
I have a Bosch Exxcel 1400 S Express which blew
There is no internal fuse in the washer to replace.
If you have replaced the fuse, make sure that is is a good one.
If you are satisfied that you have power to the washer, then I'm afraid it sounds quite serious.
Trust this helps.
Dec 04, 2009 | Bosch Washing Machines
USER MANUAL FOR BOSCH EXXCEL 1400 EXPRESS WASHING MACHINE
just go a bosch washing machine exxcel 14 express cant get it to work can anyone help i dont have the user book my email is sironsheik@hotmail.com
Apr 01, 2009 | Bosch Exxcel WFX 145S Front Load Washer
Bosch 1400 exxcel
The machine thinks the drain is blocked.. check the pump and outlet pipe for buildup of dirt.
I noticed holding start down for several seconds whilst powering the machine on, then turning it off / then on again would clear the machine's idea of where it was during a program. Does this affect the error code you're seeing?
May 26, 2008 | Bosch Exxcel WFO 2264 Front Load Washer
Bosch Exxcel WFO 2264 Front Load Washer Logo
1,130 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
